Awesome.. but which beta version ? I am running Version: 3.4933 but can not select a custom sensor..Raspberry Piet wrote:Custom Sensor. Available in Beta version.Pierryck wrote:My virtual device is a general text, which one do you take to change the icon ?
Traffic with waze in Domoticz
sjefk
Re: Traffic with waze in Domoticz
sjefk
Forget my post.. was not looking closelysjefk wrote:Awesome.. but which beta version ? I am running Version: 3.4933 but can not select a custom sensor..Raspberry Piet wrote:Custom Sensor. Available in Beta version.Pierryck wrote:My virtual device is a general text, which one do you take to change the icon ?
konix
- Domoticz version: 2020.2
Hello all , I use a script below to the rise of Waze information under domoticz and it works perfectly on a custom sensor
. I would like now blocked configuration journey on one trip ? Have you an idea of the configuration to perform to freeze the desired road ?
Below my my request
Thank you in advance.
Below my my request
ocal waze=assert(io.popen('curl "https://www.waze.com/row-RoutingManager/routingRequest?from=x%3A'..departx..'+y%3A'..departy..'&to=x%3A'..arrivex..'+y%3A'..arrivey..'&returnJSON=true&timeout=6000&nPaths=1&options=AVOID_TRAILS%3At%2CALLOW_UTURNS"'))
local trajet = waze:read('*all')
waze:close()Raspberry PI 2 whith Domoticz (Master)
Raspberry PI B+ whith Domoticz (Slave)
Raspberry PI B+ whith OSMC
RFLINK - ZWAVE - TELEINFO - 1 WIRE
- remb0
I got almost every minute this error message:
2016-03-24 21:11:01.165 Error: EventSystem: in script_time_Waze: /home/pi/domoticz/scripts/lua/JSON.lua:383: html passed to JSON:decode():
503 Service Temporarily Unavailable
Maybe it's coincidence , but since I installed pi-hole I get this error . waze.com is already on my whitelist and I have data in my sensors so it looks good. How can I debug it and get rid of this message?
I'm using the waze script but with ssl socket instead of curl to get status information from the https call (or does curl also include this?).
The only problem is I'm getting a time out once a day. I already added a timeout, but with no luck.
Any idea about how to solve this?
woody4165
Very nice script.
I'm trying also to send a telegram message when traffic is more than a certain value.
The only thing is that I get several messages because the script runs several time during the 1 minute checking timeframe.
I tried using an UserVariable and set it to 0 if it has to send Telegram message and 1 when it has sent the message.
Then I set back to 0 when it goes out of the checking timeframe.
But it's not working...
Any suggestion?
-- Invia messagio a Telegram bot per traffico
if (routeTotalTimeMin > 20 and uservariables["solouna"]<1) then
minuti = tostring(routeTotalTimeMin)
message = minuti..' minuti per andare in ufficio alle '..time.hour..':'..time.min..' !!!'
os.execute('curl --data chat_id=xxxxxxxx--data-urlencode "text='..message..'" "https://api.telegram.org/botxxxxxxxxx/sendMessage" ')
uservariables["solouna"]=1
Any suggestion?
dervogt
- Domoticz version: BETA
just FYI: I just had some issues with the script after initial implementation, giving no travel times back anymore on previously good geo coordinates: all of a sudden there was an internal error in the route calculation. After verifying the geocoordinates on the Waze life map (NOTon Google maps, en re-setting them in the script, the script is returning travel times again.
I am not sure if this was a change on the Waze side of the routing API or just inaccurate (but previously working) geo coordinates.
Thought I am quickly going to share this if anyone else xperiences the same issue as well
matthiasblomme
Has anyone checked if you can get a list or details of your scheduled drives?
That would be even more fitting for your home environment.
I'm currently looking into waze api's but I'm not finding that much
- lemassykoi
- Domoticz version: 2025.1
Traffic with Waze in Domoticz (LUA/BASH)
I slightly adapted this script for my use, and it's perfect. I can monitor, as someone write earlier, traffic time, and see at which time it's better to leave.
