Skef
Re: Domoticz app 2.0
Exactly the same here... No geofencing options in the app available...
pro2call
- Domoticz version: 2020.2
Here also
- galadril
- Domoticz version: latest
Hmm i need to look into the geofence switch issue.. (can't reproduce it at this moment..)Skef wrote:Exactly the same here... No geofencing options in the app available...
Changelog for latest release:
- Improved notifications (subject/body/prio)
- Clear notifications setting
- Enable/Disable Events
- Enable/Disable Geofences
- Rebuild Geofence services
- New location screen for adding Geofences
- Change dimmer layouts
- Fixed favorite like button
- Improve Temperature rows
- Improve settings import/export
- Updated libraries
- Various fixes
Skef
I also have a problem when I go to the server settings. I use the advanced settings to have a different server-address when connected to the home wifi network.
I do see the toggle there that I use another server-address, but for some reason the panel with the config is not displayed. This is also the case with the geofencing: the toggle button is there, but when you enable it the panel with the settings doesn't show up.
So it might be a more general bug, that toggles aren't working anymore?
NiklasO
- Target OS: -
So, the background on all my Domoticz widgets goes back to white almost every time I update the beta app. Why? I have to remove them and place them again to get my dark background back and I have like 15 widgets I need to change every time. Could you set the default background in the settings for the main app or something?
- galadril
Found the bug.. new version on tha waypro2call wrote:Here also
Skef
Great work! Thank you!galadril wrote:Found the bug.. new version on tha waypro2call wrote:Here also
pvl01
Same over here on my galaxy Xcover 3. Even after today's update, no Geofencing. I can toggle the switch, but nothing happens. On my galaxy TAB S it works ok and see the "add" button to enter a location. Perhaps someting to do with the screen resolution. ( on my xcover 3 800 x 480)
With new version it correct the bug of geofence. Thanks
PSYCHOTIC
Please fix the widgets i keep having problems with them.
All the below widgets are switches now they have the alarm status..
Thx
After a reboot they look different...
Thx
- widgeterr4.jpg (76.32 KiB) Viewed 3029 times
- widgeterr3.jpg (77.4 KiB) Viewed 3032 times
pvklink
- Domoticz version: latest b
SSL problem after latest update
I have two payed premium versions running on two android devices. One is working well with HTTPS/SSL, the other is only working with HTTP and did work before the latest upgrade with HTTPS. I tried everything, clear cache, deleted the entire app.....
The only thing that was different when upgrading, was that the device that is working with HTTPS asked for a new certificate when installing the upgrade...The other device didnt ask for an update of the certificate...
The error with HTTPS is: connection time out
Jablotron connection, Ikea
- Brutus
Its working again. Nice update on the google maps for geofencing.galadril wrote:Found the bug.. new version on tha waypro2call wrote:Here also
1x Intel NUC8i5BEK (Windows 10 x64) Domoticz on Virtualbox with DietPi.
1x Aeon Labs USB Z-Stick S2
1x P1 Smart Meter USB
28x Fibaro Modules
SMA Solar System
Daikin Airco / Heating
Denon DHT-S716H & DSW-1H
28x Fibaro Modules
SMA Solar System
Skippiemanz
- Domoticz version: 4.10233
Re: RE: Re: Domoticz app 2.0
Anyone else experiencing that you can't select virtuele switches etc on the New geofancing setup?Brutus wrote:Its working again. Nice update on the google maps for geofencing.galadril wrote:Found the bug.. new version on tha waypro2call wrote:Here also
pvl01
Skippiemanz wrote:Anyone else experiencing that you can't select virtuele switches etc on the New geofancing setup?Brutus wrote:Its working again. Nice update on the google maps for geofencing.galadril wrote:
Still no "add" button in geofencing after the update off today.
- galadril
Anyone else??pvl01 wrote:Still no "add" button in geofencing after the update off today.
Because it's definitly working at my side now... ?
Skippiemanz
Re: RE: Re: RE: Re: Domoticz app 2.0
It's working here! But like mentioned before i can't choose from al my switches. Just a few and definetly no virtual switchesgaladril wrote:Anyone else??pvl01 wrote:Still no "add" button in geofencing after the update off today.
*EDIT* solved after restart of phone/app!
pvl01
Skippiemanz wrote:It's working here! But like mentioned before i can't choose from al my switches. Just a few and definetly no virtual switchesgaladril wrote:Anyone else??pvl01 wrote:Still no "add" button in geofencing after the update off today.
I'am sorry, but still no "add" button after enable geofences. Installed new version Version 0.1.374 (2439) and restarted phone.
Wobbles
- Domoticz version: 3.8153
I have the same issue after the last update (now version 0.1.374). When I try to enable Geofencing no add button (I still see the fences I added before) and geofencing is disabled again.galadril wrote:Anyone else??pvl01 wrote:Still no "add" button in geofencing after the update off today.
I have cleared the cache, reinstalled the app, rebooted the phone after each step but still not working.
It was working until I disabled and enabled geofencing, from that point on it was not possible to add a new geofence or have it enabled again. I did this because after the update it was draining my battery for starting to request the GPS position every 10 seconds...
Raspberry PI 1, Raspberry PI 2 & Raspberry PI 3, RFXCom, Z-Wave(Aeotec ZW090 Z-Stick Gen5), Philips HUE and using the premium android app
hofst01
- Domoticz version: 2023.1
hofst01
I have the same issue too on version 0.1.374 (2439). Android on Samsung S5 mini. After activating the switch for Geofencing nothing appears. On my Samsung tablet in the right corner a button "Toevoegen" appears and I can add a geofence. On my smartphone there is no button "Toevoegen". I think this is the issue. Can this be solved?
PSYCHOTIC
PSYCHOTIC wrote:Please fix the widgets i keep having problems with them.![]()
All the below widgets are switches now they have the alarm status..![]()
Thx
Guys any update on how to fix this ?
