Z-Wave Radiator-valve recommendation ?
- cyberclwn
- Domoticz version: 2024.4
Hey Guys,
Anyone here uses a Z-wave compatible radiator-valve ?
I like to get 1 or 2 but i want to know for sure that if you use the valve to change temperature, it also changes in Domoticz.
Anyone got a recommendation for which one to use/get ?
Thanks.
Thanks.
3xPi 2B (Domoticz "live", Domoticz "sandbox", PhotoFrame)
RFXCom433(E), KaKu, Oregon Scientific, Keyes 2-relay, Logitech Media Server, MiLight, Smartwares heating controller(2x), IR Send/Receive, Keyes PIR, XH-M131 DuskSensor, DHT22/11
jannl
- Domoticz version: 2025.5.x
Re: Z-Wave Radiator-valve recommendation ?
I have 1 stellaz and I am happy with it. I switch it manually on and off. No reall temp controll needed, just prevent it from getting too cold.
- emme
- Domoticz version: latest
I'm moving to danfoss LC-13.... got 1... but I discover my pipe valves are to old and not compatible and I do need to replace them
just waiting for the end of winter season to replace them
"We always done this way"
- cyberclwn
Hey,
Thanks for the replies so far.
I want the valve to be operated manually and from domoticz.
That's why i wanted to know that if you change the temperature on the valve, with the dial, the new temperature-setting will be reflected in domoticz.
Looks like the StellaZ can't be used "the old fashion way"
Was thinking of the "Eurotronic Comet Z-Wave".
- emme
LC-13 allow what you need...
it created 2 devices:
- a Clock device (quite useless in Domoticz)
- a setpoint thermostat
if you act the thermostat it will apply to the local display
if you act the local display, it will apply to the Domoticz Device
it just miss the temp it feels... but I understood that information in not provided at all from LC-13
anasazi
I'm using Popp Radiator Thermostat: http://www.popp.eu/thermostat/
It's the same as Danfoss LC-13 but with different firmware and it reports the temperature back to the controller.
Using 9 of these at home
oohlaf
When you use these devices, do you need to make changes to your heating system? Currently I have a central thermostat device in my living room that controls the ground level floor heating and when that is switched on, the radiators on the first and second floor also work. But when the central heating is switched off, the radiators don't work.
tontze
- Domoticz version: Beta Ch
Small question about these, do they maintain its valve position, or do they just fully open when heating needed, and when matched, fully close ? Or, can they maintain temperature by keeping valve open 50% or such ?
-T
-T
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
- LouiS22
In my case it's the latter. When I set the temp to 28 celsius (ie 100%) - then it's keeping it on 100% (the overall temperature won't be 28 celsius though), when i set to 22 then it's only warm (let's say it's 25%) and when set to 24 it's somewhere (50%). 16 is 0%.tontze wrote: Tuesday 13 March 2018 14:14 Small question about these, do they maintain its valve position, or do they just fully open when heating needed, and when matched, fully close ? Or, can they maintain temperature by keeping valve open 50% or such ?
-T
tontze
ok, thats good, thnx
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
MarnixO
- Domoticz version: V4.10199
Here 4 Popp valves , works verry good , with Nest thermostat , second step is to operate them with the Smart Virtual Thermostat who already controls the floorheating of the shower
garethhowell
- Domoticz version: 3.9317
SVT is not a good solution for controlling thermostatic valves. It’s designed for On/Off valves, whereas Popp valves are proportional.MarnixO wrote:Here 4 Popp valves , works verry good , with Nest thermostat , second step is to operate them with the Smart Virtual Thermostat who already controls the floorheating of the shower
This has been discussed on the SVT thread.
