robgeerts
- Domoticz version: 3.7067
Re: New Dashboard Design
Ok, dont you want any confirmation when pressed that button?
Verstuurd vanaf mijn SM-G930F met Tapatalk
- HansieNL
Thx for the reply... Am I missing somethingrobgeerts wrote:Ok, dont you want any confirmation when pressed that button?
I thought it was only showing the setpoint value. It's not clear to me what it should do when I press it? Can you further explain please?
Blah blah blah
robgeerts
Setpoint is a temperature wich is set when pressed? Not the current temperature?
- HansieNL
The setpoint is the value (degrees) to set the thermostat to. Now it shows the actual value, but I don't have possibility to set to other temperature like in Domoticz. If that would be possible it would be greatrobgeerts wrote:Setpoint is a temperature wich is set when pressed? Not the current temperature?
Blah blah blah
robgeerts
Could you post the complete output of your domoticz? (Or at least every party wich has to do with Toon...
Ierlandfan
I figured I would use the traffic.js as template to show a camera.
The popup part works since that's a simple replace of the htmlpage it opens
For the camera part, I am not sure where to put in the img src. I think I have to substitute some part in the the "entryTemplate"
Or do I have to insert it in the part further above?
- HansieNL
No problem...robgeerts wrote:Could you post the complete output of your domoticz? (Or at least every party wich has to do with Toon...
"ActTime" : 1491237688,
"ServerTime" : "2017-04-03 18:41:28",
"Sunrise" : "07:14",
"Sunset" : "20:17",
"result" : [
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 255,
"CustomImage" : 0,
"Data" : "20.2 C",
"Description" : "",
"Favorite" : 1,
"HardwareID" : 7,
"HardwareName" : "Toon Thermostaat",
"HardwareType" : "Toon Thermostat",
"HardwareTypeVal" : 34,
"HaveTimeout" : false,
"ID" : "0001",
"LastUpdate" : "2017-04-03 18:40:43",
"Name" : "Kamertemperatuur",
"Notifications" : "false",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"Protected" : false,
"ShowNotifications" : true,
"SignalLevel" : "-",
"SubType" : "LaCrosse TX3",
"Temp" : 20.199999999999999,
"Timers" : "false",
"Type" : "Temp",
"TypeImg" : "temperature",
"Unit" : 1,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "36"
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"CustomImage" : 0,
"Data" : "12.0",
"Description" : "",
"Favorite" : 1,
"HardwareID" : 7,
"ID" : "0000001",
"Name" : "Thermostaatinstelling",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"SetPoint" : "12.0",
"SubType" : "SetPoint",
"Timers" : "false",
"Type" : "Thermostat",
"TypeImg" : "override_mini",
"Unit" : 0,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "35"
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"CustomImage" : 0,
"Data" : "Off",
"Description" : "",
"Favorite" : 0,
"HardwareID" : 7,
"HaveDimmer" : true,
"HaveGroupCmd" : true,
"ID" : "0000071",
"Image" : "Light",
"IsSubDevice" : false,
"LastUpdate" : "2017-04-03 18:35:42",
"Level" : 0,
"LevelInt" : 0,
"MaxDimLevel" : 15,
"Name" : "HeatingOn",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"Status" : "Off",
"StrParam1" : "",
"StrParam2" : "",
"SubType" : "AC",
"SwitchType" : "On/Off",
"SwitchTypeVal" : 0,
"Timers" : "false",
"Type" : "Lighting 2",
"TypeImg" : "lightbulb",
"Unit" : 1,
"Used" : 0,
"UsedByCamera" : false,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "278"
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"CustomImage" : 0,
"Data" : "Off",
"Description" : "",
"Favorite" : 0,
"HardwareID" : 7,
"ID" : "0000072",
"Image" : "Light",
"Level" : 0,
"LevelInt" : 0,
"MaxDimLevel" : 15,
"Name" : "TapwaterOn",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"Status" : "Off",
"StrParam1" : "",
"StrParam2" : "",
"SubType" : "AC",
"Timers" : "false",
"Unit" : 1,
"Used" : 0,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "279"
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"CustomImage" : 0,
"Data" : "Off",
"Description" : "",
