Update with Raspberry PI. (linux)
433Mhz opensource Receiver & Transmitter.
jossie67
Post by jossie67 »
Is it posssible to update RFlink with Raspberry PI?
Now I have to disconnect the RFlink, connect it to a windows PC and update.
It would be much easy when I can just update the RFlink in Linux
Raspberry Pi (3x)
Master Domoticz installed on a Synology
RFXCOM RFXtrx433E USB
RFLink
USB Z-Wave Mini Adapter
Mi-light
QuinLED
Landis+Gyr ZME120ACd
Kamstrup_M401
USB-IR-Schreib-Lesekopf Alecto WS1700
Watermeter with TCRT5000
Kodi
DS18B20
MarcE85
Re: Update with Raspberry PI. (linux)
Post by MarcE85 »
Hey,
it is possible with Linux.
Commands:
  • sudo service domoticz stop
  • sudo apt-get install avrdude
  • avrdude -v -p atmega2560 -c stk500 -P /dev/ttyUSB0 -b 115200 -D -U flash:w:/home/pi/RFLink.cpp.hex:i
  • sudo service domoticz start
Just replace the ttyUSB0 with your connection and home/pi/RFLink.cpp.hex with your path to the file.
Regards Marc
jossie67
Post by jossie67 »
Raspberry Pi (3x)
RFLink
Mi-light
QuinLED
Kamstrup_M401
Kodi
DS18B20
htca
Post by htca »
I get this error:
avrdude: stk500v2_ReceiveMessage(): timeout
tried different things, but it did not help (I managed to use this method on earlier versions btw)
This is the command I give:
avrdude -v -p atmega2560 -c stk500 -P /dev/ttyUSB0 -b 115200 -D -U flash:w:/home/pi/rflink46/RFLink.ino.hex:i
I tried different tty's (ACM0) as well.
any clue?
devros
Post by devros »
on my Orangi pi adress is /dev/ttyACM0
sometimes its not working on first try, check if domoticz is stoped
