domoticz in synology as package! Available now.
bertbigb
Post by bertbigb »
Many thanks for your quick and clear answers.
I have installed Python also, no problem for me.
Don't like a difficult live ;)
Best regards Bert
Synology DS1517+ - DSM 6.2
EdwinK
Post by EdwinK »
Just upgraded to 3.6775. Looks neat. No more dark skin, but happy blue-ish.
tjofras
Post by tjofras »
Hmm not sure if I screwed up my installation by trying to update to a new version inside domoticz (I figured out you should do it from the synology package center a bit too late), but I have some issues with my versions:
I run a Synology 416j
In domoticz it says I run version 3.5876
In synology package center it says I've installed version 3.0.5877-7
The synology says I have the latest version so I haven't been able to update from there. I've tried to install the latest file from jadahl.com but it doesn't change anything and inside domoticz
Does the package include the wrong version?
Egregius
Domoticz version: v2024.7
Post by Egregius »
I had that also with stable 5877. Nothing to worry about.
GJKNL
Post by GJKNL »
Upgraded to DSM 6.1 and latest beta on my Syno 215. Domoticz is running well.
Now I do not have rights anymore to copy scripts to the NAS. in WINscp I get: "Permission denied"
A few months ago I read somewere on this forum about such issue, but I can't find it. I know I have to modify the rights somewhere in the nas, but don't know how. Who can help?
rjblake
Post by rjblake »
GJKNL wrote:Upgraded to DSM 6.1 and latest beta on my Syno 215. Domoticz is running well.
I login to NAS using terminal application (ssh admin@"NAS-IP-Address"), enter admin password then type "sudo -i" and re-enter admin password. Otherwise try these steps https://forum.synology.com/enu/viewtopic.php?t=116295
GJKNL
Post by GJKNL »
Thnx, Its working now!
jumbotroll
Post by jumbotroll »
UPDATED URL's
DSM 6.0 Beta http://www.jadahl.com/domoticz_beta_6/
DSM 6.0 Beta with Python Plugin http://www.jadahl.com/domoticz_beta_6_python/
DSM 6.1 Beta http://www.jadahl.com/domoticz_beta_6.1/
DSM 6.1 Beta with Python Plugin http://www.jadahl.com/domoticz_beta_6.1_python/
Drivers for DSM 6.1 has not been tested for all Synology models yet, so if you update your Synology DSM 6.1, I can unfortunately not guarantee that the USB drivers for domoticz works on all models.
This is because Synology has not released the source code for DSM 6.1 and it is not certain they're going to do it.
See full list of links here: http://www.jadahl.com/
https://paypal.me/Jumbotroll
Jumbotroll
domonator
Post by domonator »
What's the best way to upgrade from stable to the latest beta? Currently on 3.0.5877-7, would like to try v3.0.6775-7.
Thanks,
Peter
jumbotroll
domonator wrote:Hello,
Thanks,
Peter
Just upgrade in package center on your NAS ;)
Download the correct DSM version for your NAS and install, that's it.
Jumbotroll
EdwinK
Post by EdwinK »
Thanks for all your work on this. Makes it easier to install Domoticz this way.
Gravityz
Domoticz version: 2022.2
Post by Gravityz »
so is there at least a list of synology models which experienced problems?
jumbotroll wrote:UPDATED URL's
Drivers for DSM 6.1 has not been tested for all Synology models and there is reported that some has problems, so if you update your Synology DSM 6.1, I can unfortunately not guarantee that the USB drivers for domoticz works on all models.
jumbotroll
Gravityz wrote:so is there at least a list of synology models which experienced problems?
So far only arch-alpine and arch-alpine4k for DSM6.1 is reported with driver problem.
Edit:
arch-alpine for DSM 6.1 seems to be working again with the new drivers compiled with linux kernel 3.10.102.
Jumbotroll
DSM 6.1 Beta http://www.jadahl.com/domoticz_beta_6.1/ (tested V3.0.6775)
DSM 6.1 Beta with Python Plugin http://www.jadahl.com/domoticz_beta_6.1_python/ (tested V3.6800)
both working without problems on Synology DS916+ with DSM 6.1-15047
rjblake
Post by rjblake »
@jumbotroll - curious as to why the start-stop-status script is being overwritten on every update. I keep my SSL certificate in a separate folder so I don't have to maintain a number of these for each app that uses SSL, but every update I need to edit the start-stop-status script. Other than that, working well and appreciate your work
jumbotroll
@rjblake
Because then I have to modify the installer and update script and there are so many different desires and I have chosen to do minimize the number of modifications.
I have unfortunately limited time to fulfill all wishes.
