Plugin - SNMP Value Reader (Debian)
ycahome
Domoticz version: lat Beta
Post by ycahome »
Hi there,
just finished the first version of the "SNMP Value Reader" plugin.
With this plugin you can bring one SNMP OID each time on your Domoticz server.
Debian Requirements:
- Install "python-pysnmp-common" with "sudo apt-get install python3-pysnmp4"
Domoticz Installation instructions:
- Create Plugin Folder "SNMPreader" under "domoticz/plugins" folder
- Save this script as "plugin.py" on "SNMPreader" folder
- Restart domoticz service.
- Add a new entry of this Hardware on your domoticz installation (Setup/Hardware/select and add "Wan Ip Checker")
Hope you like it!!
Version 1.0.0 - Updated on 2017-03-17
Develompent is maintained to GitHub - https://github.com/ycahome/SNMPreader
#   SNMPreader Plugin
#   Ycahome, 2017
#   https://www.domoticz.com/forum
<plugin key="SNMPreader" name="SNMP Value Reader" author="ycahome" version="1.0.0" wikilink="m" externallink="https://www.domoticz.com/forum/viewtopic.php?f=65">
    <params>
        <param field="Address" label="Server IP" width="200px" required="true" default="192.168.1.1"/>
        <param field="Mode1" label="OID" width="200px" required="true" default="1.3.6.1.2.1.25.3.2.1.1.2"/>
        <param field="Mode2" label="Community" width="200px" required="true" default="public"/>
        <param field="Mode3" label="Domoticz TypeName" width="200px">
            <options>
                <option label="Custom" value="Custom"/>
                <option label="Text" value="Text"/>
                <option label="Temperature" value="Temperature"  default="true" />
            </options>
        </param>
            <options>
                <option label="False" value="Normal"  default="true" />
            </options>
        </param>
    </params>
</plugin>
import Domoticz
import sys
sys.path.append('/usr/lib/python2.7/dist-packages/')
from pysnmp.entity.rfc3413.oneliner import cmdgen
import json
import urllib.request
import urllib.error
from math import radians, cos, sin, asin, sqrt
from datetime import datetime, timedelta
#                      Domoticz call back functions                         #
def onStart():
    global gdeviceSuffix
    global gdeviceTypeName
    gdeviceSuffix = "(SNMP)"
    interval = 1
    createDevices()
    if Parameters["Mode6"] == "Debug":
        DumpConfigToDebug()
    DumpConfigToLog()
    ServerIP = str(Parameters["Address"])
    snmpOID = str(Parameters["Mode1"])
    snmpCommunity = Parameters["Mode2"]
    snmpDataValue = getSNMPvalue(ServerIP,snmpOID,snmpCommunity)
    Domoticz.Heartbeat(interval)
    return True
def onHeartbeat():
    # Get new information and update the devices
    UpdateDevice(1,0,snmpDataValue)
        Domoticz.Log("SNMP Value retrieved:"+snmpDataValue)
    return True
#                         Domoticz helper functions                         #
def DumpConfigToDebug():
    for x in Parameters:
        if Parameters[x] != "":
            Domoticz.Log("'" + x + "':'" + str(Parameters[x]) + "'")
    for x in Devices:
        Domoticz.Log("Device:           " + str(x) + " - " + str(Devices[x]))
        Domoticz.Log("Device ID:       '" + str(Devices[x].ID) + "'")
        Domoticz.Log("Device Name:     '" + Devices[x].Name + "'")
        Domoticz.Log("Device nValue:    " + str(Devices[x].nValue))
        Domoticz.Log("Device sValue:   '" + Devices[x].sValue + "'")
def DumpConfigToLog():
    Domoticz.Log("Device count: " + str(len(Devices)))
    for x in Devices:
def UpdateDevice(Unit, nValue, sValue):
    # Make sure that the Domoticz device still exists before updating it.
    # It can be deleted or never created!
    if (Unit in Devices):
        Devices[Unit].Update(nValue, str(sValue))
            Domoticz.Debug("Update " + str(nValue) + ":'" + str(sValue) + "' (" + Devices[Unit].Name + ")")
#                       Device specific functions                           #
def createDevices():
    # Are there any devices?
    if len(Devices) != 0:
        # Could be the user deleted some devices, so do nothing
            Domoticz.Debug("Devices Already Exist.")