"Favorite" : 0,
"HardwareID" : 7,
"ID" : "0000073",
"Image" : "Light",
"Level" : 0,
"LevelInt" : 0,
"MaxDimLevel" : 15,
"Name" : "PreheatOn",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"Status" : "Off",
"StrParam1" : "",
"StrParam2" : "",
"SubType" : "AC",
"Timers" : "false",
"Unit" : 1,
"Used" : 0,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "280"
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"Counter" : "3129.388",
"CounterDeliv" : "0.000",
"CounterDelivToday" : "0.000 kWh",
"CounterToday" : "0.014 kWh",
"CustomImage" : 0,
"Data" : "1934116;1195272;0;0;157;0",
"Description" : "",
"Favorite" : 0,
"HardwareID" : 7,
"ID" : "1",
"Name" : "Unknown",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"SubType" : "Energy",
"Timers" : "false",
"Type" : "P1 Smart Meter",
"TypeImg" : "counter",
"Unit" : 1,
"Usage" : "157 Watt",
"UsageDeliv" : "0 Watt",
"Used" : 0,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "281"
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"Counter" : "844.029",
"CounterToday" : "0.000 m3",
"CustomImage" : 0,
"Data" : "844.029",
"Description" : "",
"Favorite" : 0,
"HardwareID" : 7,
"ID" : "1",
"Name" : "Unknown",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"SubType" : "Gas",
"SwitchTypeVal" : 1,
"Timers" : "false",
"Unit" : 2,
"Used" : 0,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "282"
"status" : "OK",
"title" : "Devices"
Blah blah blah
robgeerts
Ok, will look into this asap!
- EdwinK
- Domoticz version: BETA
Great. Looking forward to it.
- Dynamic
- Target OS: -
Your dashboard is really awesome! Today I mounted an iPad to the wall to show all those cool things.
I have some devices that I would like to add (like the usage of my 'city heating' ). Here is the JSON-output:
Cityheating:
Temperature sensors:
And what is the easiest way to add a shortcut to Domoticz in the dashboard?
I'm also not able to switch scenes (I don't use groups). I mentioned that before:
Cityheating:
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"Counter" : "385.790 m3",
"CounterToday" : "0.040 m3",
"CustomImage" : 0,
"Data" : "385.790 m3",
"Description" : "",
"Favorite" : 0,
"HardwareID" : 2,
"HardwareName" : "Dummy",
"HardwareType" : "Dummy (Does nothing, use for virtual switches only)",
"HardwareTypeVal" : 15,
"ID" : "1421E",
"LastUpdate" : "2017-04-03 19:40:09",
"Name" : "Stadsverw. energie",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"SubType" : "RFXMeter counter",
"Timers" : "false",
"Type" : "RFXMeter",
"Unit" : 1,
"Used" : 1,
"ValueQuantity" : "",
"ValueUnits" : "",
"XOffset" : "0",
"YOffset" : "0",
"idx" : "463"
},Code: Select all
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"CustomImage" : 0,
"Data" : "75.1 C",
"Description" : "",
"Favorite" : 0,
"HardwareID" : 2,
"ID" : "1426A",
"LastUpdate" : "2017-04-03 19:40:08",
"Name" : "Stadverwarming temperatuur in",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"SubType" : "THR128/138, THC138",
"Temp" : 75.129999999999995,
"Timers" : "false",
"Type" : "Temp",
"Unit" : 1,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "539"
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"CustomImage" : 0,
"Data" : "74.7 C",
"Description" : "",
"Favorite" : 0,
"HardwareID" : 2,
"ID" : "1426B",
"Name" : "Stadsverwarming temperatuur uit",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"Temp" : 74.730000000000004,
"Timers" : "false",
"Type" : "Temp",
"Unit" : 1,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "540"
},I'm also not able to switch scenes (I don't use groups). I mentioned that before:
I will buy you a beer!Dynamic wrote:How can I activate a scene? My 'favorite' scenes are visible, but when I click them, nothing happens. Or is it designed for groups only?
Edit: I found something. When you activate a scene/group, it does:
/json.htm?type=command¶m=switchlight&idx=1&switchcmd=On&level=0&passcode=
But it should be:
/json.htm?type=command¶m=switchscene&idx=1&switchcmd=On&passcode=
How can I fix this?
