Yet another frontpage
SwordFish
Domoticz version: V4.11375
Re: Yet another frontpage
Post by SwordFish »
verry nice frontpage. But I have kaku dimmers and these works in steps so when i use the slider the kaku dimmer respons only between 0% and 16% and from 16% it is alway 100% for the light. Is there a way to change this for kaku dimmers?
HansLe
Domoticz version: V2.3530
Post by HansLe »
You have to define a new class, f.e. kakudimmers. See how the heaters are defined.
Raspberry Pi B+ | Domoticz v3.4834 | RFXtrx433E | Action sockets and remote control (a cheap solution to start with)
Sonos device: control via Action remote control and EasySonos (via Domoticz scripts)
2 x Chresta TX320, Kaku sensoren, D-link camera
h143
Post by h143 »
HansLe wrote:@arnoldg:
you have added this code to?
				} else if(element.hasClass("datavalue")) {
					that.updateWidget.datavalue(element, result);
Can you add the console log line:
		datavalue: function(element, result) {                // 1-2 toegevoegd
			var datavalue = result.Data ;
			console.log ( "Datavalue: " + result.idx + " " + result.Usage);
I use chrome to inspect what happens:
After changing the code
refresh the page with the box
right click your mouse
select inspect
select tab console
you see there the printed line? If not use some more console.log statements to investigate where it's going wrong.
i don't get also my elctric and gas usage in this frontpage,
i have do your steps but the frontpage shows only ...
daandamhuis
Domoticz version: 2.4608
Post by daandamhuis »
I've just configured the Web Interface, and it's working great. But is their an example to configure / include a Chromecast and Selector Switches?
Thanks in advance!
RPi Model 2: Domoticz Server (Beta)
RPi Model B+: Smart Meter Slave (Stable)
Particle Photon (2x): Prototyping, Controlling LEDS and gathering Sensor data for Domoticz
Arduino Uno R3: with CC2500 Shield for Philips LivingColor Lights 1st Gen.
HansLe
Post by HansLe »
@arnoldg
Change line:
<div class="box" data-domoticz-id="60" data-status="true"">
to
<div class="box datavalue" data-domoticz-id="60" data-status="true"">
and it will work.
arnoldg wrote:i can't get it to work, below is the output of the json string.
i wan't to use ID:60 and the usage output.
that is not the problem, in domoticz.js a read this
         	var datavalue = result.Usage;
         // Update the datavalue itself
         eleme....
but it doesn't display the value to the screen, is there a way to see what is going wrong.
HTML code on the site
           		<div class="col col-md-2 col-sm-2 col-xs-2">
        				<div class="box-header box-solid box-info with-border bg-red ">
            				<h3 class="box-title">Elektra</h3>
			            </div><!-- /.box-header> -->
            		     <h4><div class="box-body datavalue">...</div></h4>
                 		<!-- /.box-body -->
		        	</div><!-- /.box -->
            	</div><!-- /.col -->
the rest is just as you descript.
please tell me what i do wrong.