        return
    # Give the devices a unique unit number. This makes updating them more easy.
    # UpdateDevice() checks if the device exists before trying to update it.
    # Add Power and temperature device(s)
    Domoticz.Device(Name=gdeviceSuffix, Unit=1, TypeName=Parameters["Mode3"]).Create()
    Domoticz.Log("Devices created.")
def getSNMPvalue(ServerIP,snmpOID,snmpCommunity):
        Domoticz.Log("var ." + str(ServerIP))
        Domoticz.Log("var ." + str(snmpOID))
        Domoticz.Log("var ." + str(snmpCommunity))
    cmdGen = cmdgen.CommandGenerator()
    #genData = cmdgen.CommunityData('public')
    genData = cmdgen.CommunityData(str(snmpCommunity))
        Domoticz.Log("genData Loaded." + str(genData))
    TTData = cmdgen.UdpTransportTarget((str(ServerIP), 161), retries=2)
        Domoticz.Log("TTData Loaded." + str(TTData))
    errorIndication, errorStatus, errorIndex, varBinds = cmdGen.getCmd(genData,TTData,snmpOID)
        Domoticz.Log("DATA Loaded." + str(varBinds))
    # Check for errors and print out results
    if errorIndication:
        Domoticz.Log(str(errorIndication))
    else:
        if errorStatus:
            Domoticz.Log('%s at %s' % (errorStatus.prettyPrint(),errorIndex and varBinds[int(errorIndex)-1] or '?'))
        else:
            for name, val in varBinds:
                    Domoticz.Log('%s = %s' % (name.prettyPrint(), val.prettyPrint()))
                    return val.prettyPrint()
# Parse an int and return None if no int is given
def parseIntValue(s):
        try:
            return int(s)
        except:
            return None
# Parse a float and return None if no float is given
def parseFloatValue(s):
        try:
            return float(s)
        except:
            return None
ycahome
Re: Plugin - SNMP Value Reader (Debian)
Post by ycahome »
Next version will contain simple calculations on the value returned.
Let me know if anyone interested...
gerardvs
Domoticz version: latest-1
Post by gerardvs »
Nice! This was also on my todo list.
Do you have the code on github so we can easily install and maintain subsequent releases?
I know there are other opinions but new Python code should be written in in Python3. ;)
--Gerard
ycahome
Post by ycahome »
gerardvs wrote:Nice! This was also on my todo list.
--Gerard
Hello Gerard,
no, unfortunately am not yet a github user. Also, we are not yet "close friends" with python.
Feel free to suggest mods!!
I believe that this functionality should be native on Domoticz, with a similar implementation like "System Checker"
ycahome
Post by ycahome »
gerardvs wrote: Friday 17 March 2017 15:59 Do you have the code on github so we can easily install and maintain subsequent releases?
Finally I have managed to use GitHub for some of my plugins. List will be updated soon.
Feel free to clone/contribute.
gerardvs
Post by gerardvs »
I see on your github you use python 2.7. Is that wise to do since Domoticz has a dependency of Python 3?
A year ago I also made a proof of concept which works fine but there is a memory leak (due to Python3? ;) ) so I didn't continue so far.
I will follow you progress, good luck!
ycahome
Post by ycahome »
gerardvs wrote: Saturday 17 February 2018 17:55 I see on your github you use python 2.7. Is that wise to do since Domoticz has a dependency of Python 3?
You are totally right.
Unfortunately, didn't found yet a way to make "pysnmp" work with python 3.5+
If you have an idea, am all ears!!! :-)
gerardvs
Post by gerardvs »
This is how I made a simple piece to test. https://github.com/seventer/tonq Don't mind the name, i assume you get the origin of it. :geek:
Be aware of the memory leak so some refactoring of the code is needed. So far I hadn't the time to look into it.
--Gerard
ycahome
Post by ycahome »
gerardvs wrote: Saturday 17 February 2018 21:28 This is how I made a simple piece to test. https://github.com/seventer/tonq Don't mind the name, i assume you get the origin of it. :geek:
--Gerard
I think that I 've managed to make it work with python3. (https://github.com/ycahome/SNMPreader)
Am testing it now.
assenzuid
Post by assenzuid »
I want to monitor a remote nas where I have change the default port in the router to response at.
xxxxxxbackup:port is not working,
Log
2018-05-31 23:21:23.006 Error: (xxxxxxbackup Temp) 'onHeartbeat' failed 'PySnmpError'.
