Improve 433Mhz reliability Topic is solved
gerard76
Domoticz version: 3.8153
Post by gerard76 »
I created this script to improve the reliability of my 433Mhz devices. I hate it when Domoticz thinks something is on, while the receiver never got the signal. Whenever a device changes the script sends the same command another 2 times to make sure the receiver gets it. Because the RFXcom also picks up the signal from my remote, those signals are also multiplied and the reliability improved.
You need to create integer uservariables with the same name as your devices, they are used to prevent getting stuck in a loop.
my_devices = {"Lamp in hoek", "Lamp naast bank", "Lamp naast tv", "Lamp naast kachel", "Lamp bij trap", "TV" }
-- loop through the changed devices
for device_name, device_value in pairs(devicechanged) do
    for i, my_device in pairs(my_devices) do
        if device_name == my_device then
            if device_value == "On" and uservariables[device_name] == 0 then
                commandArray['Variable:' .. device_name] = "1"
                commandArray[0]={[device_name]='On'} -- send signal again
                commandArray[1]={[device_name]='On'} -- and again..
            elseif device_value == "Off" and uservariables[device_name] == 1 then
                commandArray['Variable:' .. device_name] = "0"
                commandArray[0]={[device_name]='Off'} -- send signal again
                commandArray[1]={[device_name]='Off'} -- and again..
lvsigo
Re: Improve 433Mhz reliability
Post by lvsigo »
Don't lets us manualy create devices...
Do it in the script
http://easydomoticz.com/forum/viewtopic ... ilit=Twice
K3rryBlue
Domoticz version: V4.10xx
Post by K3rryBlue »
Be carefull, as this will not work well with dimmers.
Sending the on command twice will cause the mayority of dimmers to start the auto dim sequence.
Better sending:
Domoticz V4.10717, RPi2 -> Linux raspberrypi 4.4.47-v7+ , RFXCOM - RFXtrx433 USB 433.92MHz ,RAZBERRY2 and OpenZWave USB Version: 1.4-2363-g1f10253-dirty
zak45
Domoticz version: V2024.4
Post by zak45 »
Siewert308SW
Domoticz version: Stable
Post by Siewert308SW »
Really, using Domo since 2015 and never knew the repeat command.
To be honest... As i searched the chagelog, i think a lot of those added features aren't mentioned in the chagelog and there for unknown to all users.
Setup:
- DS923+ Docker
Domoticz Latest Stable
Mosquitto / ZwaveJSUI @ Aeotec Z-Stick Gen5+ / PiHole Unbound
P1 USB Gas/Power, HW watermeter
- A lot of Zwave switches, contacts, plugs, smoke/Co2 ect
- DiY 7.5kWh Solar Storage @ GitHuB
gerard76
Post by gerard76 »
Nice. Hadn't seen that in the docs. Much cleaner. I changed the user variables to strings containing 'On' and 'Off'. Also saves a few lines of code.
    for i, device in pairs(my_devices) do
        if device_name == device then
            if uservariables[device_name] ~= device_value then
                commandArray['Variable:' .. device_name] = device_value
                commandArray[device_name] = device_value .. ' REPEAT 2 INTERVAL 1'
Mediacj
Post by Mediacj »
Thanks for sharing it works great!
Derik
Post by Derik »
mmm
Scripting is not my thing.. [ to stupid to understand all this epxert stuff. ]
Only will give sometimes the scripts that i think they are usefull a try..
Also like this one..
Have some devices in the grey places of the RFXcom ...
And i will send them 2 or 3 times a 433 command.
Only how is this script activeted? [ crontab? ]
Where to place?
Is there a time setting? [ each minute or? ]
Can i send more then 2 times??
Working for on and off?
gerard76
Post by gerard76 »
You put it in Domoticz under Setup - More options - Events. Set the pull downs to 'Lua' and the other to 'Device', check the 'activate' mark. Paste the script and change the names to your on/off 433 devices.
You can send more than 2 times, change the 'repeat 2' to 3 or whatever. Remember that 2 means 2 extra times, so 3 total. You have the original signal and then the 2 repeats. I have 5 switchable lights +TV in my living room and the more I repeated the signal the longer it took to turn them all on at once. So pick the lowest number that works for you.
Derik
Post by Derik »
Ok will give it a try...
Is the last script in this thread for on and of?
The first script they are separated?
gerard76
Post by gerard76 »
Yes, On and Off.
Do not forget to create the user variables with the same name as your devices under Setup - More Options - User Variables with type string.
Derik
Post by Derik »
gerard76 wrote:Do not forget to create the user variables with the same name as your devices under Setup - More Options - User Variables with type string.
This part i do not understand,
Please a screendump of the settings :roll:
gerard76
Post by gerard76 »
user variables example
Screen Shot 2017-04-02 at 21.53.09.png (54.57 KiB) Viewed 5264 times
Derik
Post by Derik »
mm
Sorry for my dombo questions..
Only why 1 device on and the other off?
DaWauZ
Post by DaWauZ »
I dont understand this exactly.
First, I do not have any problems with my rfxcom (-e type) switching things on and off.
Sometimes, I using a remote to put the lights off, and yes, domoticz thinks device is on, but what should this script helps about that?
Is the script triggered by the remote signal, how?
Raspberry Pi 2 model B with domoticz
OMV NAS installed on thin client HP T610
Openelec Kodi Mediaplayer on thin client HP T520 (and with multiboot windows 10)
gerard76
Post by gerard76 »
@derik that is just the current state of my lights
@DaWauZ this script helps when domoticz sees the signal from the remote, but the lights do not or if you send signals from domoticz. For example if you have a scene to turn on all lights, but sometimes 1 light will not turn on because it missed the signal.This script fixes that.
In your case I would suggest bringing the RFXcom closer to where you use the remote.
DaWauZ
Post by DaWauZ »
The only problem with my remote, is not the distance but a kaku hotel switching. I using 2 senders behind wall switch, and also domoticz to put that light automatically on. I also have a hand remote for that same light.
I think I used the remote signal for domoticz, but not the 2 of the wall switches.
Derik
Post by Derik »
Did set a string..
Only what do i need to fill in by value:
gerard76
Post by gerard76 »
Doesn't really matter. The program will fill it out after the first time you switch.
Derik
Post by Derik »
mm
Got an error:
2017-04-03 19:48:00.876 Error: EventSystem: in Lua: Extra Schakeling Aan: [string "commandArray = {}..."]:5: bad argument #1 to 'pairs' (table expected, got nil)
This is my setting:
And:
Looks there is something wrong