Before first run, you need to :
If you want to see DEBUG, change User Variable "debug_general" to "Y"
Big Thanks to D'rMorris
EDIT :
I switched to bash to avoid errors like "more ten seconds... blablabla"
so, the same in BASH :
edited to add UserAgent and Referer to LUA (not tested) and Bash (tested) - 20170814
- Create two User Variables : (settings --> more --> user variables)
debug_general (type "String", value : "N" for No or "Y" for Yes)
timeout_general (type "Integer", value : "600" in seconds, the time needed to update Travel Time) - Create two Virtual Sensors (I used "Custom Sensor" with "minutes" for Axis Label)
change their name to "Home to Work" and "Work to Home" (or whatever you want, but you'll need to change values in the script).
Also take note of their IDX - Find your correct Lat / Long, by browsing https://www.waze.com/fr/livemap, enter your address, then click on the Blue marker to get the Permalink. Values will be shown in the Permalink URL.
- And finally, replace variables in the script (if your values differs)
-- script_time_Waze.lua
print('<b style="color:Blue"> >> Monitoring Traveltimes</b>')
------------- Begin time functions -------------
function timedifference_lastupdate_homework (s)
year = string.sub(s, 1, 4)
month = string.sub(s, 6, 7)
day = string.sub(s, 9, 10)
hour = string.sub(s, 12, 13)
t1 = os.time()
difference_lastupdate_homework = os.difftime (t1, t2)
return difference_lastupdate_homework
function timedifference_lastupdate_workhome (s)
t1 = os.time()
difference_lastupdate_workhome = os.difftime (t1, t2)
return difference_lastupdate_workhome
------------- End time functions -------------
------------- Begin local variables -------------
-- User variables --
-- IP Address and port
IP = '192.168.1.10'
port = '8080'
--idx of devices for capturing the travel time (in minutes) in both direction
idxhomework = '120' -- Home to Work
idxworkhome = '121' -- Work to Home
HomeToWork = 'Home to Work' -- Replace by the name of your dummy sensor
WorkToHome = 'Work to Home' -- Replace by the name of your dummy sensor
--Coordinates Home
-- https://www.waze.com/fr/livemap?zoom=17&lat=48.79687&lon=2.31007 -- Ex. : Bagneux, France
departy = '48.79687'
departx = '2.31007'
--Coordinates Work
-- https://www.waze.com/fr/livemap?zoom=17&lat=48.88988&lon=2.24181 -- Ex. : La Défense, France
arrivey = '48.88988'
arrivex = '2.24181'
-- Debug variables:
debug = uservariables["debug_general"]
timeout = uservariables["timeout_general"]
difference_homework = timedifference_lastupdate_homework(otherdevices_lastupdate[HomeToWork])
difference_workhome = timedifference_lastupdate_workhome(otherdevices_lastupdate[WorkToHome])
------------- End local variables -------------
------------- Begin debug statements -------------
if debug=="Y"
then
print('<b style="color:Red"> >> Debug is set to: ' .. debug .. '</b>')
print('<b style="color:Red"> >> Update timeout: ' .. timeout .. '</b>')
print('<b style="color:Red"> >> Lastupdate Home to Work : ' .. difference_homework .. '</b>')
print('<b style="color:Red"> >> Lastupdate Work to Home : ' .. difference_workhome .. '</b>')
------------- End debug statements -------------
------------- Begin code -------------
if (difference_homework > timeout and difference_workhome > timeout)
then
function traveltime(departx,departy,arrivex,arrivey)
--get route from WAZE--
