I have some issues using you're tutorial:Any issues using the Xiaomi Gateway with Domoticz?
In above part, I choose the toggle switch to enable de LAN mode and write down the password. I then click OK in the right bottom area to save the changes. Which I see with an answer to be correct.https://www.domoticz.com/wiki/Xiaomi_Gateway_(Aqara)
Adding the Xiaomi Gateway to Domoticz:
After those steps I fill in the new hardware and password in Domoticz and click add (update)
The log file says: XiaomiGateway: Worker started...
And I can see the new hardware in Domoticz.
After those steps nothing happens in Domoticz. No Xiaomi Gateway appears at the devices en no other devices (already connected to the gateway) do appear.
To check my password and settings in the app after that I surprisingly see a new password and no toggled LAN switch! It seems I cannot save the setting in the xiaomi app on my phone.
Do you have any ideas to correct this?
