Etekcity Smart Wireless Electrical Outlet
tedmtl
Domoticz version: v3.5641
Post by tedmtl »
I have bought a Etekcity Smart Wireless Electrical Outlet from amazon.ca (https://www.amazon.ca/Etekcity-Wireless ... cal+Outlet)
i try to control it from domoticz through Rfrxtrx433,
In RFXmngr, i can turn on and off the outlet (housecode=H, unitcode=1-3)
By can't add it as dimmer to domoticz, only housecodes A to D are available for Energenie 5-gang ?
Lighting1 command
Packettype = Lighting1
subtype = Energenie 5-gang, Etekcity
Sequence nbr = 3
housecode = H
unitcode = 3
Command = Off
Signal level = 0 -120dBm
is there a way to get it work in domoticz ?
2016-09-14 07_29_45-Domoticz - Internet Explorer.png (21.08 KiB) Viewed 2145 times
apm
Re: Etekcity Smart Wireless Electrical Outlet
Post by apm »
Did you get this working at all ?
RPi + RFXCOM
Lightwave RF, ByeByeStandby, Generic Temp sensors, OWL, TRC02 RGB Controllers, HIVE
Next Projects: Rain sensor, Cameras.
apm
Post by apm »
After some fiddling I got mine working on latest firmware 1015 and latest Domoticz beta 3.6707 - it will not auto-detect but manual switch adding works fine - you might have to change the house number settings "J" worked for mine perfectly http://imgur.com/a/dQOzh
RPi + RFXCOM
morilm
Target OS: OS X
Post by morilm »
I have received a 5pack today.
I have been able to auto create the switch automatically (using Rflink usb on a Pi3). The devices are detected as TriState.
regards,
Miguel
HM31
Post by HM31 »
Received a pack of 5 this week. Couldn't have it added automaticaly (Domoticz Version: 3.7324 and RFXCOM - RFXtrx433 USB 433.92MHz Transceiver Version: Ext/1015).
Found Housecode A and unitcode 5 or 10 can control all the plugs at once (on and off) but couldn't find a way to control each of them.
HM31
Post by HM31 »
Contacted RFXCOM team, my model is not supported :
"The supported version is a P300 type and your version is a ?Rx type.
The Etekcity P300 remote is not received but you could add the Energenie5 device as an additional remote to the module."
Then I put each of the plugs in learning mode, one by one, and send each of them the house-unit combination I decided for each of them and it works. It was added has another remote, it didn't replace actual remote. Thus I can use each of the remote using Domoticz and the genuine remote.
