just finished the first version of the "SNMP Value Reader" plugin.
With this plugin you can bring one SNMP OID each time on your Domoticz server.
Debian Requirements:
- Install "python-pysnmp-common" with "sudo apt-get install python3-pysnmp4"
Domoticz Installation instructions:
- Create Plugin Folder "SNMPreader" under "domoticz/plugins" folder
- Save this script as "plugin.py" on "SNMPreader" folder
- Restart domoticz service.
- Add a new entry of this Hardware on your domoticz installation (Setup/Hardware/select and add "Wan Ip Checker")
Hope you like it!!
Version 1.0.0 - Updated on 2017-03-17
Develompent is maintained to GitHub - https://github.com/ycahome/SNMPreader
# SNMPreader Plugin
# Ycahome, 2017
# https://www.domoticz.com/forum
<plugin key="SNMPreader" name="SNMP Value Reader" author="ycahome" version="1.0.0" wikilink="m" externallink="https://www.domoticz.com/forum/viewtopic.php?f=65">
<params>
<param field="Address" label="Server IP" width="200px" required="true" default="192.168.1.1"/>
<param field="Mode1" label="OID" width="200px" required="true" default="1.3.6.1.2.1.25.3.2.1.1.2"/>
<param field="Mode2" label="Community" width="200px" required="true" default="public"/>
<param field="Mode3" label="Domoticz TypeName" width="200px">
<options>
<option label="Custom" value="Custom"/>
<option label="Text" value="Text"/>
<option label="Temperature" value="Temperature" default="true" />
</options>
</param>
<param field="Mode6" label="Debug" width="75px">
<options>
<option label="True" value="Debug"/>
<option label="False" value="Normal" default="true" />
</options>
</param>
</params>
</plugin>
import Domoticz
import sys
sys.path.append('/usr/lib/python2.7/dist-packages/')
from pysnmp.entity.rfc3413.oneliner import cmdgen
import json
import urllib.request
import urllib.error
from math import radians, cos, sin, asin, sqrt
from datetime import datetime, timedelta
# Domoticz call back functions #
def onStart():
global gdeviceSuffix
global gdeviceTypeName
gdeviceSuffix = "(SNMP)"
interval = 1
createDevices()
if Parameters["Mode6"] == "Debug":
DumpConfigToDebug()
DumpConfigToLog()
ServerIP = str(Parameters["Address"])
snmpOID = str(Parameters["Mode1"])
snmpCommunity = Parameters["Mode2"]
snmpDataValue = getSNMPvalue(ServerIP,snmpOID,snmpCommunity)
Domoticz.Heartbeat(interval)
return True
def onHeartbeat():
# Get new information and update the devices
UpdateDevice(1,0,snmpDataValue)
Domoticz.Log("SNMP Value retrieved:"+snmpDataValue)
return True
# Domoticz helper functions #
def DumpConfigToDebug():
for x in Parameters:
if Parameters[x] != "":
Domoticz.Log("'" + x + "':'" + str(Parameters[x]) + "'")
Domoticz.Debug("Device count: " + str(len(Devices)))
for x in Devices:
Domoticz.Log("Device: " + str(x) + " - " + str(Devices[x]))
Domoticz.Log("Device ID: '" + str(Devices[x].ID) + "'")
Domoticz.Log("Device Name: '" + Devices[x].Name + "'")
Domoticz.Log("Device nValue: " + str(Devices[x].nValue))
Domoticz.Log("Device sValue: '" + Devices[x].sValue + "'")
def DumpConfigToLog():
Domoticz.Log("Device count: " + str(len(Devices)))
for x in Devices:
def UpdateDevice(Unit, nValue, sValue):
# Make sure that the Domoticz device still exists before updating it.
# It can be deleted or never created!
if (Unit in Devices):
Devices[Unit].Update(nValue, str(sValue))
Domoticz.Debug("Update " + str(nValue) + ":'" + str(sValue) + "' (" + Devices[Unit].Name + ")")
# Device specific functions #
def createDevices():
# Are there any devices?
if len(Devices) != 0:
# Could be the user deleted some devices, so do nothing
Domoticz.Debug("Devices Already Exist.")
return
# Give the devices a unique unit number. This makes updating them more easy.
# UpdateDevice() checks if the device exists before trying to update it.
# Add Power and temperature device(s)
Domoticz.Device(Name=gdeviceSuffix, Unit=1, TypeName=Parameters["Mode3"]).Create()
Domoticz.Log("Devices created.")
def getSNMPvalue(ServerIP,snmpOID,snmpCommunity):
Domoticz.Log("var ." + str(ServerIP))
Domoticz.Log("var ." + str(snmpOID))
Domoticz.Log("var ." + str(snmpCommunity))
cmdGen = cmdgen.CommandGenerator()
#genData = cmdgen.CommunityData('public')
genData = cmdgen.CommunityData(str(snmpCommunity))
Domoticz.Log("genData Loaded." + str(genData))
TTData = cmdgen.UdpTransportTarget((str(ServerIP), 161), retries=2)
Domoticz.Log("TTData Loaded." + str(TTData))
errorIndication, errorStatus, errorIndex, varBinds = cmdGen.getCmd(genData,TTData,snmpOID)
Domoticz.Log("DATA Loaded." + str(varBinds))
# Check for errors and print out results
if errorIndication:
Domoticz.Log(str(errorIndication))
else:
if errorStatus:
Domoticz.Log('%s at %s' % (errorStatus.prettyPrint(),errorIndex and varBinds[int(errorIndex)-1] or '?'))
else:
for name, val in varBinds:
Domoticz.Log('%s = %s' % (name.prettyPrint(), val.prettyPrint()))
return val.prettyPrint()
# Parse an int and return None if no int is given
def parseIntValue(s):
try:
return int(s)
except:
return None
# Parse a float and return None if no float is given
def parseFloatValue(s):
try:
return float(s)
except:
return None
