How to use EvoHome and Opentherm gateway tempertures in Blocky ?
HFman
Domoticz version: V4.1174
Post by HFman »
I would like to use the Evohome temperatures from the sensors in blocky.
Also the temp data from the Opentherm gateway I would like to use.
But they are not visible in blocky.. :(
Has anyone figured out how to do this ?
I search on the web and the forum but could find anything...
Raspberry PI 3 - Opentherm Gateway + ESP8826 - EvoHome - ESPEasy CO2 + Fancontrol - RF-Link - zigbee2mqqt -
HFman
Re: How to use EvoHome and Opentherm gateway tempertures in Blocky ?
Post by HFman »
After reading a lot more i try this :
First it seem to work (don't worry about the < and >) this was only for testing...
But figured out that what is between the " " is handled as "text" and not the value which is inside the sensor right ?
Any one any idea how to solve this...
In they end i want to switch the floorheating pump on and off based on room temperture and water temperture in the Heating system.
I know this is not perfect.. but EVOHOME makes even a bigger mess...:(
Domosapiens
Domoticz version: V3.5981
Post by Domosapiens »
Don't know about EvoHome and Opentherm gateway ..
But this works for me:
Compare with constant.PNG (16.26 KiB) Viewed 2446 times
Temp_A3_Return comes a Fibaro FGBS001 with DS18B20 sensor
That was before I discovered the Thermostat type.
Now I use this:
Compare with dummy.PNG (30.55 KiB) Viewed 2446 times
D_Setpoint is a Dummy of Thermostat type
With this simple Blockly I control the underfloor heating of my whole house in a comfortable way.
Hope this helps
HFman
Post by HFman »
This is what i also need .. ! but then with the EvoHome sensors ..
I see them in Domoticz :
But can't select them at blocky.. :
Lebo2d9
Domoticz version: L stab
Post by Lebo2d9 »
I think you need to create user variables for each evo device and a script to polulate the user variables.
Kind regards
Koen Deschepper
Domoicz on RPI3 (wifi) directly connected 3x ds18b20 for CV temp, Evohome (9 zone), 1 remote 220V switch based on ESP-12. RFXtrx433E, 16x AMST-606, 5 Somfy RTS motors
Domoticz on RPI3(wifi) as slave for terraruim control
More to come
HFman
Post by HFman »
Hi Koen,
I give it up and programmed it directly in Lua...
This works great and without any issue, and frankly speaking, is quite easy :)
Lebo2d9
Post by Lebo2d9 »
I need to learn to use Lua scripting ... I need the temp for my 9 zones in blokcly...
More to come