2018-05-31 23:21:23.006 Error: (xxxxxxbackup Temp) ----> Line 89 in /home/pi/domoticz/plugins/SNMPreader/plugin.py, function onHeartbeat
2018-05-31 23:21:23.007 Error: (xxxxxxbackup Temp) ----> Line 152 in /home/pi/domoticz/plugins/SNMPreader/plugin.py, function getSNMPvalue
2018-05-31 23:21:23.007 Error: xxxxxxbackup Temp) ----> Line 10 in /usr/lib/python3/dist-packages/pysnmp/entity/rfc3413/oneliner/target.py, function __init__
2018-05-31 23:21:23.007 Error: (nashomebackup Temp) ----> Line 45 in /usr/lib/python3/dist-packages/pysnmp/entity/rfc3413/oneliner/target.py, function _resolveAddr
pizzulicchio
Post by pizzulicchio »
i'm using this plugin with success, but i have noticed that isn't possible to retreive data from device with snmp version 1.0
I'm be able to use every device with correct id and snmp version 2c.
Is it possible to add support for snmp v1 ?
Many old or elementary devices use only snmp v1.
Have a nice day
Draakje
Domoticz version: 4.11539
Post by Draakje »
I would also love to see some support for v1 snmp.
My device (Atal Temp/humidity sensor) does only do v1 ..
I can read it out with snmp but my knowledge of python is just to low to fix the script
Hardware: Raspberry Pi 3, OTGW, 433MHz Superheterodyne 3310 RF Link
Software: Ubuntu 16.04, Domoticz v3.5468, WiringPi, rc-switch
ycahome
Post by ycahome »
SNMP v2 is not tested with this plugin and i think that uses variables instead of keys (or both).
plugin language is not so flexible with different set of plugin variable requirements.
So, seems that a different plugin might need to be created.
I will try to find time to write it. Feel free to collaborate on github bellow
Draakje
Post by Draakje »
We were talking about v1 :) but that doesn't matter.
I have created my own dzvents script (with some help from other scripts.)
Here is my script.. It is quite simpel and it could be made better :) (more modulair or whatever)
But it does the trick.
It was based on a lua script made by papoo .(synology2.lua source: https://github.com/papo-o/domoticz_scri ... ology2.lua)
I create this for simple SNMP read out (version can simple be changed to v2)
Install SNMP on Raspberry Pi
Log in to you Raspberry Pi and issue:
sudo apt-get install snmpd
Create Virtual/Dummy devices in domoticz
    active = true,
    timer = {'every minute'}
logging =   {  --level    =    domoticz.LOG_DEBUG,                                              -- Only one level can be active; comment others
                level    =   domoticz.LOG_INFO,
                -- level    =   domoticz.LOG_ERROR,
                -- level    =   domoticz.LOG_MODULE_EXEC_INFO,
                   marker    =   "ATAL Temperature/Humidity"      },                            --Display name in LOG
    local DeviceIP = "<ip addres>"                                                               --Device IP Address
    local CommunityPassword = "<password>"                                                          --SNMP Community password
    local Device_Temp = "ATAL Temperature"                                                      --Device Name in Domoticz
    local Device_Hum = "ATAL Humidity"                                                          --Device Name in Domoticz
    local OID_Temperature = '1.3.6.1.4.1.22626.1.2.1.1.0'                                       --OID for Temperature
    local OID_Humidity = '1.3.6.1.4.1.22626.1.2.1.2.0'                                          --OID for Humidity
    local command = 'snmpget -v 1 -c '..CommunityPassword..' -O qv '..DeviceIP..' '..OID_Temperature..' '..OID_Humidity..' '    --Define Bash command to readout SNMP
    local i, results = 0, {}        --Define local Variables to be able to use them later
    local handle = assert(io.popen(command))                                                    --Execute command to get SNMP info
        for line in handle:lines() do                                                           --Capture SNMP output in Array
            results[i] =  line:gsub('"','')                                                     --Remove Double Quotes from entry
            i = i + 1        --Increment Array index
    handle:close()
    if results[0] then domoticz.log(""..Device_Temp.." : "..results[0],domoticz.LOG_DEBUG)      --If Array index 0 is present print Debug if debug is active (see above)
