Is it possible to control a servo with domoticz?
I want to use it to open and close a "downlufter"
(A ventilation opening in a window)
Like: when heating on downlufter close,
When heating off downlufter open
How can this be done?
Servo control
- jvdz
- Domoticz version: 4.107
Re: Servo control
I have 3 servo's, used for tilting my blinds, connected to the raspberry PI.
The position of the servo's is controlled by ServoBlaster on the RPi.
I use a couple of bash script files which translate the position of a dummy dimmer to the correct command for ServoBlaster.
These scripts also ensure the tilting goes smoothly in stead of a quick angle change as it would scare the hell out of everybody.
Jos
Jos
edwin1234
- Domoticz version: 2021.1
Re: Servo control
Thank you for your aswer
could you share the scripts?
- jvdz
Re: Servo control
Sure, but guess they also need some explanation.edwin1234 wrote:could you share the scripts?
Let me explain the basics after which you can have a look and see how much makes sense and what needs more explanation.
Let me start with the basics:
I have 2 Dimmers defined for setting the 3 Blinds, so one controls the first blinds and the second dimmer controls the 2 other blinds.
I have 2 User variable defined which remember the current state of each dimmer, which allows me to calculate the difference after one or both dimmer are changed.
Each dimmer has these lines for action: And the Blinds_Set_run.sh script contains the following code:
#!/bin/bash
#--Set variables
chk=`sudo ps x | grep "Blinds_Set.sh 0" | grep -cv grep`
if [ "$chk" = "0" ] ; then
sh /home/pi/domoticz/scripts/Blinds_Set.sh 0 191 31 Blinds1 >> /var/tmp/blinds1.log 2>&1 &
#--else
#-- echo "$(date +%x) $(date +%X) Blinds_Set.sh is already running" >> /var/tmp/blinds.log
fi
chk=`sudo ps x | grep "Blinds_Set.sh 1" | grep -cv grep`
sh /home/pi/domoticz/scripts/Blinds_Set.sh 1 281 32 Blinds2 >> /var/tmp/blinds2.log 2>&1 &
#--else
fi
You need to update the commands in the script with the correct IDX numbers and devicenames.
The shelled Blinds_Set.sh scripts will check the current status of the dimmer and compare that with the last saved value. In case they differ the servos will be activated in small steps so they slowly change.
This is the actual action script:
#!/bin/bash
# Script to control a Servo via an "Blinds Percentage" device in Domoticz.
#--Set variables
urlpre='http://192.168.?.??:8080/json.htm'
idxBlindDevice=$2
NameBlindDevice="$4"
idxSaveBlindAngle=$3
NameSaveBlindAngle="$4_current_Level"
if [ -z "$1" ] ; then
ServoNummer="0"
ServoNummer="$1"
fi
if [ -z "$5" ] ; then
MaxOpen=0
MaxOpen=$5
fi
#~ pulse traveling 900 to 2100 usec means ServoBlaster needs to send 90-210
ServoMin=90
ServoFlat=110
ServoMax=200
servostep=1
ServoCur=0
ServoNew=0
Speling=0
Direction=0
slowdown=0.03
# set servo level
SetServo()
echo -n "$1;"
#~ echo $ServoNummer=$1
echo $ServoNummer=$1 > /dev/servoblaster
#~ Get current Levels and new level
echo "`date +"%x %X"` =================================================================================================================================================="
Result=`curl -s "$urlpre?type=devices&rid=$idxBlindDevice"`
BlindsMax=`echo "$Result"| /usr/local/bin/jq -r '.result[]|.MaxDimLevel'`
Blindsflat=$(((ServoMax-ServoFlat)/(ServoMax-ServoMin)*BlindsMax))
#~ echo "$urlpre?type=devices&rid=$idxBlindDevice"
BlindsNewStatus=`echo "$Result"| /usr/local/bin/jq -r '.result[]|.Status'`
ServoTotalSteps=$((ServoMax-ServoFlat))
ServoCur=`curl -s "$urlpre?type=command¶m=getuservariable&idx=$idxSaveBlindAngle"| /usr/local/bin/jq -r '.result[]|.Value'`
