Just tried it too, voltage is discovered, percentage and lux. Audio etc too.
the previous discovered sensors like door and motion needed to be deleted and discovered again otherwise the status would not be updated. (It now contains more fields)
But after 2 or 3 status changes those never changed again. The log does see the sensor status, but it is not reflected in the switches.
Tried with a empty database, same.. lux updates only once an hour, I revered to the April 1 git beta and all working again.
Great work, will try again soon
- mvveelen
Nice addition indeed. If I understand well, you could use the gateway as a doorbell for instance? Keep up the good work
bing69
Yes you can!! But i think only with the appmvveelen wrote:Nice addition indeed. If I understand well, you could use the gateway as a doorbell for instance? Keep up the good work
Not anymore with the new functions. The xiaomi gateway contains a number of sounds that can easily be triggered by a script or scene.bing69 wrote:Yes you can!! But i think only with the appmvveelen wrote:Nice addition indeed. If I understand well, you could use the gateway as a doorbell for instance? Keep up the good work
So, use a switch device, trigger a sound in the gateway and done..
bing69
You mean in the latest beta or beta in the future. I see no options with the latest betajoebar wrote:Not anymore with the new functions. The xiaomi gateway contains a number of sounds that can easily be triggered by a script or scene.bing69 wrote:Yes you can!! But i think only with the appmvveelen wrote:Nice addition indeed. If I understand well, you could use the gateway as a doorbell for instance? Keep up the good work
deennoo
please have a read to this long post and you will learn what is our futur.bing69 wrote:Yes you can!! But i think only with the appmvveelen wrote:Nice addition indeed. If I understand well, you could use the gateway as a doorbell for instance? Keep up the good work
about sound we have on the gateway :
where : mid for Alarm Bell
0 : police car 1
1 : police car 2
2 : accident
3 : countdown
4 : ghost
5 : sniper rifle
6 : battle
7 : air raid
8 : bark
Door Bell Tone
10 : doorbell
11 : knock at a door
12 : amuse
13 : alarm clock
Alarm Clock
20 : mimix
21 : enthusuastic
22 : guitar classic
23 : ice world piano
24 : leisure time
25 : child hood
26 : morning stream liet
27 : music box
28 : orange
29 : thinker
+ personnalise sound (don't know yet what is the limit on full free sieze available or if there is a limit of number, if some one an test this and provied infomation this can make us a real big step forward)
Volume value can be controled to adding : "vol":0-100 to your write data command (slider on domoticz)
https://github.com/deennoo/lumi-gateway-local-api provied you all usefull option (will translate chinese to english)
how to test sound ? easy compile domoticz from this source : https://github.com/corbinmunce/domoticz following this guide : http://www.domoticz.com/wiki/Linux#Comp ... z_binaries no help on this, you have to use the good source from corbin
Just remember that a pre-beta, don't complain about problem except if you have a solution (use issue on github), all change on this will be report on official beta when all is ok.
http://domo-attitude.fr
xxLeoxx93
I switched the type from "selector" to "on/off" and after that I couldn't press the editbutton anymore. I got it working again by removing and readding the device.corbin wrote:Edit the switch button how? I can edit mine ok but it would likely break some functionality.xxLeoxx93 wrote:@cobin allow your modifications to domoticz to edit the switchbutton? I'm using the official latest beta, but I can't edit my switch
BTW: Is it confirmed, that the xiaomi zigbee plug works as an repeater? And is there any way to add more than one gateway to domoticz? I've two, but the second-one is not displayed (probably because they use the same port?).
murtadin
I do not see audio device from gateway.... Pls show screenshot how it looks like. And may be script example - door bell would be nice.
deennoo
grrrrrr have you read what i write before ? ;-p ?? have you compil from corbin fork ? if not, wait for an update to official beta.murtadin wrote:I do not see audio device from gateway.... Pls show screenshot how it looks like. And may be script example - door bell would be nice.
murtadin
Of course i compiled from Corbin's fork )). I see lux device, but audio nope.deennoo wrote:grrrrrr have you read what i write before ? ;-p ?? have you compil from corbin fork ? if not, wait for an update to official beta.murtadin wrote:I do not see audio device from gateway.... Pls show screenshot how it looks like. And may be script example - door bell would be nice.
