Samsung TV control in Domoticz
ptijo
Re: Samsung TV control in Domoticz
i have try :
/usr/local/iSamsungTV/bin$ ./iSamsungTV C 192.168.1.10 -KEY KEY_MUTE
-sh: ./iSamsungTV: cannot execute binary file: Exec format error
and with root
-ash: /usr/local/iSamsungTV/bin$: No such file or directory
i have try :
and with root
- jumbotroll
@ptijo
I am using this without any problem, on DS712+, but maybe my build not working on your NAS.
If my packages not work I'm going to delete them from my server.
Edit: packages deleted!
https://paypal.me/Jumbotroll
Jumbotroll
http://www.jadahl.com
Jumbotroll
Rodio
Still the same error:tontze wrote:
Correct sudo usage :
sudo /usr/local/iSamsungTV/bin/iSamsungTV E 192.168.1.36 -KEY KEY_POWEROFF
root@HA:~# sudo /usr/local/iSamsungTV/bin/iSamsungTV E 192.168.1.36 -KEY KEY_POWEROFF
/usr/local/iSamsungTV/bin/iSamsungTV: /usr/local/iSamsungTV/bin/iSamsungTV: cannot execute binary file
I tried:
Delete and reinstall package.
Install it on my 916 (running latest stable version)
Install it on my 916 running Domoticz V3.6749
Tried the C, D, F TV setting.
All give the same error
ptijo
I see that there are lot of issue with version of NASjumbotroll wrote:@ptijo
uname r :2.6.32.12
'm sorry, but I'm resigning myself.
thanks
tontze
- Domoticz version: Beta Ch
Not the same error, last time it didnt find sudo since wrong path was provided to it. go toRodio wrote:Still the same error:tontze wrote:
I tried:
/usr/local/iSamsungTV/bin/Code: Select all
./iSamsungTVCode: Select all
sudo ./iSamsungTVCode: Select all
chmod a+x /usr/local/iSamsungTV/bin/iSamsungTV-----------------------------------------
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
Rodio
Hi Tontze,
Thx for the replies.
did the chmod a+x thing
root@HA:/usr/local/iSamsungTV/bin# iSamsungTV
-ash: /bin/iSamsungTV: cannot execute binary file: Exec format error
root@HA:/usr/local/iSamsungTV/bin# iSamsungTV E 192.168.1.36 -KEY KEY_POWERON
root@HA:/usr/local/iSamsungTV/bin# sudo iSamsungTV
/bin/iSamsungTV: /bin/iSamsungTV: cannot execute binary file
root@HA:/usr/local/iSamsungTV/bin# sudo ./iSamsungTV
./iSamsungTV: ./iSamsungTV: cannot execute binary file
R
R
tontze
Check that your binary file matches with your systems architecture, is it ARM and your system is X86 or vice versa
Or is it 32bit program and your system is 64bit, or vice versa.
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
Rodio
No idea how to check for which architecture the binary file is.
I've downloaded it form the site of Jumbotroll, but he's deleted them (they're not there anymore).
I'm gonna stop for now with this 'project'.
Thx for the help Tontze, really appreciate it
- bueno79
- Domoticz version: 4.9700
your problem is : this file is NOT compile for your architecture. type :
file iSamsungTV
you will see the infos (you need file command of course). So I get the same issue and fix it with a 214play.
- I install a linux ubuntuu.
- I install the CORRECT tool chain from here on the ubuntuu (https://sourceforge.net/projects/dsgpl/ ... edomCookie)
- I set some variables to compile on th ubuntuu (lines below are not for 214play, just example)
- then compile the samsungTV code (I clone the project on the ubuntuu with git first) with the gcc (the path is in the variable CC you set before)
- move my new iSAmsungTV on my NAS
it woooorks !!!
you can find all info in french here : http://benjamin-balet.info/multimedia/s ... -synology/
you can fin d info on google with "cross compilation synology"
regards
Bueno
file iSamsungTV
export CFLAGS="-I/usr/local/arm-none-linux-gnueabi/include"
export LDFLAGS="-L/usr/local/arm-none-linux-gnueabi/lib"
export RANLIB=/usr/local/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-ranlib
export LD=/usr/local/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-ld
export CC=/usr/local/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-gcc
export LD_LIBRARY_PATH=/usr/local/arm-none-linux-gnueabi/lib
export ARCH=arm- move my new iSAmsungTV on my NAS
it woooorks !!!
regards
Bueno
stavast
As a proud owner of a Samsung Series K I really wanted to integrate remote control into Domoticz and i finally found a way!perwei wrote:Just a comment regarding newer Samsung TVs like model K. Seems iSamsungTV isn't working on those models.
On the other hand, Wake-on-LAN does work and brings the TV from sleeping and un-pingable to live and pingable.
Cheers,
Per
SamsungCTL makes it possible to control the Samsung Series K (and probably all the other series as well). At this moment i can control the TV via the command interface, so we are only a small step away from the full integration which will allow us to control the TV via Domoticz.
