Python Plugin: Broadlink RM2
- StanHD
Re: Python Plugin: Broadlink RM2
Hi, I am trying to install the plugin:
Platform: Windows 7
Domoticz: V3.6694
Install fails with these last lines in the cmd window:-
Skipping implicit fixer: buffer
Skipping implicit fixer: idioms
Skipping implicit fixer: set_literal
Skipping implicit fixer: ws_comma
running build_ext
building 'Crypto.Random.OSRNG.winrandom' extension
warning: GMP or MPIR library not found; Not building Crypto.PublicKey._fastmath.
error: Microsoft Visual C++ 10.0 is required (Unable to find vcvarsall.bat).
Command "C:\Python34\python.exe -c "import setuptools, tokenize;__file__='C:
\\Users\\Stan\\AppData\\Local\\Temp\\pip-build-191ilrgk\\pycrypto\\setup.py';exe
c(compile(getattr(tokenize, 'open', open)(__file__).read().replace('\r\n', '\n')
, __file__, 'exec'))" install --record C:\Users\Stan\AppData\Local\Temp\pip-_t_l
4d3g-record\install-record.txt --single-version-externally-managed --compile" fa
iled with error code 1 in C:\Users\Stan\AppData\Local\Temp\pip-build-191ilrgk\py
crypto
"ERROR: broadlink installation error"
Press any key to continue . . .
I have installed Microsoft Visual C++ 10, but the same error occurs.
Any ideas?
Thanks.
Platform: Windows 7
Domoticz: V3.6694
running build_ext
crypto
Any ideas?
Thanks.
Python:- Broadlink RM2, Sonos
zak45
- Domoticz version: V2024.4
Do you have run it as "Administrator" ??
- StanHD
Re: RE: Re: Python Plugin: Broadlink RM2
Yes, I have tried both normal and as administrator.zak45 wrote:Do you have run it as "Administrator" ??
zak45
StanHD wrote:Hi, I am trying to install the plugin:
Platform: Windows 7
Domoticz: V3.6694
running build_ext
crypto
Any ideas?
Thanks.
looks like you're using python 3.4.. all tests has been done on 3.5.
the pycrypto-2.6.1-cp35-none-win32.whl show me that crypto available only for 3.5 in windows.
if you want to use this plugin, plan to go to 3.5.3, the one I have tested.
zak45
deennoo wrote:I'm facing an issue when trying to record an IR code
My configCode: Select all
2017-03-28 20:45:47.331 User: Admin initiated a switch command (3379/Broadlink - Command/Set Level) 2017-03-28 20:45:47.364 (Broadlink) Calling message handler 'onCommand'. 2017-03-28 20:45:47.364 (Broadlink) onCommand called for Unit 1: Parameter 'Set Level', Level: 10 , Connected : True 2017-03-28 20:45:47.394 (Broadlink) Connected to Broadlink device. 