local waze=assert(io.popen('curl -A "Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:43.0) Gecko/20100101 Firefox/43.0" --referer "https://www.waze.com" "https://www.waze.com/row-RoutingManager/routingRequest?from=x%3A'..departx..'+y%3A'..departy..'&to=x%3A'..arrivex..'+y%3A'..arrivey..'&returnJSON=true&returnGeometries=true&returnInstructions=true&timeout=60000&nPaths=1&clientVersion=4.0.0&options=AVOID_TRAILS%3At%2CALLOW_UTURNS"'))
waze:close()
if debug=="Y"
then
print("========================================================================================================")
print(trajet)
local jsonTrajet = json:decode(trajet)
--Get major road from JSON
routeName = jsonTrajet['response']['routeName']
--Get route steps from JSON info
route = jsonTrajet['response']['results']
--Calculate the total time by adding the time of all sections
routeTotalTimeSec = 0
for response,results in pairs(route) do
routeTotalTimeSec = routeTotalTimeSec + results['crossTime']
--translate the number of seconds to minutes
routeTotalTimeMin = routeTotalTimeSec/60-((routeTotalTimeSec%60)/60)
return routeTotalTimeMin
--import JSON addin (already used with DTGBOT and stored in the standard library)
json = (loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")() -- check presence of this script if problem
-- get travel time
homework=traveltime(departx,departy,arrivex,arrivey)
workhome=traveltime(arrivex,arrivey,departx,departy)
if debug=="Y"
then
print('Home to Work : ' .. homework .. ' minutes')
print('Work to Home : ' .. workhome .. ' minutes')
-- update Domoticz devices
url='http://' .. IP .. ':' .. port .. '/json.htm?type=command¶m=udevice&idx=' .. idxhomework .. '&nvalue=0&svalue=' .. homework
read = os.execute('curl -s "'..url..'"')
url='http://' .. IP .. ':' .. port .. '/json.htm?type=command¶m=udevice&idx=' .. idxworkhome .. '&nvalue=0&svalue=' .. workhome
print('<b style="color:Green"> >> Update OK !</b>')
if debug=="Y"
then
print('<b style="color:Red">>> HomeWork lastupdate: ' .. difference_homework .. ' seconds ago. Must be > to '.. timeout ..'</b>')
print('<b style="color:Red">>> WorkHome lastupdate: ' .. difference_workhome .. ' seconds ago. Must be > to '.. timeout ..'</b>')
------------- End code -------------
EDIT :
#!/bin/bash
## user variables
DOMOTICZ_SERVER="127.0.0.1:8080"
IDXA="122" ## IDX du dummy Maison-Travail
IDXR="123" ## IDX du dummy Travail-Maison
departx="2.44177" ## Maison
departy="48.62994"
arriveex="2.25733" ## Travail
arriveey="48.79998"
tmpfileA="/tmp/wazeAller.txt"
tmpfileR="/tmp/wazeRetour.txt"
log="/tmp/wazelog.txt"
rm -rf $log
rm -rf $tmpfileA
rm -rf $tmpfileR
#echo "Start." > $log
## CURL de l'Aller
urlA='https://www.waze.com/row-RoutingManager/routingRequest?from=x%3A'$departx'+y%3A'$departy'&to=x%3A'$arriveex'+y%3A'$arriveey'&returnJSON=true&returnGeometries=true&returnInstructions=true&timeout=60000&nPaths=1&clientVersion=4.0.0&options=AVOID_TRAILS%3At%2CALLOW_UTURNS'
/usr/bin/curl -A 'Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:43.0) Gecko/20100101 Firefox/43.0' --referer 'https://www.waze.com' -s -o $tmpfileA $urlA
#echo "urlA : "$urlA >> $log
## Sleep to avoid 503 errors
sleep 5
## CURL du Retour
urlR='https://www.waze.com/row-RoutingManager/routingRequest?from=x%3A'$arriveex'+y%3A'$arriveey'&to=x%3A'$departx'+y%3A'$departy'&returnJSON=true&returnGeometries=true&returnInstructions=true&timeout=60000&nPaths=1&clientVersion=4.0.0&options=AVOID_TRAILS%3At%2CALLOW_UTURNS'
/usr/bin/curl -A 'Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:43.0) Gecko/20100101 Firefox/43.0' --referer 'https://www.waze.com' -s -o $tmpfileR $urlR
