EdwinK
Post by EdwinK »
Yup... I see the following:
It's looking for '192.168.1.102', but I don't have that ip-address, and I can't find in what file it does call this.
G3rard
Domoticz version: No
Post by G3rard »
The 192.168.1.102:8084 is from my Domoticz settings. That means you haven't changed that in frontpage_settings.js.
So change that line to your Domoticz settings and that should work.
The 192.168.1.1 for the videostream is in line 290 of frontpage.html. So you can change that as well (or remove it).
Check this readme instruction .
Not using Domoticz anymore
G3rard
Post by G3rard »
Trigun wrote:
Hi G3rard,
I was looking at this post and this is exactly what I would like to use.
I am able to control the sonos via HTTP but I can't get it to work with the PHP option in G3rards files.
perhaps you can help me out here?
maybe a noob question but how do I install the PHP server on the Domoticz Pi?
Thanks in advance!
Kind regards,
Is your question regarding installing PHP on a Pi? Then check this.
If you have any questions regarding the config of the Sonos files, then show some more info on your setup and what is not working.
G3rard
Post by G3rard »
hpapagaj wrote:
G3rard wrote:@hpapagaj,
Can you try this
var d = ((level + 10)/100 * 32) +  0.5;
Super it's working now. :P Thank you!
Little glitch that one step is 6% instead of 3% (like in Domoticz):
50 to 56:
plus 50
in plus 19.7 50
SUCCES
56 to 62:
plus 56
in plus 21.62 56
SUCCES
Then just try to change the formula until it works for you.
Something like
var d = ((level + 10)/100 * 31) +  0.3;
should do the trick.
EdwinK
Post by EdwinK »
G3rard wrote:The 192.168.1.102:8084 is from my Domoticz settings. That means you haven't changed that in frontpage_settings.js.
I had it changed. See below
// #### vvvvv   USER VALUES below vvvvv   #######
$(document).ready(function() {
        $.roomplan=0;	// define roomplan in Domoticz and create items below.
        $.domoticzurl="http://192.168.0.10:8084";
		//format: idx, value, label, description, lastseen(1 when lastseen is wanted, 2 is only time), plusmin button or protected (0 for empty, 1 for buttons, 2 for volume of Sonos, 4 for protected, 5 for zwave dimmer, 6 for protected when on), [override css], [alarm value]
        $.PageArray = [
g3rard wrote: The 192.168.1.1 for the videostream is in line 290 of frontpage.html. So you can change that as well (or remove it).
I had this line commented out with <!-- -->, but somehow that line was still being executed.
G3rard
Post by G3rard »
My guess would be that you have 2 frontpages and changed the settings in one of them, but open the other.
Because the log shows that it tries to open 192.168.1.102:8084 and that URL is only present in frontpage_settings.js.
https://github.com/gerard33/frontpage/s ... .168.1.102
Same applies for frontpage.html. Because if you have commented that line out, it will not try to open the url.
EdwinK
Post by EdwinK »
That might have be the problem, because now it isn't trying to connect to the cam's anymore. :)
RobvdB
Post by RobvdB »
I've been busting my balls over this one. I have Gerards frontpage on an old ipad on the wall. all works like a charm, except for one wish. I have two camera's in screen 1 and 2, cell 3 and cell 2_3. I get a still image from these camera's, but what i want is a moving image. Adding in the stream URL does not work, and I think it never will due to lack of codec support on the ipad.
My question; how and where can I add a script of some kind to refresh the image every second. Or at least refresh when I tap it?
I've tried to add the below code in frontpage.js, but no luck:
function updateCamera() {
	var d = new Date();
	var t = d.getTime();
	document.getElementById("popup_camera").src="http://<IPADDRESS>/cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=******&pwd=********&"+t;
	document.getElementById("popup_camera3").src="http://<IPADDRESS>/snapshot.cgi?user=*****&pwd=*****&"+t;
setInterval(updateCamera,1000);
Hope someone can help me with this, since I'm going crazy ;)
Synology DS213, RFXtrx433E, COCO, HomeEasy, Promax, Denon, Philips TV, Logitech Harmony, Nest, Smart meters.
ropske
Domoticz version: V3_8394
Post by ropske »
hi, anyone using setpoint in this FrontPage?