Sent from my MI MAX using Tapatalk
deennoo
i did it this morning and i got it...pic join just before.
Have you git pull your copy of corbin fork and recompil it ? this have to be done each time after an update on his fork.
Xiaomi Gateway Audio is the name of the device discover
murtadin
I just updated few hours ago. No luck.
Glad you got it sorted mate. These things are sent to test usmvveelen wrote:It tells me too much I guess. Tried to follow some tutorials, but I can't figure out what to do or even where to start. I'll report back tomorrow after trying the Samsung to regenerate a password.
Edit:
OK, got the tip to use "ip.src==192.168.0.24" as a filter and it showed me a lot of (red) UPD packets.
I deleted the app from my iPhone and installed the app again. Logged in and had to add the gateway and sensors again. So I did. But, it asked me to upgrade the firmware again (?). So I did. After I added the sensors, it showed me the sensors in Domoticz !!
I added them and they work fine.
But....still no gateway in the devices list. Could this be due to the password? Or is the password OK because I see the sensors?
If so, why can't I see the gateway itself in the devices list?
Sent from my Nexus 6P using Tapatalk
murtadin
About audio device. May be some libs are missing? Are there any dependencies on audio libs?
bertbigb
maybe a little bit of topic but I'm going to ask:
A few days ago while looking for the Xiaomi door sensor I came to a page where someone has find out which pins are connected and how you can connect your existing doorbell to the door sensor so you could see it in Domoticz also. I thought that I stored this webpage but obviously i didn't.
Does someone know what I mean or can help in another way? Would be appreciated.
Best regards Bert
Synology DS1517+ - DSM 6.2
- corbin
https://github.com/corbinmunce/domoticz is updated which should address some of the device problems
Coldman
Great job, thanks a lot!corbin wrote:alarm.PNG
aldodemi
- Domoticz version: 3.8275
I'm sorry but I not able to compile from source corbinmunce version.
what I do:
domo@domo:~$ cd domoticz
domo@domo:~/domoticz$ git remote -v
origin https://github.com/corbinmunce/domoticz.git (fetch)
origin https://github.com/corbinmunce/domoticz.git (push)
domo@domo:~/domoticz$ git status
Sul branch master
Your branch is up-to-date with 'origin/master'.
nothing to commit, working tree clean
domo@domo:~/domoticz$ git pull
Already up-to-date.
domo@domo:~/domoticz$ cmake -DCMAKE_BUILD_TYPE=Beta .
domo@domo:~/domoticz$ make -j 4
domo@domo:~/domoticz$ ./domoticz
2017-04-04 14:16:28.135 Domoticz V3.7150 (c)2012-2017 GizMoCuz
2017-04-04 14:16:28.135 Build Hash: 21fc8a1, Date: 2017-04-04 13:07:41
2017-04-04 14:16:28.136 Startup Path: /home/domo/domoticz/
What is wrong?
Thanks in advance.
Resolved: when connected via web, domoticz says there is an update, updated via web and found all new devices.
thank to @Corbin for the great work!!!
what I do:
Sul branch master
Already up-to-date.
What is wrong?
Thanks in advance.
Server Domoticz 3.7243 (usually the last beta) on Debian Linux (Jessie) - Hw homemade with Atom CPU/4 GB RAM
RFXCom and ZWave Stick (Aeon)
murtadin
Dear Corbin - thank you again for your work. How can i get these 3 devices? After last update only Xiaomi Gateway Audio detected.corbin wrote:alarm.PNG
P.S. Alarm Clock And Door Bell Detected.
Coldman
Mr. Corbin,
Great job!
Thanks a lot
Great job!
2017-04-04 17:47:53.697 (xGW) Light/Switch (Xiaomi Smart Wall Plug)
2017-04-04 17:47:53.702 {"cmd":"report","model":"86plug","sid":"158d0001575156","short_id":26606,"data":"{\"status\":\"off\"}"}
2017-04-04 17:47:57.074 (xGW) Light/Switch (Xiaomi Smart Wall Plug)
2017-04-04 17:47:57.079 {"cmd":"report","model":"86plug","sid":"158d0001575156","short_id":26606,"data":"{\"status\":\"on\"}"}Who is online