2017-03-28 20:45:47.394 (Broadlink) All plugin system is on pause for 5s... 2017-03-28 20:45:47.394 (Broadlink) When Broadlink led is lit press the button on your remote within 5 seconds 2017-03-28 20:45:52.781 (Broadlink) b'&\x00\x84\x03\x11/\x13/\x12/\x13/\x11\x10\x11\x10\x11\x0f\x12/\x12\x00\x07[\x96\x91\x12\x0f\x11\x10\x11\x0f\x12\x0f\x110\x12/\x13\x0f\x10\x10\x11/\x13/\x12/\x120\x12\x0e\x12\x0f\x12\x0f\x12\x0e\x12\x92\x12\x0f\x11\x10\x11\x10\x11\x0f\x11\x10\x11\x10\x11\x0f\x11\x0f\x12/\x120\x12/\x12\x0f\x110\x12/\x110\x12/\x12\x10\x11\x0f\x12\x0f\x110\x12\x00\x07[\x96\x90\x13\x0f\x11\x0f\x12\x0f\x11\x10\x110\x12/\x12\x0f\x12\x0f\x110\x12/\x110\x12/\x13\x0f\x11\x0f\x12\x0f\x11\x0f\x12\x92\x12\x0f\x11\x10\x11\x0f\x12\x0f\x11\x0f\x12\x0f\x12\x0f\x11\x0f\x120\x11/\x120\x12\x0e\x120\x12/\x120\x110\x11\x0f\x12\x0f\x11\x10\x110\x12\x00\x07\\\x95\x91\x12\x0f\x12\x0f\x11\x10\x11\x0f\x11/\x120\x12\x0f\x11\x10\x110\x12/\x12/\x13.\x12\x0f\x12\x0f\x11\x10\x11\x0f\x12\x91\x13\x0f\x11\x0f\x12\x0f\x11\x10\x11\x10\x11\x0f\x11\x10\x11\x10\x11/\x120\x12.\x12\x0f\x12/\x13/\x12/\x120\x12\x0f\x11\x10\x11\x0f\x12.\x13\x00\x07[\x96\x91\x12\x0f\x11\x0f\x12\x0f\x12\x0f\x110\x12/\x12\x0f\x11\x10\x11/\x120\x12/\x120\x11\x10\x11\x0f\x12\x0f\x11\x10\x11\x92\x12\x0f\x11\x10\x11\x0e\x12\x0f\x12\x0f\x11\x10\x11\x10\x11\x0f\x12/\x120\x12/\x12\x0f\x12/\x12/\x12/\x12/\x13\x0f\x11\x0f\x12\x0f\x110\x12\x00\x07\\\x95\x90\x13\x0e\x12\x10\x11\x0f\x12\x0f\x110\x12/\x12\x10\x11\x0f\x11/\x120\x110\x12/\x13\x0f\x11\x0f\x12\x0f\x11\x10\x11\x92\x12\x0f\x11\x10\x11\x0f\x12\x0f\x11\x0f\x12\x10\x10\x10\x11\x0f\x110\x12/\x120\x12\x0f\x110\x12/\x120\x11/\x12\x10\x11\x0f\x11\x10\x110\x12\x00\x07\\\x94\x92\x12\x0f\x11\x0f\x12\x0f\x11\x10\x110\x12/\x12\x0f\x12\x0e\x120\x12/\x110\x12/\x12\x0f\x12\x0f\x11\x10\x11\x10\x11\x91\x12\x0f\x12\x0f\x12\x0f\x11\x10\x11\x10\x11\x0f\x12\x0f\x11\x10\x11/\x12/\x12/\x13\x0f\x110\x110\x12/\x13/\x12\x0f\x11\x10\x11\x0f\x110\x11\x00\x07]\x94\x92\x12\x0f\x11\x10\x11\x10\x11\x0f\x11/\x13/\x12\x0f\x11\x10\x11/\x13/\x12/\x120\x11\x10\x11\x0f\x11\x10\x11\x0f\x12\x91\x12\x0f\x12\x0f\x11\x10\x11\x0f\x12\x0f\x12\x0f\x11\x10\x11\x0f\x12/\x13/\x12/\x11\x10\x11/\x120\x12/\x120\x12\x0e\x12\x10\x11\x0f\x12/\x11\x00\x07\\\x95\x92\x12\x0e\x12\x0f\x12\x0f\x12\x0f\x110\x12/\x12\x0f\x11\x0f\x12/\x120\x12/\x12/\x13\x0f\x11\x0f\x12\x0f\x11\x10\x11\x92\x12\x0f\x11\x10\x11\x0f\x11\x10\x11\x0f\x11\x10\x11\x0f\x12\x0f\x110\x12/\x13/\x12\x0f\x110\x12/\x12/\x12/\x13\x0f\x11\x0f\x12\x0f\x110\x12\x00\x07\\\x95\x90\x12\x0f\x12\x0f\x12\x0f\x11\x10\x110\x12/\x12\x0f\x12\x0f\x110\x11/\x13/\x12/\x12\x10\x11\x0f\x11\x10\x11\x10\x11\x92\x12\x0e\x12\x0f\x12\x0f\x12\x0f\x11\x10\x11\x0f\x12\x0f\x11\x10\x11/\x12/\x120\x12\x0f\x110\x12/\x120\x100\x12\x0f\x12\x0f\x11\x10\x110\x12\x00\x07\\\x95\x91\x12\x0f\x11\x10\x11\x10\x11\x0f\x11/\x13/\x12\x0f\x11\x0f\x120\x12/\x12/\x110\x12\x0f\x12\x0f\x11\x10\x11\x0f\x12\x91\x12\x0f\x12\x0f\x12\x0f\x11\x0f\x12\x0f\x12\x0f\x11\x10\x11\x10\x11/\x13/\x11/\x13\x0f\x11/\x13/\x12/\x120\x12\x0f\x11\x10\x11\x0f\x11/\x12\x00\x07\\\x96\x91\x12\x0f\x11\x10\x11\x0f\x12\x0f\x110\x11/\x13\x0e\x12\x0f\x12/\x120\x12/\x13/\x12\x0f\x11\x10\x10\x10\x11\x0f\x11\x93\x11\x10\x11\x0f\x11\x10\x11\x0f\x12\x0f\x11\x10\x11\x10\x11\x0f\x12/\x120\x110\x12\x0f\x12.