   "ActTime" : 1455731410,
   "ServerTime" : "2016-02-17 18:50:10",
   "Sunrise" : "07:47",
   "Sunset" : "17:47",
   "result" : [
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "BatteryLevel" : 255,
         "CustomImage" : 0,
         "Data" : "On, Level: 100 %",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 12,
         "HardwareName" : "Mysensor serial",
         "HardwareType" : "MySensors Gateway USB",
         "HardwareTypeVal" : 41,
         "HaveDimmer" : true,
         "HaveGroupCmd" : true,
         "HaveTimeout" : false,
         "ID" : "0000064",
         "Image" : "Light",
         "IsSubDevice" : false,
         "LastUpdate" : "2016-02-17 17:35:03",
         "Level" : 100,
         "LevelInt" : 15,
         "MaxDimLevel" : 15,
         "Name" : "Bank",
         "Notifications" : "false",
         "PlanID" : "2",
         "PlanIDs" : [ 2 ],
         "Protected" : false,
         "ShowNotifications" : true,
         "SignalLevel" : "-",
         "Status" : "On",
         "StrParam1" : "",
         "StrParam2" : "",
         "SubType" : "AC",
         "SwitchType" : "On/Off",
         "SwitchTypeVal" : 0,
         "Timers" : "false",
         "Type" : "Lighting 2",
         "TypeImg" : "lightbulb",
         "Unit" : 3,
         "Used" : 1,
         "UsedByCamera" : false,
         "XOffset" : "339",
         "YOffset" : "255",
         "idx" : "103"
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 12,
         "ID" : "0000064",
         "Image" : "Light",
         "Level" : 100,
         "LevelInt" : 15,
         "MaxDimLevel" : 15,
         "Name" : "Computer",
         "PlanID" : "2",
         "PlanIDs" : [ 2 ],
         "Status" : "On",
         "StrParam1" : "",
         "StrParam2" : "",
         "SubType" : "AC",
         "Timers" : "false",
         "Unit" : 2,
         "Used" : 1,
         "XOffset" : "103",
         "YOffset" : "316",
         "idx" : "102"
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 12,
         "ID" : "0000064",
         "Image" : "Light",
         "LastUpdate" : "2016-02-17 17:35:05",
         "Level" : 100,
         "LevelInt" : 15,
         "MaxDimLevel" : 15,
         "Name" : "TV",
         "PlanID" : "2",
         "PlanIDs" : [ 2 ],
         "Status" : "On",
         "StrParam1" : "",
         "StrParam2" : "",
         "SubType" : "AC",
         "Timers" : "false",
         "Unit" : 5,
         "Used" : 1,
         "XOffset" : "145",
         "YOffset" : "171",
         "idx" : "105"
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 12,
         "ID" : "0000064",
         "Image" : "Light",
         "LastUpdate" : "2016-02-17 18:25:33",
         "Level" : 100,
         "LevelInt" : 15,
         "MaxDimLevel" : 15,
         "Name" : "Vensterbank",
         "PlanID" : "2",
         "PlanIDs" : [ 2 ],
         "Status" : "On",
         "StrParam1" : "",
         "StrParam2" : "",
         "SubType" : "AC",
         "Timers" : "false",
         "Unit" : 4,
         "Used" : 1,
         "XOffset" : "310",
         "YOffset" : "55",
         "idx" : "104"
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "21.0",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 13,
         "HardwareName" : "Opentherm",
         "HardwareType" : "OpenTherm Gateway USB",
         "HardwareTypeVal" : 18,
         "ID" : "0000005",
         "LastUpdate" : "2016-02-17 18:49:44",
         "Name" : "Room Setpoint",
         "PlanID" : "2",
         "PlanIDs" : [ 2 ],
         "SetPoint" : "21.0",
         "SubType" : "SetPoint",
         "Timers" : "false",
         "Type" : "Thermostat",
         "TypeImg" : "override_mini",
         "Unit" : 0,
         "Used" : 1,
         "XOffset" : "248",
         "YOffset" : "140",
         "idx" : "142"
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "21.0 C",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 13,
         "ID" : "0008",
         "Name" : "Room Temperature",
         "PlanID" : "2",
         "PlanIDs" : [ 2 ],
         "SubType" : "TFA 30.3133",
         "Temp" : 21.0,
         "Timers" : "false",
         "Type" : "Temp",
         "TypeImg" : "temperature",
         "Unit" : 8,
         "Used" : 1,
         "XOffset" : "95",
         "YOffset" : "419",
         "idx" : "143"
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "Counter" : "1267.663",
         "CounterDeliv" : "0.000",
         "CounterDelivToday" : "0.000 kWh",
         "CounterToday" : "6.692 kWh",
         "CustomImage" : 0,
         "Data" : "538022;729641;0;0;528;0",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 10,
         "HardwareName" : "Smart meter",
         "HardwareType" : "P1 Smart Meter USB",
         "HardwareTypeVal" : 4,
         "ID" : "1",
         "LastUpdate" : "2016-02-17 18:50:02",
         "Name" : "Elektra",
