Hi all !
Tried using search, but no hits. Has anyone tried these :
https://www.aliexpress.com/item/Sonoff- ... 271.Qd5CG6
Looks nice and are affordable, but i wonder do these work out of the box ? As far as i have understood, they dont need different controller, can be controlled directly from mobile phone for example.
-Tomi
Itead Sonoff 2.4ghz wi-fi wall switch compatibility ?
tontze
- Domoticz version: Beta Ch
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
tontze
Re: Itead Sonoff 2.4ghz wi-fi wall switch compatibility ?
Found some information about the switch :
"It's an ESP8266 based, PSF-A85 mounted on a small board that has 4 pin header labeled 3.3v, GND, and Relay (4th pin unused). In addition to the ESP module, there's a touch sensor chip (label scrapped off). The larger board has power and relay"
https://github.com/arendst/Sonoff-MQTT-OTA-Arduino
Looks nice
Looks nice
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
tontze
And further : https://github.com/arendst/Sonoff-Tasmota
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
I have one lying around, on my to do list, but haven't got time to figure out how to open it...
https://github.com/davidmpye/Sonoff-Touch-MQTT/wiki
tontze
Ok, there is information how to do it here :
https://www.domoticz.com/forum/viewtopi ... 28&t=17352
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