\x120\x12/\x12/\x13\x0f\x11\x0f\x12\x0f\x110\x12\x00\r\x05\x00\x00\x00\x00' 2017-03-28 20:45:52.781 Error: (Broadlink) 'onCommand' failed 'AttributeError':''bytes' object has no attribute 'hex''. 2017-03-28 20:45:52.781 Error: (Broadlink) ----> Line 117 in /home/nico/domoticz/plugins/Broadlink/plugin.py, function onCommand 2017-03-28 20:45:52.781 Error: (Broadlink) ----> Line 339 in /home/nico/domoticz/plugins/Broadlink/plugin.py, function learn 2017-03-28 20:45:54.556 User: Admin initiated a switch command (3379/Broadlink - Command/Set Level) 2017-03-28 20:45:54.585 (Broadlink) Calling message handler 'onCommand'. 2017-03-28 20:45:54.585 (Broadlink) onCommand called for Unit 1: Parameter 'Set Level', Level: 10 , Connected : True 2017-03-28 20:45:54.615 (Broadlink) Connected to Broadlink device. 2017-03-28 20:45:54.615 (Broadlink) All plugin system is on pause for 5s... 2017-03-28 20:45:54.615 (Broadlink) When Broadlink led is lit press the button on your remote within 5 secondes 2017-03-28 20:45:59.855 (Broadlink) b'&\x00\xe0\x01\x95\x91\x13\x0e\x12\x0f\x10\x11\x10\x11\x101\x13-\x13\x0f\x10\x10\x110\x110\x13/\x13.\x13\x0e\x12\x0f\x10\x10\x12\x10\x11\x92\x11\x10\x11\x10\x11\x0f\x0e\x12\x10\x11\x10\x11\x10\x10\x10\x10\x120\x110\x13/\x13\x0e\x101\x100\x120\x101\x13\x0e\x10\x11\x11\x0f\x120\x11\x00\x07\\\x96\x90\x12\x0f\x12\x0f\x11\x10\x10\x10\x110\x13/\x12\x0f\x11\x10\x100\x12/\x13/\x110\x12\x0f\x11\x10\x10\x11\x10\x10\x12\x91\x13\x0f\x10\x10\x11\x10\x11\x0f\x12\x0f\x12\x0f\x11\x10\x11\x0e\x120\x12/\x12/\x13\x0f\x110\x12/\x12.\x13/\x12\x0f\x11\x0f\x12\x10\x11/\x13\x00\x07[\x95\x92\x11\x0f\x12\x0e\x12\x10\x11\x0f\x110\x13/\x12\x0f\x11\x10\x11/\x13/\x11/\x13/\x12\x0f\x11\x10\x11\x0f\x12\x0f\x11\x92\x12\x0f\x12\x0f\x11\x10\x11\x10\x11\x0f\x11\x0f\x12\x0f\x12\x0f\x12/\x110\x12/\x13\x0e\x12/\x120\x12/\x12/\x12\x10\x11\x0e\x12\x0f\x12/\x12\x00\x07\\\x95\x92\x11\x0f\x12\x10\x11\x0f\x11\x10\x11/\x12/\x12\x10\x11\x0f\x12/\x13/\x12/\x12/\x11\x11\x11\x0f\x11\x0f\x11\x10\x11\x92\x12\x0f\x11\x10\x11\x10\x11\x0f\x12\x0f\x11\x10\x11\x0f\x12\x0f\x110\x12/\x13/\x11\x0f\x110\x12/\x13/\x12/\x12\x10\x11\x0f\x11\x0f\x120\x11\x00\x07\\\x95\x91\x13\x0f\x11\x0f\x12\x0f\x11\x10\x11/\x13/\x11\x10\x11\x0f\x110\x12/\x13/\x12/\x13\x0e\x12\x0f\x11\x10\x11\x10\x10\x92\x12\x10\x11\x0f\x12\x0f\x11\x10