Edit 2: got it. In main.js you have to change this line:
else if(data.result[r]['Type']=='Group'){
info:
else if(data.result[r]['Type']=='Scene'){
- rsz_img_0861.jpg (105.57 KiB) Viewed 2290 times
- HansieNL
Take your time...robgeerts wrote:Ok, will look into this asap!
Blah blah blah
- Dynamic
- Target OS: -
A very cheap wall mount, just 13,99 euro!HansieNL wrote:@Dynamic:
What did you use to fix it to the wall?
https://go.bol.com/p/9000000012512507
- EdwinK
Looking good. No iPad here. Just some smallish Galaxy TabsDynamic wrote:Your dashboard is really awesome! Today I mounted an iPad to the wall to show all those cool things.
Ierlandfan
Little moren expensive, same idea
(Dual mount point included (E.g livingroom and kitchen/other place)
https://www.bol.com/nl/p/vogel-s-ringo- ... 0027956279
robgeerts
You dont need the entryTemplate part..Ierlandfan wrote:I figured I would use the traffic.js as template to show a camera.
Whats the JSON-output of your camera? This way I can test with it...
Will look into it asap!
Thanks!Dynamic wrote:Your dashboard is really awesome! Today I mounted an iPad to the wall to show all those cool things.
Added in the lastest version in Gitlab!Dynamic wrote: I have some devices that I would like to add (like the usage of my 'city heating' ). Here is the JSON-output:
Cityheating:Temperature sensors:Code: Select all
{ "AddjMulti" : 1.0, "AddjMulti2" : 1.0, "AddjValue" : 0.0, "AddjValue2" : 0.0, "BatteryLevel" : 255, "Counter" : "385.790 m3", "CounterToday" : "0.040 m3", ------ "idx" : "463" },Code: Select all
{ "AddjMulti" : 1.0, "AddjMulti2" : 1.0, "AddjValue" : 0.0, ------ "idx" : "539" }, { "AddjMulti" : 1.0, "AddjMulti2" : 1.0, ------- "Used" : 1, "XOffset" : "0", "YOffset" : "0", "idx" : "540" },
Try, in CONFIG.js:Dynamic wrote: And what is the easiest way to add a shortcut to Domoticz in the dashboard?
var buttons = {}
buttons.radio = {image: 'img/radio_on.png', title: 'Radio', url: 'http://nederland.fm'}
buttons.nunl = {icon: 'fa-newspaper-o', title: 'Nu.nl', url: 'http://www.nu.nl'}
buttons.radar = {icon: 'fa-cloud', title: 'Radar', url: 'http://www.weer.nl/verwachting/nederland/son/189656/'}
buttons.nzbget = {icon: 'fa-download', title: 'NZBget', url: 'http://192.168.1.3:6789'}
Thanks, fixed in latest version!Dynamic wrote: I'm also not able to switch scenes (I don't use groups). I mentioned that before:Dynamic wrote:How can I activate a scene? My 'favorite' scenes are visible, but when I click them, nothing happens. Or is it designed for groups only?
But it should be:
How can I fix this?
info:
Could you test this?
Thanks!Dynamic wrote: I will buy you a beer!
Could you test with the latest version if the setpoint-buttons are working?EdKo66 wrote:Great. Looking forward to it.
WARNING, TRAFFIC AND NS-INFO ARE NOT WORKING CORRECTLY IN LATEST VERSION.
PLEASE SET, TEMPORARILY TO FALSE IN CONFIG.JS
WILL FIX THIS ASAP!
Ierlandfan
Simple and static version is http:/IP:some_port/someimage
(we can also use this for buienradar)
Somewhat complicated version is :
<embed src="swfs/StrobeMediaPlayback.swf" width="960" height="540" quality="high" bgcolor="#000000" name="StrobeMediaPlayback" allowfullscreen="true" pluginspage="http://www.adobe.com/go/getflashplayer" flashvars="&src=rtmp://ip:some-port/flash/11:username:some-password&autoHideControlBar=true&streamType=live&autoPlay=true" type="application/x-shockwave-flash">
Height and width are only important for the pop-up part.
ddahya
Great Dashboard, keep up the good work.
i've downloaded the latest version and most of my devices are working, any chance of adding blind support to the dashboard?
