- havnegata
- Domoticz version: V4.10162
I've been using G3rard's frontpage for many months now, but suddenly all thats showing is the buienradar and the rest is black. Anyone got an idea of what happened here?
- gielie
- Domoticz version: latest β
Ok, i gave this front-page a try and looks very nice, i used G3rard's front-page. But 1 thing i cant figure out.
How and where do setup my camera, i have a foscam within domoticz but i cant figure out how to get this done in the front-page.
can someone point me in the right direction?
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
- FIBARO FGS223
- Toon
- Kodi Media Server
- G3rard
- Target OS: -
- Domoticz version: No
@gielie, you can do the setup of the camera in frontpage.html.
@havnegata, can you check the console (F12 in Chrome) for any messages.
Not using Domoticz anymore
- havnegata
Thanks, will do when I get home
- havnegata
OK, @G3rard, can you point me in the direction as of what to loook for in the console?
- havnegata
I restored a backup and everything is OK now
Ewaldharmsen
I want to have push off button to turn off all the light at once.
How do I add that in the frontpage?
jannl
- Domoticz version: 2025.5.x
Just create a virtual button, put that on your frontpage and add some lua to switch of all the lights in a device script.
bsmeding
Yes I'm also interested in a extra column. Will be very happy if you can share your settingsTrigun wrote:Hi Albertvandam,albertvandam wrote:Dear all,
With all the examples and code in this forum, I have managed to create a pretty good frontpage which runs on a wall mounted tablet. Thanks to Hansbit, G3rard and all others.
However I can't get to control my Dru Fireplace (Mertik G6R-HT4B) on the frontpage like it should. Directly from Domoticz it works fine.
Does someone have the right json commands to control the Mertik controller?
When I send json commands directly from the Chrome Address Bar, it doesn't work as aspected also.
For example:
http://192.168.4.250:8080/json.htm?type ... itchcmd=up
switches the fire place off!
Thanks in advance for any response.
first of all, you did a great job!
is there a chance you can post your frontpage files?
I would love to check it out and see how I can make it fit for my home.
thnx in advance!
- gielie
@G3rard Yes, thanks for the help, it works now.
There is only one thing about the camera, i have a foscam R2 and within frontpage i only get an fixed image and no streaming video, is this possible? What should i change? Within Domticz streaming works fine and i use the same url as in my Domoticz camera settings (Ip-adres:port/cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=user&pwd=password&)
- FIBARO FGS223
- Toon
- Kodi Media Server
- FIBARO FGS223
- Toon
- Kodi Media Server
Ewaldharmsen
@Jannl, thanks.
I found my answer on line 159 of frontpage.js
But if I change it like this:
It is non-clickable.
So I still have the quesition: how can I change the look of one particular button?
if (item.SwitchType == 'Push Off Button') {
vdata = '<img src=icons/off_button.png>'
}So I still have the quesition: how can I change the look of one particular button?
Last edited by Ewaldharmsen on Tuesday 28 February 2017 21:21, edited 1 time in total.
Ewaldharmsen
When I click on cell26 it tries to open up 192.168.1.1, which cannot be found.
I cannot find where that is defined.
Can someone guide me?
It is not in frontpage.html, frontpage.js nor frontpage_settings.js..
- G3rard
- Target OS: -
@gielie,
I use this code to show a picture from the camera using Domoticz, where 5 is the idx of the camera in Domoticz.
And when I click on the picture the video is shown (which is actually pictures being reloaded very quickly) using the following code.
This code is somewhere on the bottom of frontpage.html.
This way the video is only shown when you click on the picture, this saves some network traffic.
Domoticz is using the same trick by reloading the pictures very quickly so it looks like a streaming video.
But as you can see in the url of your camera, it is actually showing you a picture.
Other option is that you google the streaming video url for your camera and use that in the frontpage.
<img src="http://192.168.1.157:8084/camsnapshot.jpg?idx=5&t=" onClick="lightbox_open('camera1', 92400);" width="200px" class='camera' />Code: Select all
<div id="popup_camera1"><img src="http://192.168.1.157:8084/camsnapshot.jpg?idx=5&t=" onClick="lightbox_close('camera1');" width="640" height="480" onload='setTimeout(function() {src = src.substring(0, (src.lastIndexOf("t=")+2))+(new Date()).getTime()}, 100)' onerror='setTimeout(function() {src = src.substring(0, (src.lastIndexOf("t=")+2))+(new Date()).getTime()}, 1000)' class='bigcamera' /></div>This way the video is only shown when you click on the picture, this saves some network traffic.
Ierlandfan
Does anyone how to create this? I think I need to change frontpage.html and mess with css?
- frontpage (Small).png (347.14 KiB) Viewed 9085 times
- gielie
Ok i figured out why i can't get a stream but only a steady picture.
My camera doesn't support mjpeg, it only supports H.264 and it needs a different url like this, rtsp://username:pwd@IP:port/videoMain burt i can't get this to work, does the script support rasp? Within VLC i can check if the url works and it does, anybody an idea?
- FIBARO FGS223
- Toon
- Kodi Media Server
- FIBARO FGS223
- Toon
- Kodi Media Server
leffert
Can the frontpage.html dashboard be password protected?
Can it be run, or does it lose any functionallity if it is run from a webhotel outside of home (protected by htaccess or login system)?
How do you solve this?
jannl
Re: RE: Re: NEW frontpage.html - request comments
I solve this by using a vpnleffert wrote:Can the frontpage.html dashboard be password protected?
Ewaldharmsen
Got an excellent frontpage, thank you all!
I change it a bit:
* Made it responsive
* I am using a uservariable instead of a virtual switch
* In phone mode I put the switches on the top of the page:
I change it a bit:
Ewaldharmsen
Last edited by Ewaldharmsen on Monday 20 March 2017 18:45, edited 1 time in total.
Trigun
- Domoticz version: 4.10717
Hi Ewald, it looks amazing! Especially the responsive part! Is there a chance you can share your config? Cheers!!