         "PlanID" : "2",
         "PlanIDs" : [ 2 ],
         "SubType" : "Energy",
         "Timers" : "false",
         "Type" : "P1 Smart Meter",
         "TypeImg" : "counter",
         "Unit" : 1,
         "Usage" : "528 Watt",
         "UsageDeliv" : "0 Watt",
         "Used" : 1,
         "XOffset" : "91",
         "YOffset" : "26",
         "idx" : "60"
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 10,
         "Data" : "Off",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 13,
         "ID" : "0000071",
         "Image" : "Fireplace",
         "LastUpdate" : "2016-02-17 18:45:14",
         "Level" : 0,
         "LevelInt" : 0,
         "MaxDimLevel" : 15,
         "Name" : "FlameOn",
         "PlanID" : "2",
         "PlanIDs" : [ 2 ],
         "Status" : "Off",
         "StrParam1" : "",
         "StrParam2" : "",
         "SubType" : "AC",
         "Timers" : "false",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "31",
         "YOffset" : "584",
         "idx" : "137"
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 11,
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 13,
         "ID" : "0000066",
         "Image" : "Water",
         "LastUpdate" : "2016-02-13 12:11:52",
         "Level" : 100,
         "LevelInt" : 15,
         "LevelNames" : "Off",
         "MaxDimLevel" : 15,
         "Name" : "DHW_enabled",
         "PlanID" : "2",
         "PlanIDs" : [ 2 ],
         "SelectorStyle" : 0,
         "Status" : "On",
         "StrParam1" : "",
         "StrParam2" : "",
         "SubType" : "AC",
         "SwitchType" : "Selector",
         "SwitchTypeVal" : 18,
         "Timers" : "false",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "31",
         "YOffset" : "533",
         "idx" : "130"
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 15,
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 13,
         "ID" : "0000065",
         "Image" : "Heating",
         "LastUpdate" : "2016-02-17 15:48:11",
         "Level" : 100,
         "LevelInt" : 15,
         "MaxDimLevel" : 15,
         "Name" : "CH_enabled",
         "PlanID" : "2",
         "PlanIDs" : [ 2 ],
         "Status" : "On",
         "StrParam1" : "",
         "StrParam2" : "",
         "SubType" : "AC",
         "Timers" : "false",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "33",
         "YOffset" : "484",
         "idx" : "129"
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 12,
         "ID" : "0000064",
         "Image" : "Light",
         "LastUpdate" : "2016-02-17 17:30:49",
         "Level" : 100,
         "LevelInt" : 15,
         "MaxDimLevel" : 15,
         "Name" : "Keuken",
         "PlanID" : "2",
         "PlanIDs" : [ 2 ],
         "Status" : "On",
         "StrParam1" : "",
         "StrParam2" : "",
         "SubType" : "AC",
         "Timers" : "false",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "101"
   "status" : "OK",
   "title" : "Devices"
daandamhuis
Got the Gas and Electricity working. Thanks for the example @HansLe.
Dashboard
Dashboard
Schermafbeelding 2016-02-24 om 18.15.52.png (97.75 KiB) Viewed 7375 times
wauwturrr
Domoticz version: 2.3530
Post by wauwturrr »
Really love this theme. Using it with a tablet attached to the wall. There are only 2 things i just can't get solved..
When you have your heater connected with a OpenTherm Gateway, the temperate can only be turned up by 1 degree per slide. Is there someone who allready made it working with just 0.5 degree per slide? (i know it might sound quite silly..). I've also tested some things with the chromecast, but it seems to be not working anymore.. Someone who also solved that?
Last van trage WiFi? unifikopen.nl
daandamhuis
wauwturrr wrote:I've also tested some things with the chromecast, but it seems to be not working anymore.. Someone who also solved that?
Currently I don't have a solution, you can use cURL commands to get the JSON response! (http://fiquett.com/2013/07/chromecast-traffic-sniffing/)
petergab94
Post by petergab94 »
The switch command works fine, ... good frontpage ! i love !
the scroll bars are not changed ?
it's normal ? it can not be varied ?
ok HS for chrome .. ok mozilla !
clubeddie
Post by clubeddie »
Project still Alive?
fverdonk
Post by fverdonk »
hi all, i like to use this good looking front page but a failed to get it working.
Maybe someone can have a look wat step went wrong.
From the readme
## Getting started
* Copy `custom/js/settings.example.js` to `custom/js/settings.js` and configure the settings: done
* Add a rectangular user image to `custom/img/user.jpg`: can not find it
* Create a roomplan in Domoticz that contains all devices you want to see/control in the dashboard : done
After this i connect the server via:
http://192.168.178.35:8080/frontpage.html
But all i get is that Domoticz is offline.
