Connect doorbell
RayAmsterdam
Connect doorbell
Post by RayAmsterdam »
I want to connect my doorbell to de gpio (in) of my pi 3b. The momentary contact is connected in between the door entry unit (Golmar Platea) en mass. When the contact is open, the tension measured over the contact is 16,7V. What is the easiest way to get the signal of the doorbell as input?
door bell.png (1.55 KiB) Viewed 5982 times
YellowSky
Domoticz version: Last
Re: Connect doorbell
Post by YellowSky »
A voltage divider to get about 3V?
NStafford
Post by NStafford »
I am trying to do something similar with my door system. But I am pretty new to trying to do this set ups without someone checking up on my work.
For me, I am having issues other than the signal. But I would try the voltage divider.
heggink
Domoticz version: 12451
Post by heggink »
Is the 17.6v ac or dc? If dc then you should be able to use a simple up/down converter to 3.3v and connect that to the gpio pin, right? I ordered these for a different use (esp power) : DD0603SB_3V3 * 5 5 STKS Auto Step-UP
http://s.aliexpress.com/NJZjiAvA
DASHTICZ 🙃
P1 meter & solar panel
RayAmsterdam
Thanks for the replies. I ordered a step down converter. I'll keep you guys informed.
RayAmsterdam
Unfortunately the step down converter is not the solution. The step down converter itself triggers the door entry system, like if the doorbell button is pushed. Any other solution?
RayAmsterdam
I was thinking, isn't it simply possible to achieve this with just 2 diodes?
door bell.png (3.06 KiB) Viewed 5848 times
RayAmsterdam
This is the working solution:
door bell.png (2.8 KiB) Viewed 5827 times
ronh123
Post by ronh123 »
Where can I find the instructions and a diagram how to configure and connect a simple switch ( like a door bell switch without any power ) to a Raspberry PI3 and make it usefull in Domoticz.
Installation WiringPI, how to configure the pins and how to keep it in the config of the Raspberry.
elgringo
Domoticz version: Left
Post by elgringo »
viewtopic.php?f=65&t=17759&p=136511#p136511 ?
Input voltage is 8 VAC (normal doorbell), if different the resistor of 1200 Ohm must be changed