\x11\x0e\x12\x0f\x12\x0f\x11\x10\x110\x12/\x12/\x13\x0e\x120\x11/\x120\x110\x12\x0f\x12\x0f\x11\x10\x11/\x13\x00\x07\\\x94\x91\x12\x0f\x12\x0f\x11\x10\x11\x0f\x12/\x13/\x12\x0e\x12\x10\x11/\x12/\x12/\x13/\x12\x0f\x11\x10\x11\x10\x11\x0f\x11\x92\x12\x0f\x12\x0f\x11\x10\x11\x10\x11\x0f\x12\x0f\x11\x10\x11\x0f\x11/\x120\x12/\x13\x0e\x12/\x120\x12/\x110\x12\x0e\x12\x10\x11\x0f\x12/\x13\x00\r\x05\x101\x100\x120\x101' 2017-03-28 20:45:59.855 Error: (Broadlink) 'onCommand' failed 'AttributeError':''bytes' object has no attribute 'hex''. 2017-03-28 20:45:59.855 Error: (Broadlink) ----> Line 117 in /home/nico/domoticz/plugins/Broadlink/plugin.py, function onCommand 2017-03-28 20:45:59.855 Error: (Broadlink) ----> Line 339 in /home/nico/domoticz/plugins/Broadlink/plugin.py, function learn
Config is Ok, on plugin point of view...
Now I suspect your python version < 3.5.
Looks like .hex() alias is available only from this one.
Can you confirm your plugin version ?
and try this please :
py
>>import codecs
>>codecs.encode(b'\x12', 'hex_codec')
- StanHD
Thank you for your reply. I have installed python 3.5, but still also have 3.4 installed. Is that OK? I am worried about breaking the Sonos plug-in if I uninstall 3.4? I still get the same error.
deennoo
Python 3.4 here.zak45 wrote:deennoo wrote:I'm facing an issue when trying to record an IR code
py
>>import codecs
Where to put your order ?
http://domo-attitude.fr
zak45
For people that are not in python 3.5, lets try this version.
domoraspberryitaly
Will try!
zak45
lets try this :StanHD wrote:Thank you for your reply. I have installed python 3.5, but still also have 3.4 installed. Is that OK? I am worried about breaking the Sonos plug-in if I uninstall 3.4? I still get the same error.
https://github.com/axper/python3-pycryp ... -installer
- StanHD
Thanks, Installation was now successful, New hardware is available. I already new IP and MAC so filled these in, however getting this error in log:-zak45 wrote:lets try this :StanHD wrote:Thank you for your reply. I have installed python 3.5, but still also have 3.4 installed. Is that OK? I am worried about breaking the Sonos plug-in if I uninstall 3.4? I still get the same error.
2017-03-29 07:45:08.810 (Broadlink RM2) Initialized version 1.0.0, author 'zak45'
2017-03-29 07:45:08.811 Error: Expected: myVar = Domoticz.Device(Name="myDevice", Unit=0, TypeName="", Type=0, Subtype=0, Switchtype=0, Image=0, Options="")
2017-03-29 07:45:08.811 Error: (Broadlink RM2) 'CDevice_init' failed 'TypeError':'argument 8 must be str, not dict'.
2017-03-29 07:45:08.811 Error: Device creation failed, Device object is not associated with a plugin.