#echo "urlR : "$urlR >> $log
## calcul Aller
tempstrajetminsA=$(/usr/local/bin/jq -r .response.results[].crossTime $tmpfileA | /usr/bin/awk '{s+=$1} END {print s}' | /usr/bin/awk '{sum = $1 / 60 ; print sum }' | /usr/bin/cut -f1 -d\. )
#echo "Temps trajet Aller : "$tempstrajetminsA >> $log
## calcul Retour
tempstrajetminsR=$(/usr/local/bin/jq -r .response.results[].crossTime $tmpfileR | /usr/bin/awk '{s+=$1} END {print s}' | /usr/bin/awk '{sum = $1 / 60 ; print sum }' | /usr/bin/cut -f1 -d\. )
#echo "Temps trajet Retour: "$tempstrajetminsR >> $log
## Resultats
echo "Temps de Trajet Aller : $tempstrajetminsA mn"
echo "Temps de Trajet Retour : $tempstrajetminsR mn"
## updating dummy sensors
updateA='http://'$DOMOTICZ_SERVER'/json.htm?type=command¶m=udevice&idx='$IDXA'&nvalue=0&svalue='$tempstrajetminsA
updateR='http://'$DOMOTICZ_SERVER'/json.htm?type=command¶m=udevice&idx='$IDXR'&nvalue=0&svalue='$tempstrajetminsR
#echo "URL Update A : "$updateA >> $log
#echo "URL Update R : "$updateR >> $log
/usr/bin/curl -s $updateA &
/usr/bin/curl -s $updateR
exit 0
Last edited by lemassykoi on Monday 14 August 2017 16:31, edited 2 times in total.
krizzz
Thanks for the script! When using the bash script I am getting the following error:
I googled and found that JQ is a program. But how do I install JQ so that it is available from the /usr/local/bin directory?
waze.sh: line 30: /usr/local/bin/jq: No such file or directory
waze.sh: line 34: /usr/local/bin/jq: No such file or directory
Temps de Trajet Aller : 0 mn
Temps de Trajet Retour : 0 mn
"status" : "OK",
"title" : "Update Device"
"status" : "OK",
- lemassykoi
I build JQ from source, and I put my script in a CRON, that's why I specified all the binary paths.
You can install it from apt :
then locate the binary :
then update the script to the correct path
sudo apt-get install jqCode: Select all
whereis jq-
Abbadon
sometimes i have problem with your script
and sometimes its working fine...
to prevent 0 i add if to your script, but its not a solution
any idea?
pi@raspberrypi:~/domoticz/scripts$ ./traffic.sh
parse error: Invalid numeric literal at line 1, column 7
Temps de Trajet Aller : 21 mn
"status" : "OK",
"status" : "OK",
Temps de Trajet Retour : 19 mn
"status" : "OK",
"status" : "OK",
if [ $tempstrajetminsA -gt "0" ]; then
fi
if [ $tempstrajetminsR -gt "0" ]; then
fi
- lemassykoi
I found this : https://github.com/stedolan/jq/issues/501
Try to replace this line :
by this one :
/usr/local/bin/jq -r .response.results[].crossTimeCode: Select all
/usr/local/bin/jq -r '.response.results[].crossTime'-
Abbadon
sadly no. ;|
- lemassykoi
It seems to be JQ/JSON related.
http://stackoverflow.com/questions/3479 ... 1-column-9
try to play with switch R and r, maybe Waze is not full JSON.
I checked my queries, and I don't have any "0 minutes" during past 48 hours.
krizzz
I have the script working! Also But seem to have the exact same issue as user Abbadon. Sometimes the value 0 appears but only on the route from work to home
- lemassykoi
do any of you have a minus sign in one of his coordinates ?
krizzz
No.lemassykoi wrote:do any of you have a minus sign in one of his coordinates ?
How did you check what were the results over a certain period?
Abbadon
Same, for now best solution is that IF statmentlemassykoi wrote:It seems to be JQ/JSON related.
- lemassykoi
like this : click on "log" on the dummy sensorkrizzz wrote:No.lemassykoi wrote:do any of you have a minus sign in one of his coordinates ?