May it is something stupid but i do not know where to find it.
Hw Raspberry PI model 2 Domoticz V3.4834 RFXcom and Z-wave
Kind Regards Frank
satanasinc
Domoticz version: 4.9700
Post by satanasinc »
Hi!
Nice dashboard. Installed and runnig without problems.
Very good job!
Thank you.
Greetings from spain!
qwerk
Post by qwerk »
fverdonk wrote:hi all, i like to use this good looking front page but a failed to get it working.
From the readme
## Getting started
Kind Regards Frank
Hi, I had the same problem when I installed this this morning.
When I go to http://domoticz/frontpage/index.html then its working ;-)
regards
fverdonk
Post by fverdonk »
Thanks that was it.!!
rg Frank
clubeddie
Post by clubeddie »
daandamhuis wrote:Got the Gas and Electricity working. Thanks for the example @HansLe.
I have tried to implement the gas and electricity also, only i cannot get two values. I want to show the daily usage and the actual usage.
So for electricity i want to use the values: 'CounterToday' and 'Usage'
So i added below in domotics.js
} else if(element.hasClass("actueelverbruik")) {
					that.updateWidget.actueelverbruik(element, result);
				} else if(element.hasClass("totaalverbruik")) {
					that.updateWidget.totaalverbruik(element, result);
And also:
actueelverbruik: function(element, result) {
         var actueelverbruik = result.Usage ;
         // Update the actueelverbruik itself
         element.find(".datavalue" ).html(actueelverbruik);
         // Also do generic updating
         this.generic(element, result);
	  totaalverbruik: function(element, result) {
         var totaalverbruik = result.CounterToday ;
         // Update the totaalverbruik itself
         element.find(".datavalue" ).html(totaalverbruik);
This is working, if i add for example actueel usage like below:
<div class="col col-md-4 col-sm-4 col-xs-2">
               <div class="box actueelverbruik" data-domoticz-id="26" data-status="true"">
                        <h3 class="box-title">Actueel verbruik</h3>
                       <!-- /.box-body -->
I get
If i change this code in:
               <div class="box totaalverbruik" data-domoticz-id="26" data-status="true"">
                        <h3 class="box-title">Totaal verbruik</h3>
                       <!-- /.box-body -->
I get
If i place both boxes like:
                       <!-- /.box-body -->
                       <!-- /.box-body -->
I get:
So it shows only the actual usage in both boxes... i am starring at it... but i cannot find it. Hope someone can see what i am doing wrong!
clubeddie
Post by clubeddie »
Solved it, some adjustments in domoticz.js did the trick.
Now starting to implement traffic information and some other iframe stuff like google calendar and squeezebox.
Has anyone sees the AdminLTE2 interface, it would be awesome if you can show the certain graphics like powerconsumption like in this example
See https://almsaeedstudio.com/themes/AdminLTE/index2.html
blauwebuis
Domoticz version: current
Post by blauwebuis »
Wow, this is stellar.
Could Domoticz use one of the great themes that have been developed as the new default?
gijsdevries
Post by gijsdevries »
its verry nice, i have a tablet on the livingroom with this frontpage, my girlfriend likes it ;)
would be nice if there are people who can make extra things in. such as current temp a thermostat. as in my living room and barn.
attached a few pictures
bsmeding
Post by bsmeding »
I'm also start using this frontpage a couple of months ago.
It is a very nice frontpage but I don't understand that there are not more people using this. I'm not that fimilar with javascript so it takes a lot of time for me to understand and create extra addons. I'm now trying to port the sonos function to another API. I use the Sonos HTTP API http://www.domoticz.com/forum/viewtopic.php?f=4&t=15365 instead of the Sonos web https://github.com/roberthorlings/sonos-web
when i have an updates version i will post it here, but with the spare time i currently have it will not be very soon
EdwinK
Post by EdwinK »
I agree that this is a nice thee, but setting it up is a bit of a pain. So, therefore I'm using the theme from G3rard, that is much easier to setting up. Then again, I' still very new to the world of Domoticz so who knows I might switch at a later day.
Users browsing this forum: BarryT and 1 guest