Stan
zak45
@StanHD
Domoticz version 3.70xx or > is required
deennoo
Ok it works for me !zak45 wrote:For people that are not in python 3.5, lets try this version.
plugin.zip
Learn : ok
Test : ok
Save : ok
Reset : ok
temp : ok
Debian 8.5 x64 + python 3.4 domoticz 3.7196
domoraspberryitaly
got it working with python3.4 with the new plugin.py, thank you! don't forget the
sudo cp -r /usr/local/lib/python3.4/dist-packages/Crypto/ /usr/lib/python3.4/
and
sudo cp -r /usr/local/lib/python3.4/dist-packages/broadlink /usr/lib/python3.4/
and
- StanHD
Doh!, sorry should have realised.zak45 wrote:@StanHD
Updated to latest Beta, on restart new "Command" switch is created and no errors.
So to sum-up:- Windows 7, Domoticz V3.7197, Python 3.4.3, Python 3.4 pycrypto-2.6.1 - Working.
Thank you very much for your support, and the plug-in, it is very much appreciated.
Stan
- StanHD
Sorry another problem when attempting to learn:-StanHD wrote:Doh!, sorry should have realised.zak45 wrote:@StanHD
Domoticz version 3.70xx or > is required![]()
Updated to latest Beta, on restart new "Command" switch is created and no errors.Can't do any more until I get home tonight.
Stan
2017-03-29 20:54:33.867 User: Admin initiated a switch command (1300/Broadlink RM2 - Command/Set Level)
2017-03-29 20:54:33.904 (Broadlink RM2) Calling message handler 'onCommand'.
2017-03-29 20:54:33.904 (Broadlink RM2) onCommand called for Unit 1: Parameter 'Set Level', Level: 10 , Connected : True
2017-03-29 20:54:33.935 (Broadlink RM2) Connected to Broadlink device.
2017-03-29 20:54:33.935 (Broadlink RM2) All plugin system is on pause for 5s...
2017-03-29 20:54:33.935 (Broadlink RM2) When Broadlink led is lit press the button on your remote within 5 seconds
2017-03-29 20:54:38.514 (1-Wire) Temp (Bedroom Flow Temp)
2017-03-29 20:54:39.448 (Broadlink RM2) b'&\x00<\x00Z\x1b\x11\x0c\x11\x0c\x11\x1a\x11\x1a \x0c\x11\x0c\x11\x0c\x11\x0c\x11\r\x10\r\x10\r\x10\r\x1f\x1b\x10\r\x10\r\x10\r\x10\r\x10\r\x1f\r\x11\x1a \x1a \x0c\x11\x1a\x11\x0c \x0c\x11\x1a\x11\r\x10\x00\r\x05\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00'
2017-03-29 20:54:39.448 Error: (Broadlink RM2) 'onCommand' failed 'AttributeError':''bytes' object has no attribute 'hex''.
2017-03-29 20:54:39.448 Error: (Broadlink RM2) ----> Line 117 in C:\Program Files (x86)\Domoticz\plugins\Broadlink\plugin.py, function onCommand
2017-03-29 20:54:39.448 Error: (Broadlink RM2) ----> Line 339 in C:\Program Files (x86)\Domoticz\plugins\Broadlink\plugin.py, function learn
Stan
zak45
@StandHD,
you 're in python 3.4 so just download plugin.zip (few post above) and replace plugin.py in your Broadlink directory.
- StanHD
Ah, thanks, learning is working perfectly.zak45 wrote:@StandHD,
Once again thank you for this excellent plug-in and patient support.
Stan
markjgabb
- Domoticz version: 3.8153
hmmm...ive run your setup.exe but no new folders or files are created...dont see a log file anywhere obvious
ive also got the .py script but not sure where to put it when i cant find the folder
server 2012
domtoicz 3.6653
server 2012
domtoicz 3.6653
V 2020.2 RPI 3
RFlink 334 mhz
mysensors
broadlink
Mirabella Genio Globes
RFlink 334 mhz
mysensors
broadlink
zak45
@markjgabb
this should be there : "%ProgramFiles(x86)%\Domoticz\plugins\Broadlink\"
And Domoticz v 3.7xxx or >
