OK, I installed the gateway and no error messages. (See logfile) Have installed a door sensor. In the app, no problem. However in Domoticz I see no device from Xiaomi.
What am I doing wrong?
2017-03-16 19:32:24.257 XiaomiGateway: will listen on 9898 for hardware id 18
2017-03-16 19:32:24.257 XiaomiGateway: Worker started...
2017-03-16 19:32:24.257 EventSystem: reset all events...
2017-03-16 19:32:24.257 XiaomiGateway: Using 192.168.1.49 for local IP address.
2017-03-16 19:32:24.258 EventSystem: reset all device statuses...
2017-03-16 19:32:24.262 EventSystem: Started
2017-03-16 19:32:25.257 RFXCOM: Using serial port: /dev/ttyUSB0
2017-03-16 19:32:25.660 AppLamp: Bridge found!...
2017-03-16 19:32:35.032 Incoming connection from: 127.0.0.1
I need to put the gateway onto a different Wi-Fi network. Do you guys know how to do this without resetting everything?
I have just hit 30 devices. Untill now everything is working correctly. Hopefully i can add device number 31 within this weekcorbin wrote:That is a lot of devices, you should have some fun with that!. Are you getting any more? I think I read the limit is around 30 per gateway and would be good to know for sure.dcliff1 wrote:
Nice work mate! Its now reporting all the devices. Thanks heaps for that.. really appreciate the good work. Now to go play!
- Domoticz version: BETA
Perhaps in Domoticz just change the ip adres.. [ same idx ]jjnj wrote:I need to put the gateway onto a different Wi-Fi network. Do you guys know how to do this without resetting everything?
Mihome:-(
And in your app is a help function..
There you can ask the helpdesk some help..
And they help me.......... [ with other problems ]
- corbin
Please be aware that the next Xiaomi Gateway beta update will duplicate all your switches - you will then need to delete the originals and rename the new switches.
With this change, it should fix the double update messages (I hope!)
Please don't update to beta 3.7016, the problem isn't fixed and will duplicate your switches for no benefit.
corbin wrote:Please be aware that the next Xiaomi Gateway beta update will duplicate all your switches - you will then need to delete the originals and rename the new switches.
Currently I do not see at all switches.
How do I get to see the switches ??
- bbqkees
- Domoticz version: 4.1x
I now have a black version of the door sensor (because my window frames are black, not white.)
You can't buy them in store unfortunately, I used a spray can from the Praxis (Sensys zwart zijdeglans).
I did the same with a classic black spay
Thank you for your reply. I do a software reboot (sudo reboot) without it working,. After a hardware reboot everything is returned in order.corbin wrote:Have you tried deleting hardware id 11? If that doesn't work, look in the Hardware table in the Domoticz.db database and try deleting from there.
thank you
DZ Beta V3.6953 / Aeotec Z-Stick S2 / Aeotec Multi Sensor / Xiaomi Gateway /
- corbin
Please don't update to beta 3.7016, the problem isn't fixed (there is no double up, but you lose control of switches) and will duplicate your switches for no benefit.
mmmmcorbin wrote:Please don't update to beta 3.7016, the problem isn't fixed (there is no double up, but you lose control of switches) and will duplicate your switches for no benefit.
To late....
Did the upgrade.. [ before reading this
And now?
edit..
Cannot See not my motionsensors and my doorsensor and the light is not working in domoticz.
The cube and the wireless switch are working fine
- corbin
Hope to have it fixed soon
Just restore frome backup. Of course you have made one before upgrade.Derik wrote:And now?corbin wrote:Please don't update to beta 3.7016, the problem isn't fixed (there is no double up, but you lose control of switches) and will duplicate your switches for no benefit.
Wait for that...corbin wrote:Hope to have it fixed soon
I always wait to the stable before use the sensors for real...
Never downgrade...
when you need a tester... i will help
- corbin
Please test from https://github.com/corbinmunce/domoticzDerik wrote: when you need a tester... i will help
corbin wrote:Please test from https://github.com/corbinmunce/domoticzDerik wrote: when you need a tester... i will help
Sorry do not now how ho to use the github clone..
Or do you have a how to..
my gateway freezes about 4-5 times a day so i had to plug it out and in again.
Does anybody has the same issues with it?
- Domoticz version: 3.7449
Off state are no longer seen on the last beta built.
Door sensor are detecting when open, but do not detect the closed (when the status is correct according to Xiaomi apps).
Same for motion sensor that are kept in detection for ever.
Version: 3.7040
Build Hash: fcc83f4a
Compile Date: 2017-03-19 09:34:59
Version: 3.7040
- corbin
Do you have any devices with duplicate IDs on the Devices page?Mat2Vence wrote:Off state are no longer seen on the last beta built.
- corbin
No issues here, its been 100% stable so far.thps wrote:my gateway freezes about 4-5 times a day so i had to plug it out and in again.
What firmware version? Tried moving it to a different power point?