I'm just wondering if it's also taking some seconds with you guys when it changes state? guess 2-3 seconds
so when i want to go from 16degrees to for example 20degrees, this takes long
i'm going up/down by steps off 0.5degree so i need to press 8 times on the temp up button (8x2sec = 16sec)
RobvdB
Post by RobvdB »
I'm using it. The same issue here too. The frontpage refreshes every few seconds, and in addition the path for an update of your setpoint is frontpage > domoticz > Nest cloud > domoticz > frontpage. So that adds some extra time.
As a suggestion it could be handy to open a small popup, set the value you want locally in frontpage, and then update accordingly. But I lack the skills to code that I'm afraid :-)
ropske
Post by ropske »
yeah, like the popup-window now in domoticz when you change a setpoint
franzelare
Post by franzelare »
I like to add some graphs to my frontpage, anyone who knows how to do that? like by using the highcharts function that domoticz web interface is using?
EdwinK
Post by EdwinK »
I thought I read a fix somewhere in this topic, but can't find it anymore.
What happens is that one of the cell 2_3 I'm using for one of my Pi's (LMS). The title of the playing song is just going all over the place. (see image)
Imageimage post
How can I fix this so that it is just in one cell? Btw.. it was just a random music-list playing
ErwinWes
Post by ErwinWes »
Hi guys,
I see a lot of stuff what I can do with domoticz.
At this moment the only thing that I want is show the outside sensors (wind, rain, temp, etc.)
The only thing that I want is that the graphs are automatically made for use on websites.
How can I do that?
I make use of my Synology NAS in combination with the RFlink 868 mhz receiver.
Thanks for any answer.
barbaar
Post by barbaar »
Right.. Has anyone succeeded with displaying a group?
I have entered the group into the roomplan, and added the line below to frontpage_settings.js:
['1','Status',          'cell11',       'Licht Beneden','1','0'],
The IDX is correct for sure..
But, the cell in Chrome stays empty. When I inspect the element, I get the following error:
Uncaught TypeError: Cannot read property 'length' of undefined
    at Object.<anonymous> (frontpage.js:954)
    at Function.each (jquery.min.js:4)
    at Object.success (frontpage.js:953)
    at c (jquery.min.js:4)
    at Object.fireWith [as resolveWith] (jquery.min.js:4)
    at k (jquery.min.js:6)
    at HTMLScriptElement.n.onload.n.onreadystatechange (jquery.min.js:6)
Line 954 of frontpage.js is:
for( var ii = 0, len = $.PageArray_Scenes.length; ii < len; ii++ ) {
Any help would be appreciated!
ropske
Post by ropske »
anyone that can help us please?
ropske wrote:hi, anyone using setpoint in this FrontPage?
ubfssF
Domoticz version: 2.2364
Post by ubfssF »
barbaar wrote:Right.. Has anyone succeeded with displaying a group?
What works for me is:
	$.PageArray_Scenes = [
	['2','Status',		'cell14',	'Thuis werken','0','0'],
	['1','Status',		'cell15',	'HiFi systemen','0','0'],
barbaar
Post by barbaar »
Works! Great, thanks!
Ewaldharmsen
Post by Ewaldharmsen »
I cannot get it to work.
Add a room, it got IDX 2
Extracted the file two times to get the frontpage.html
Edited line 250 to $.roomplan=2; That is the IDX of the "Ruimte" right?
Edited line 251 to $.domoticzurl="http://192.168.0.116:8080";
Edited line 264 to ['3', 'UVI', 'cell21', 'UV straling (UVI)', 'color:orange', '>4'], as a test
Copied the file to the domoticz/www folder
browsed to 192.168.0.116:8080/frontpage.html, but no numbers there just the plain picture.
http://192.168.0.116:8080/json.htm?type=devices&plan=2 gives me the data I expected
What is going wrong?
Ewaldharmsen
Ah Room needs to be 0
