Weird incoming connections in LOG window ?
tontze
Domoticz version: Beta Ch
Post by tontze »
Do i need to be worried when i see "incoming connection from xx.xx.xx.xx" from unknown ip´s for me ?
If i browser to the addresses, there is like d-link sharecenter, which i dont own(whos is it then ?), and Any time & Any where ip surveillance login page, which i dont know either ...
Are these my neighbour´s wifi devices maybe ?
-Tomi
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
htilburgs
Re: Weird incoming connections in LOG window ?
Post by htilburgs »
Is your Domoticz installation reachable from the outside?
What you probably see are 'robots' trying to connect on port 8080, because this is published.
Advice:
- Only publish Domoticz to the outside on https (443)
- If publish Domoticz on http, don't use port 8080 but choose other and redirect to correct internal address
- Use Firewall
- Optional: use Fail2Ban
Hardware:
jensc
Domoticz version: 2020.3
Post by jensc »
I have a Vera Edge on the LAN the insists upon connecting with my Domoticz Pi. I have no clue what that's about. I'm ignoring it for now but it is... odd.
tontze
Post by tontze »
I have 4g modem which have firewall in it. As far as i know, these connections started at same time when i added mi light ibox to my home network .. Ptopably this doesnt have anything to do with this but ..
I have dyndns in use tho, and have forwarded port 8080 to intranet, need to change this and see what happens.
-T
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
tontze
Post by tontze »
Hi, some more information..
As i cancelled dyndns, it didnt have effect on incoming connections. I had a feeling that this all started when i bought MiLight bridge and some bulbs..
Why do MiLight bridge have this in settings:
IP locations databases
Country Code	Country	Region	City	Latitude	Longitude	Last update
IP2Location	-		-	-	0	0	2017-01-16
MaxMind	US	United States	-	Durham	35.994	-78.8986	2017-01-16
It can be changed in AP settings :
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