The blinds are showing up as on/off devices but should be On/Off/Stop, also i have some dummy setpoint devices i use to control my neohub Thermostats that are also on/off devices.
json output for rflink blinds and Setpoint device
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"CustomImage" : 0,
"Data" : "Open",
"Description" : "",
"Favorite" : 1,
"HardwareID" : 9,
"HardwareName" : "RFLink",
"HardwareType" : "RFLink Gateway USB",
"HardwareTypeVal" : 46,
"HaveDimmer" : false,
"HaveGroupCmd" : false,
"ID" : "244CC400",
"Image" : "Light",
"LastUpdate" : "2017-04-04 06:45:10",
"Level" : 99,
"LevelInt" : 99,
"MaxDimLevel" : 100,
"Name" : "Living Room Blind 1",
"PlanID" : "6",
"PlanIDs" : [ 6, 10 ],
"Status" : "Open",
"StrParam1" : "",
"StrParam2" : "",
"SubType" : "Dooya",
"SwitchType" : "Venetian Blinds EU",
"SwitchTypeVal" : 15,
"Timers" : "false",
"Type" : "Light/Switch",
"TypeImg" : "blinds",
"Unit" : 1,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "86"
},Code: Select all
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"CustomImage" : 0,
"Data" : "12.0",
"Description" : "",
"Favorite" : 1,
"HardwareID" : 5,
"HardwareName" : "Neohub",
"ID" : "00140B7",
"LastUpdate" : "2017-04-04 11:48:04",
"Name" : "Bathroom",
"PlanID" : "9",
"PlanIDs" : [ 9, 10 ],
"SetPoint" : "18.0",
"Timers" : "false",
"Unit" : 1,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "104"
}- HansieNL
I've tested the Toon Thermostat setpoint, but don't see anything happenrobgeerts wrote:Could you test with the latest version if the setpoint-buttons are working?EdKo66 wrote:Great. Looking forward to it.
I forgot to add a lamp item with the Toon thermostat data
@EdKo66: have you tested latest version?
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"CustomImage" : 0,
"Data" : "Off",
"Description" : "",
"Favorite" : 1,
"HardwareID" : 7,
"ID" : "0000010",
"Image" : "Light",
"LastUpdate" : "2017-04-04 03:14:40",
"Level" : 0,
"LevelInt" : 0,
"MaxDimLevel" : 15,
"Name" : "Schemerlamp",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"Status" : "Off",
"StrParam1" : "",
"StrParam2" : "",
"SubType" : "AC",
"Timers" : "false",
"Unit" : 1,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "168"
Blah blah blah
lassiko
Firstly, dashboard looks great, and as others, i am planning to set it for my tablet on a living room wall.
I have few devices that i could not get working, not that familiar with modifying the code.. What i would like get is Energy: "Usage" and "CounterToday" to be visible on a dashboard from this device:
I also have several Temp + Humidity sensors that i would like use. I could not edit Temp + Humidity + Baro section for my needs, maybe some one can help to create a only Temp + Humidity? :
Thank you!
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"CounterToday" : "22.998 kWh",
"CustomImage" : 0,
"Data" : "11050.739 kWh",
"Description" : "",
"Favorite" : 1,
"HardwareID" : 17,
"HardwareName" : "MySensors Gateway",
"HardwareType" : "MySensors Gateway USB",
"HardwareTypeVal" : 41,
"ID" : "00000201",
"LastUpdate" : "2017-04-04 09:37:55",
"Name" : "kWh",
"Options" : "",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"SubType" : "kWh",
"Timers" : "false",
"Type" : "General",
"TypeImg" : "current",
"Unit" : 1,
"Usage" : "311.0 Watt",
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "100"Code: Select all
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 10.0,
"AddjValue2" : 0.0,
"CustomImage" : 0,
"Data" : "1.1 C, 89 %",
"Description" : "",
"DewPoint" : "-0.51",
"Favorite" : 1,
"HardwareID" : 14,
"HardwareName" : "Virtual",
"Humidity" : 89,
"HumidityStatus" : "Normal",
"ID" : "140F2",
"LastUpdate" : "2017-04-04 09:37:50",
"Name" : "Ulkolämpötila",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"SubType" : "THGN122/123, THGN132, THGR122/228/238/268",
"Temp" : 1.1000000000000001,
"Timers" : "false",
"Type" : "Temp + Humidity",
"Unit" : 1,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "162"Who is online