        domoticz.devices(Device_Temp).updateTemperature(results[0]) end                         --Update Device in Domoticz with value from Array
    if results[1] then domoticz.log( "" ..Device_Hum.. " : "..results[1],domoticz.LOG_DEBUG)    --If Array index 1 is present print Debug if debug is active (see above)
        local hum = domoticz.utils.round((results[1]),0)                                        --Round value with no decimals, Humidity is displayed in a round percentage
        local temp = tonumber(results[0])                                                       --Convert Temperature (Array Index0) to number to be able to compare
        if (hum < 30) then        --If Humidity is lower than 30% condition is DRY (equals to 2)
            humstat = 2
        elseif (hum > 70) then        --If Humidity is higher than 70% condition is WET (equals to 3)
            humstat = 3
        elseif ((hum >= 30 and hum <=70) and (temp >= 22 and temp <= 26)) then                  --If Humidity is between 30% and 70% AND temperature is between 22 Degrees and 26 Degrees condition is Comfort (equals to 1)
            humstat = 1
            humstat = 0 end        --Set Humidity to condition NORMAL if non of the above apply (equals to 0)
        domoticz.devices(Device_Hum).update(hum,humstat)                                        --Update Device in Domoticz with value from array and condition.
kllngtme
Post by kllngtme »
Draakje wrote: Thursday 02 April 2020 20:33 I have created my own dzvents script (with some help from other scripts.)
I'm trying to utilize the same idea with a device in my network. I can run an snmpget on the pi with no issues and bring up the results but I'm having issues incorporating the script and such into Domoticz.
I added the dzvents script much like you did but I'm not getting the virtual sensor to update. I created a temperature virtual sensor and had it named accordingly. Am I missing something else?
    active = true,
                   marker    =   "Attic"      },                            --Display name in LOG
    local DeviceIP = "192.168.1.24"                                                               --Device IP Address
    local CommunityPassword = "public"                                                          --SNMP Community password
    local Device_Temp = "AtticTemp"                                                      --Device Name in Domoticz
    local Device_Hum = "AtticHumid"                                                          --Device Name in Domoticz
    local OID_Temperature = '1.3.6.1.4.1.20916.1.6.1.2.2.1.0'                                       --OID for Temperature for Attic
    local OID_Humidity = '1.3.6.1.4.1.20916.1.6.1.2.2.3.0'                                          --OID for Humidity for Attic
    handle:close()
            humstat = 2
            humstat = 3
            humstat = 1
Domoticz logs:
2021-01-29 16:10:00.111 Status: dzVents: Info: Attic: ------ Start internal script: Attic:, trigger: "every minute"
2021-01-29 16:10:00.114 Status: dzVents: Info: Attic: ------ Finished Attic
Draakje
Post by Draakje »
Whatis the snmpget command you use? (the one that is working manually)
I can't see anything wrong with the script (as is is pretty much the same as mine)
you can also set debugging on by putting the level on debug (and disable info logging)
logging = { level = domoticz.LOG_DEBUG, -- Only one level can be active; comment others
--level = domoticz.LOG_INFO,
kllngtme wrote: Friday 29 January 2021 22:13
    active = true,
    handle:close()
            humstat = 2
            humstat = 3
            humstat = 1
Domoticz logs:
kllngtme
Post by kllngtme »
Draakje wrote: Saturday 30 January 2021 11:50 Whatis the snmpget command you use? (the one that is working manually)
This works with no issues:
snmpget -v 1 -c public -O qv 192.168.1.6 1.3.6.1.4.1.20916.1.6.1.2.2.1.0 1.3.6.1.4.1.20916.1.6.1.2.2.3.0
Is it the type of dummy switch I have? Does it need to be text or something?
Draakje
Post by Draakje »
Could be..
Commands looks good so I guess in dzvents script it should also work
I am using 2 dummys. 1 is a temp type and the other is a humidity type
Users browsing this forum: cmisip and 1 guest