Installation
1. Install python3-pip:
pi@domoticz:~ $ sudo apt-get install python3-pip
pi@domoticz:~ $ sudo pip3 install samsungctl
pi@domoticz:~ $ sudo pip3 install websocket-client
pi@domoticz:~ $ samsungctl --host xxx.xxx.xxx.xxx --method websocket KEY_MUTE
6. Allow the external control with your TV Remote and voila! remote control should be working now and the volume of your TV should be muted.
Extra information:
1. To unmute your tv use
pi@domoticz:~ $ samsungctl --host xxx.xxx.xxx.xxx --method websocket KEY_VOLUP
2. The extra option
--method websocketLinks
SamsungCTL GitHub: https://github.com/Ape/samsungctl
Key Codes: https://github.com/Ape/samsungctl#key-codes
Good luck!
- mlamie
- Domoticz version: 3.5877
I have seen there is a new Samsung TV page in the Domoticz wiki based on samsungctl. You can try that as well I expect.stavast wrote: Good luck!
https://www.domoticz.com/wiki/Plugins/SamsungTV.html
Raspberry Pi 3, RaZberry, RFXtrx433
Various Z-Wave devices, KlikAanKlikUit devices, ESP8266 NodeMCU, Sonoff POW and a Essent E-thermostaat
IP camera: Dahua 4MP IPC-HDBW4421R-AS, Vivotek FD8134V
- Westcott
When I try it from the command line, I get -
File "/usr/local/bin/samsungctl", line 9, in <module>
load_entry_point('samsungctl==0.6.0', 'console_scripts', 'samsungctl')()
File "/usr/local/lib/python2.7/dist-packages/samsungctl/__main__.py", line 93, in main
config = _read_config()
File "/usr/local/lib/python2.7/dist-packages/samsungctl/__main__.py", line 37, in _read_config
except FileNotFoundError:
NameError: global name 'FileNotFoundError' is not defined
My guess is that the config file is missing...
stavast
O Wow, I have been searching for two weeks! what a coincidence and a luck. Thank god the plugin is from the 27th of March, I was very sure I search in every corner of the Domoticz forum and wiki. I felt a bit of a fool for missing such a big elephantmlamie wrote:I have seen there is a new Samsung TV page in the Domoticz wiki based on samsungctl. You can try that as well I expect.stavast wrote: Good luck!
stavast
You need to have Python Version 3 to be able to run samsungctl. based upon this "File "/usr/local/lib/python2.7/" i get the feeling you installed it under Python Version 2 with the use of pip instead of pip3Westcott wrote:When I try it from the command line, I get -
- Westcott
Thanks, Stavast!
The Wiki needs to be updated with some 3's.
I REALLY don't like version-specific installs.
Now I'm getting the dreaded -
/usr/local/bin/python3.5: error while loading shared libraries: libpython3.5.so.1.0: cannot open shared object file: No such file or directory
Python3 runs OK -
Python3 -i
Python 3.5.2 (default, Dec 14 2016, 15:53:15)
echo $LD_LIBRARY_PATH
/usr/local/lib
And libpython3.5.so.1.0 is in /usr/local/lib
Haven't been able to Google a solution yet.
Python3 runs OK -
Python3 -i
/usr/local/lib
ptijo
#bueno79
Could you give me the gcc command
i try but i have the same error (format exec error)
bueno79 wrote:Hi,
file iSamsungTV
- then compile the samsungTV code (I clone the project on the ubuntuu with git first) with the gcc (the path is in the variable CC you set before)Code: Select all
export CFLAGS="-I/usr/local/arm-none-linux-gnueabi/include" export LDFLAGS="-L/usr/local/arm-none-linux-gnueabi/lib" export RANLIB=/usr/local/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-ranlib export LD=/usr/local/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-ld export CC=/usr/local/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-gcc export LD_LIBRARY_PATH=/usr/local/arm-none-linux-gnueabi/lib export ARCH=arm
it woooorks !!!
regards
Bueno
- bueno79
@ptijo
just imagine your processor is an arm. you get the tool chain and your path is the default one. And you have the source from iSamnsungTV in your home. So you should type something like this :
/usr/local/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-gcc /home/bueno/iSamsungTV/iSamsungTV.c
If you have a precompiled binary of iSamsungTV, other then osx or raspberry pi, post a link, I will add them to the github page...
tontze
Finally made a button to control my TV in domoticz, but seems its not working well ..
This is what im getting to log in domoticz, from command line its working well .. ?
2017-04-18 17:31:47.268 Error: Error executing script command (/usr/local/bin/iSamsungTV). returned: 512-----------------------------------------
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
- bueno79
ok I will extract my version.woodtrix wrote:If you have a precompiled binary of iSamsungTV, other then osx or raspberry pi, post a link, I will add them to the github page...
