Add "nalooptijd" in a lua script
Firemen112
I have a script for my floor heating pump. But the 'nalooptijd' of 10 min. are not in.
Can someone fix this? I have no experience with lua
script:
logging = true
function log (level, message)
file = io.open("/ram/domoticz.log", "a")
file:write(string.format("%s %-5s: LUA : %s\n", os.date("%m/%d/%Y %I:%M:%S %p"),level, message))
io.close(file)
AfterOff = 900
Vloer_Retour = 'Vloer_Retour'
Vloer_Aanvoer = 'Vloer_Aanvoer'
Pomp = 'Pomp'
PumpOn = tonumber(uservariables['PumpOn'])
-- if one of the sensor temps changed, do our thing
if ( devicechanged[Vloer_Retour] or devicechanged[Vloer_Aanvoer] ) then
time = os.time() -- Current time (integer sec)
dt_in = otherdevices[Vloer_Aanvoer] -- Get in temp
dt_out = otherdevices[Vloer_Retour] -- Get out temp
dt = dt_in - dt_out -- calculate diff
if (logging) then print("INFO",string.format("t_out %.2f t_in %.2f dt %.2f Pomp: %s OnTime: %d", dt_out, dt_in, dt, otherdevices[Pomp], time - PumpOn)) end
-- if temp difference > 1 degree celcius, immediatly tunr on Pump
if (dt > 1) then
-- update time we last turned "On" the pump
PumpOn = os.time()
if (otherdevices[Pomp] == "Off") then
commandArray[Pomp] = "On"
-- must me lower/equal 1 degree, see if minimum pump "On" time exeeded
if ( (os.time() - PumpOn) >= AfterOff ) then
if (otherdevices[Pomp] == "On") then
commandArray[Pomp] = "Off"
commandArray['Variable:PumpOn'] = tostring(PumpOn)
script:
logging = true
io.close(file)
AfterOff = 900
Pomp = 'Pomp'
if (dt > 1) then
PumpOn = os.time()
jannl
- Domoticz version: 2026.1.x
Re: Add "nalooptijd" in a lua script
Why not use something like Off AFTER?
Verstuurd vanaf mijn SM-G930F met Tapatalk
Firemen112
Sorry, I mean, if the pump is switched off for >24 hours, then the pump switch on 10 min.
- jvdz
- Domoticz version: 4.107
Something like this should work assuming some device will trigger it. I've also moved the updating of the variable inside the if or else it will update each time the script is ran.
Jos
logging = true
function log(level, message)
file:write(string.format("%s %-5s: LUA : %s\n", os.date("%m/%d/%Y %I:%M:%S %p"), level, message))
io.close(file)
-- Function to return the number of seconds the device was last changed
function datetimedifferencenow(s)
year = string.sub(s, 1, 4)
month = string.sub(s, 6, 7)
day = string.sub(s, 9, 10)
hour = string.sub(s, 12, 13)
t1 = os.time()
t2 = os.time{year = year, month = month, day = day, hour = hour, min = minutes, sec = seconds}
difference = os.difftime(t1, t2)
return difference
AfterOff = 900
Pomp = 'Pomp'
-- if pomp didn't change in the last 24 hours then activate for 10 minutes
if (datetimedifferencenow(Pomp) > 60*60*24) then
commandArray[Pomp] = "On for 10"
if (devicechanged[Vloer_Retour] or devicechanged[Vloer_Aanvoer]) then
if (logging) then print("INFO", string.format("t_out %.2f t_in %.2f dt %.2f Pomp: %s OnTime: %d", dt_out, dt_in, dt, otherdevices[Pomp], time - PumpOn)) end
if (dt > 1) then
PumpOn = os.time()
if ((os.time() - PumpOn) >= AfterOff) then
return commandArray-
Firemen112
Thanks!!, But now getting a error:
string "commandArray = {} ..."]:20: field 'day' missing in date table
Frank
Frank
- jvdz
Ah, I see indeed I made a mistake. It didn't retrieve the lastchanged date/time information for pomp.
I can't test the script myself
... so here is an update for you to test:
Jos
logging = true
io.close(file)
t1 = os.time()
return difference
AfterOff = 900
Pomp = 'Pomp'
if (datetimedifferencenow(otherdevices_lastupdate[Pomp]) > 60*60*24) then
if (dt > 1) then
PumpOn = os.time()
Firemen112
Works fine!! Thanks!
Frank
Frank
gerard76
- Domoticz version: 3.8153
What do you use to read the temperatures? I currently check my Nest to see if the heating is on, but I have to guess the extra time the pump needs to run.