Jumbotroll
Gravityz
Post by Gravityz »
We here You.
I just had a MIB revelation
All Hail JT(JumboTroll)
indeed keep up the good work.
jumbotroll wrote:@rjblake
Egregius
Post by Egregius »
rjblake wrote:@jumbotroll - curious as to why the start-stop-status script is being overwritten on every update. I keep my SSL certificate in a separate folder so I don't have to maintain a number of these for each app that uses SSL, but every update I need to edit the start-stop-status script. Other than that, working well and appreciate your work
You could create a shell script for this.
After update of the package, stop it again, run the script and start it again.
I now have this as script, to disable the paging in tables.
Upon next update I'll add my logfile location.
#!/bin/bash
find /volume1/@appstore/domoticz/www/ -type f -name "*.js" -exec sudo sed -i 's/\"iDisplayLength\" : 25,/\"iDisplayLength\" : -1,\"paging\": false,/g' {} +
find /volume1/@appstore/domoticz/www/ -type f -name "*.html" -exec sudo sed -i 's/\"iDisplayLength\" : 25,/\"iDisplayLength\" : -1,\"paging\": false,/g' {} +
find /volume1/@appstore/domoticz/www/ -type f -name "*.js" -exec sudo sed -i 's/\"iDisplayLength\": 25,/\"iDisplayLength\" : -1,\"paging\": false,/g' {} +
find /volume1/@appstore/domoticz/www/ -type f -name "*.html" -exec sudo sed -i 's/\"iDisplayLength\": 25,/\"iDisplayLength\" : -1,\"paging\": false,/g' {} +
find /volume1/@appstore/domoticz/www/ -type f -name "*.js" -exec sudo sed -i 's/\"iDisplayLength\" : 10,/\"iDisplayLength\" : -1,\"paging\": false,/g' {} +
find /volume1/@appstore/domoticz/www/ -type f -name "*.html" -exec sudo sed -i 's/\"iDisplayLength\" : 10,/\"iDisplayLength\" : -1,\"paging\": false,/g' {} +
find /volume1/@appstore/domoticz/www/ -type f -name "*.js" -exec sudo sed -i 's/\"iDisplayLength\": 10,/\"iDisplayLength\" : -1,\"paging\": false,/g' {} +
find /volume1/@appstore/domoticz/www/ -type f -name "*.html" -exec sudo sed -i 's/\"iDisplayLength\": 10,/\"iDisplayLength\" : -1,\"paging\": false,/g' {} +
find /volume1/@appstore/domoticz/www/ -type f -name "*.js" -exec sudo sed -i 's/\"iDisplayLength\" : 100,/\"iDisplayLength\" : -1,\"paging\": false,/g' {} +
find /volume1/@appstore/domoticz/www/ -type f -name "*.html" -exec sudo sed -i 's/\"iDisplayLength\" : 100,/\"iDisplayLength\" : -1,\"paging\": false,/g' {} +
replacing a string in a single file is something like this:
sudo sed -i s/old/new/ /var/packages/domoticz/start-stop-status
@jumbotroll: is there an option to run a script automatically while updating?
rjblake
Post by rjblake »
Egregius wrote: ...
Thanks for the tip. Might just do that, although if I'm remote, running the script is not really an option (not a big fan of leaving SSH ports open for all - already had some known Russian IP trying to get into my system). Guess I could add it to task scheduler to run it
Egregius
Post by Egregius »
I'm also seeing this in /var/log/messages...
Trying to figure out why my disks won't hibernate...
2017-03-08T22:28:08+01:00 DiskStation synousbmodemd: usbmodem_lib/usbmodem_atif.cpp:114 Unknown vendor id 0658, assign default ATIF
2017-03-08T22:28:10+01:00 DiskStation synousbmodemd: usbmodem_lib/usbmodem_simhandler.cpp:50 Warning: sim mute before handler init
2017-03-08T22:28:10+01:00 DiskStation synousbmodemd: usbmodem_lib/usbmodem.cpp:481 failed on setup sim handler
2017-03-08T22:28:10+01:00 DiskStation synousbmodemd: usbmodem_lib/usbmodem_list.cpp:116 Failed to init info [7002]
2017-03-08T22:28:10+01:00 DiskStation synousbmodemd: usbmodem_lib/usbmodem.cpp:709 USBModem [7002] is not inited
Don't know if that is recently or always there, never looked at that logfile before.
Anyway, I use http://www.jadahl.com/domoticz_beta_6.1/ on a Syno 1513+ with a rfxcom and Aeotec Gen5 zwave stick.
The var folder of domoticz is moved to a usb stick so the disks aren't constantly in use.
Any ideas?
