Skef
Re: Domoticz app 2.0
Post by Skef »
Exactly the same here... No geofencing options in the app available...
pro2call
Post by pro2call »
Here also
galadril
Domoticz version: latest
Post by galadril »
Skef wrote:Exactly the same here... No geofencing options in the app available...
Hmm i need to look into the geofence switch issue.. (can't reproduce it at this moment..)
Changelog for latest release:
- Improved notifications (subject/body/prio)
- Clear notifications setting
- Enable/Disable Events
- Enable/Disable Geofences
- Rebuild Geofence services
- New location screen for adding Geofences
- Change dimmer layouts
- Fixed favorite like button
- Improve Temperature rows
- Improve settings import/export
- Updated libraries
- Various fixes
Skef
Post by Skef »
I also have a problem when I go to the server settings. I use the advanced settings to have a different server-address when connected to the home wifi network.
I do see the toggle there that I use another server-address, but for some reason the panel with the config is not displayed. This is also the case with the geofencing: the toggle button is there, but when you enable it the panel with the settings doesn't show up.
So it might be a more general bug, that toggles aren't working anymore?
NiklasO
Post by NiklasO »
So, the background on all my Domoticz widgets goes back to white almost every time I update the beta app. Why? I have to remove them and place them again to get my dark background back and I have like 15 widgets I need to change every time. Could you set the default background in the settings for the main app or something?
galadril
Post by galadril »
pro2call wrote:Here also
Found the bug.. new version on tha way
Skef
Post by Skef »
Great work! Thank you!
pvl01
Post by pvl01 »
Same over here on my galaxy Xcover 3. Even after today's update, no Geofencing. I can toggle the switch, but nothing happens. On my galaxy TAB S it works ok and see the "add" button to enter a location. Perhaps someting to do with the screen resolution. ( on my xcover 3 800 x 480)
sbaloo
Post by sbaloo »
With new version it correct the bug of geofence. Thanks :D :D :D
PSYCHOTIC
Post by PSYCHOTIC »
Please fix the widgets i keep having problems with them. :cry:
All the below widgets are switches now they have the alarm status.. :? :? :?
Thx
After a reboot they look different...
pvklink
Domoticz version: latest b
SSL problem after latest update
Post by pvklink »
I have two payed premium versions running on two android devices. One is working well with HTTPS/SSL, the other is only working with HTTP and did work before the latest upgrade with HTTPS. I tried everything, clear cache, deleted the entire app.....
The only thing that was different when upgrading, was that the device that is working with HTTPS asked for a new certificate when installing the upgrade...The other device didnt ask for an update of the certificate...
The error with HTTPS is: connection time out
Jablotron connection, Ikea
Brutus
Post by Brutus »
Its working again. Nice update on the google maps for geofencing.
1x Intel NUC8i5BEK (Windows 10 x64) Domoticz on Virtualbox with DietPi.
1x Aeon Labs USB Z-Stick S2
1x P1 Smart Meter USB
28x Fibaro Modules
SMA Solar System
Daikin Airco / Heating
Denon DHT-S716H & DSW-1H
Skippiemanz
Domoticz version: 4.10233
Re: RE: Re: Domoticz app 2.0
Post by Skippiemanz »
Anyone else experiencing that you can't select virtuele switches etc on the New geofancing setup?
pvl01
Post by pvl01 »
Still no "add" button in geofencing after the update off today. :cry:
galadril
Post by galadril »
pvl01 wrote:Still no "add" button in geofencing after the update off today. :cry:
Anyone else??
Because it's definitly working at my side now... ?
Skippiemanz
Re: RE: Re: RE: Re: Domoticz app 2.0
Anyone else??
It's working here! But like mentioned before i can't choose from al my switches. Just a few and definetly no virtual switches
*EDIT* solved after restart of phone/app!
pvl01
Post by pvl01 »
Skippiemanz wrote:
Anyone else??
I'am sorry, but still no "add" button after enable geofences. Installed new version Version 0.1.374 (2439) and restarted phone.
Wobbles
Domoticz version: 3.8153
Post by Wobbles »
Anyone else??
I have the same issue after the last update (now version 0.1.374). When I try to enable Geofencing no add button (I still see the fences I added before) and geofencing is disabled again.
I have cleared the cache, reinstalled the app, rebooted the phone after each step but still not working.
It was working until I disabled and enabled geofencing, from that point on it was not possible to add a new geofence or have it enabled again. I did this because after the update it was draining my battery for starting to request the GPS position every 10 seconds...
Raspberry PI 1, Raspberry PI 2 & Raspberry PI 3, RFXCom, Z-Wave(Aeotec ZW090 Z-Stick Gen5), Philips HUE and using the premium android app
hofst01
Domoticz version: 2023.1
hofst01
Post by hofst01 »
I have the same issue too on version 0.1.374 (2439). Android on Samsung S5 mini. After activating the switch for Geofencing nothing appears. On my Samsung tablet in the right corner a button "Toevoegen" appears and I can add a geofence. On my smartphone there is no button "Toevoegen". I think this is the issue. Can this be solved?
PSYCHOTIC
Post by PSYCHOTIC »
PSYCHOTIC wrote:Please fix the widgets i keep having problems with them. :cry:
Thx
Guys any update on how to fix this ?
