Add "nalooptijd" in a lua script
Firemen112
Post by Firemen112 »
I have a script for my floor heating pump. But the 'nalooptijd' of 10 min. are not in.
Can someone fix this? I have no experience with lua
script:
logging = true
function log (level, message)
file = io.open("/ram/domoticz.log", "a")
file:write(string.format("%s %-5s: LUA : %s\n", os.date("%m/%d/%Y %I:%M:%S %p"),level, message))
io.close(file)
AfterOff = 900
Vloer_Retour = 'Vloer_Retour'
Vloer_Aanvoer = 'Vloer_Aanvoer'
Pomp = 'Pomp'
PumpOn = tonumber(uservariables['PumpOn'])
-- if one of the sensor temps changed, do our thing
if ( devicechanged[Vloer_Retour] or devicechanged[Vloer_Aanvoer] ) then
time = os.time() -- Current time (integer sec)
dt_in = otherdevices[Vloer_Aanvoer] -- Get in temp
dt_out = otherdevices[Vloer_Retour] -- Get out temp
dt = dt_in - dt_out -- calculate diff
if (logging) then print("INFO",string.format("t_out %.2f t_in %.2f dt %.2f Pomp: %s OnTime: %d", dt_out, dt_in, dt, otherdevices[Pomp], time - PumpOn)) end
-- if temp difference > 1 degree celcius, immediatly tunr on Pump
if (dt > 1) then
-- update time we last turned "On" the pump
PumpOn = os.time()
if (otherdevices[Pomp] == "Off") then
commandArray[Pomp] = "On"
-- must me lower/equal 1 degree, see if minimum pump "On" time exeeded
if ( (os.time() - PumpOn) >= AfterOff ) then
if (otherdevices[Pomp] == "On") then
commandArray[Pomp] = "Off"
commandArray['Variable:PumpOn'] = tostring(PumpOn)
jannl
Domoticz version: 2022.2
Re: Add "nalooptijd" in a lua script
Post by jannl »
Why not use something like Off AFTER?
Verstuurd vanaf mijn SM-G930F met Tapatalk
Firemen112
Sorry, I mean, if the pump is switched off for >24 hours, then the pump switch on 10 min.
jvdz
Domoticz version: 4.107
Post by jvdz »
Something like this should work assuming some device will trigger it. I've also moved the updating of the variable inside the if or else it will update each time the script is ran.
logging = true
function log(level, message)
	file:write(string.format("%s %-5s: LUA : %s\n", os.date("%m/%d/%Y %I:%M:%S %p"), level, message))
	io.close(file)
-- Function to return the number of seconds the device was last changed
function datetimedifferencenow(s)
	year = string.sub(s, 1, 4)
	month = string.sub(s, 6, 7)
	day = string.sub(s, 9, 10)
	hour = string.sub(s, 12, 13)
	t1 = os.time()
	t2 = os.time{year = year, month = month, day = day, hour = hour, min = minutes, sec = seconds}
	difference = os.difftime(t1, t2)
	return difference
AfterOff = 900
Pomp = 'Pomp'
-- if pomp didn't change in the last 24 hours then activate for 10 minutes
if (datetimedifferencenow(Pomp) > 60*60*24) then
	commandArray[Pomp] = "On for 10"
if (devicechanged[Vloer_Retour] or devicechanged[Vloer_Aanvoer]) then
	if (logging) then print("INFO", string.format("t_out %.2f t_in %.2f dt %.2f Pomp: %s OnTime: %d", dt_out, dt_in, dt, otherdevices[Pomp], time - PumpOn)) end
	if (dt > 1) then
		PumpOn = os.time()
		if ((os.time() - PumpOn) >= AfterOff) then
Jos
Firemen112
Thanks!!, But now getting a error:
string "commandArray = {} ..."]:20: field 'day' missing in date table
Frank
jvdz
Post by jvdz »
Ah, I see indeed I made a mistake. It didn't retrieve the lastchanged date/time information for pomp.
I can't test the script myself :roll: ... so here is an update for you to test:
logging = true
	io.close(file)
	t1 = os.time()
	return difference
AfterOff = 900
Pomp = 'Pomp'
if (datetimedifferencenow(otherdevices_lastupdate[Pomp]) > 60*60*24) then
	if (dt > 1) then
		PumpOn = os.time()
Jos
Firemen112
Works fine!! Thanks! :)
Frank
gerard76
Domoticz version: 3.8153
Post by gerard76 »
What do you use to read the temperatures? I currently check my Nest to see if the heating is on, but I have to guess the extra time the pump needs to run.
