I have this qubino smart meter and I have a problem. In Open Z-wave Control Panel I have all the values correct. Then if I look to the domoticz devices I don't have the the KWh value and I have the KVAh but expressed as W. please see the attached pictures.
best regards.
Smart Meter ZMNHTDx
nvicente
- Domoticz version: 3.6808
Smart Meter ZMNHTDx
- OZW.jpg (45.38 KiB) Viewed 7837 times
- Domoticz.jpg (50.3 KiB) Viewed 7837 times
mazgon
Re: Smart Meter ZMNHTDx
I have the same problem, I tried to remove the device, update domoticz to the last beta but no changes, still wrong values. Have you find a solution?
mazgon
As you can see from the attached screenshot, in the OZW control panel, the information are present and correct, like for yours: But the device appeare like "Unknown" and in the Log output screen there are errors reported by the Node005, the Smart Meter.nvicente wrote:I have this qubino smart meter and I have a problem. In Open Z-wave Control Panel I have all the values correct. Then if I look to the domoticz devices I don't have the the KWh value and I have the KVAh but expressed as W. please see the attached pictures.
best regards.
Is not possible that after 2 months no one can provide us any suggestion? Please, I hope that there is possible to find a solution.... I don't want to migrate to another platform and I'm really confident on the good quality of the Qubino products....
HELP US
nvicente
I have the same node error that you show on your picture. I have the last Domoticz Beta update
regards
regards
mazgon
did you solve the issue or still no way to have the correct information in Domoticz?nvicente wrote: Thursday 02 March 2017 12:31 I have the same node error that you show on your picture. I have the last Domoticz Beta update
regards
I'm installing openhab, I hope to solve this way..... if it will be the same, I will replace the smart meter....
Regards,
Stefano