if [ $ServoCur -lt $ServoMin ]; then
ServoCur=$ServoMin
fi
if [ $ServoCur -gt $ServoMax ]; then
ServoCur=$ServoMax
fi
if [ "$BlindsNewStatus" = "Closed" ]; then
BlindsNewAngle=$BlindsMax
ServoNew=$ServoMax
elif [ "$BlindsNewStatus" = "Open" ]; then
BlindsNewAngle=$Blindsflat
ServoNew=$ServoFlat
BlindsNewAngle=`echo "$Result"| /usr/local/bin/jq -r '.result[]|.LevelInt'`
ServoNew=$((BlindsNewAngle*ServoTotalSteps/BlindsMax+ServoFlat))
fi
## Opion to open the blinds Maximal
if [ $MaxOpen -eq 1 ]; then
ServoNew=$ServoMin
fi
#~ BlindsMax=`curl -s "$urlpre?type=devices&rid=$idxBlindDevice"| /usr/local/bin/jq -r '.result[]|.MaxDimLevel'`
#~ BlindsNewAngle=`curl -s "$urlpre?type=devices&rid=$idxBlindDevice"| /usr/local/bin/jq -r '.result[]|.LevelInt'`
#~ BlindsCurAngle=`curl -s "$urlpre?type=command¶m=getuservariable&idx=$idxSaveBlindAngle"| /usr/local/bin/jq -r '.result[]|.Value'`
echo -n "`date +"%x %X"` Start changing Blinds angle with Servo $ServoNummer Name $NameBlindDevice"
echo " ServoCur=$ServoCur ServoNew=$ServoNew BlindsNewStatus=$BlindsNewStatus BlindsNewAngle=$BlindsNewAngle"
if [ $ServoNew -eq $ServoCur ]; then
echo "`date +"%x %X"` Nothing to do."
#Calculate the Servo angle
# set the direction
if [ $ServoNew -gt $((ServoCur+servostep-1)) ]; then
Direction=1
fi
echo "`date +"%x %X"` ServoTotalSteps:$ServoTotalSteps ServoCur=$ServoCur ServoNew=$ServoNew Direction=$Direction"
## move the servo a bit at the time to avoid a rapic change of angle
cnt=1
echo -n "`date +"%x %X"` "
while true; do
ServoCur=$((ServoCur+servostep))
elif [ $ServoNew -lt $((ServoCur-servostep+1)) ]; then
ServoCur=$((ServoCur-servostep))
break
fi
SetServo $ServoCur
sleep $slowdown
done
# Update the User variable to save the last set angle
curl -s "$urlpre?type=command¶m=updateuservariable&idx=$idxSaveBlindAngle&vname=$NameSaveBlindAngle&vtype=0&vvalue=$ServoNew"| grep OK > /dev/null
if [ $? -eq 0 ] ; then
echo " "
echo "`date +"%x %X"` Done"
#~ echo "`date +"%x %X"` done updating $NameSaveBlindAngle to BlindsNewAngle=$BlindsNewAngle percentage=$((($ServoCur-ServoMin)*100/ServoTotalSteps))"
echo " "
echo "`date +"%x %X"` Done, but error updating $NameSaveBlindAngle to $ServoNew : ServoCur=$ServoCur percentage=$((($ServoCur-ServoMin)*100/ServoTotalSteps))"
fi
#~ sleep 0.3
#~ echo -n "`date +"%x %X"` done: Stop Servo by sending: "
#~ SetServo 0
#~ echo "Done."
# set slider at corret level when Open or Close was selected and option isn't maxopen
if [ $MaxOpen -ne 1 ]; then
echo "`date +"%x %X"` Closed set so change level to $BlindsMax."
Result=`curl -s "$urlpre?type=command¶m=switchlight&idx=$idxBlindDevice&switchcmd=Set%20Level&level=$BlindsMax"`
#~ echo "$Result"
echo "`date +"%x %X"` Open set so change level to 0."
Result=`curl -s "$urlpre?type=command¶m=switchlight&idx=$idxBlindDevice&switchcmd=Off&level=0"`
fi
fi
fi#~ pulse traveling 900 to 2100 usec means ServoBlaster needs to send 90-210
ServoMin=90 #~ minimal angle value
ServoFlat=110 #~ angle value for the position the blinds are exactly flat (open)
ServoMax=200 #~ maximum angle value
servostep=1 #~ define the change for each step
slowdown=0.03 #~ define the "sleep" between each step
Hope it all makes some sense, but ask away when you have questions.
Jos
edwin1234
Re: Servo control
Thank u very much for your scripts and info,
i let you know if i have questions.
mbunds
Re: Servo control
Thank you for sharing this information. I know it was a while ago, but it was very helpful. I registered here just to tell you "thanks"!JVDZ - Sure, but guess they also need some explanation...
