Last week I've added an second Fibaro dimmer type 2 to my zwave network.
Inclusion was no problem, but only 3 new devices show up in the devices list.
2 times usage and 1 kwh meter (see attached screenshot).
The light itself is not visible as device, so I can't controll the light via Domoticz.
I allready tried removing and adding it again, but still only 3 devices show up.
Is the Fibaro dimmer broke, or am I doing something wrong?
Missing devices with FIBARO System FGD212 Dimmer 2 Topic is solved
tontze
- Domoticz version: Beta Ch
Re: Missing devices with FIBARO System FGD212 Dimmer 2
Did you try to reset it before adding again ?
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
nizaga
question: how many device should show up after adding the FGD212 in total?
or even more general, is there a way to indentify how many domoticz devices should be created after including a zwave device based on the config.xml file?
I have just added for instance a FGD212, reading the fgd212.xml should i be able to get this information? if not, where is the logic to add devices for a specific zwave device?
Thanks,
nim
Thanks,
nim
Gravityz
- Domoticz version: 2025.1
you need to give it more time.
you need a couple of watt devices, kwh devices, lightswitch and scene devices
sometimes you get more than one device which does the same so you have to look which one is active/will react
include the device and make sure you have allow new devices set to on in setup.
after the module is recognized start switching (push switch 1, switch 2)
this will probably generate the devices
with s2 you can generate devices for 1 click, 2 clicks, 3 clicks, click and hold, release.
nizaga
With s2, you connect a cable from another wall switch then?
Enviado desde mi iPhone utilizando Tapatalk Pro
Gravityz
no you connect it to a second switch ne3xt to the first one
something like this
https://nl.dreamstime.com/stock-foto-du ... ge65396668
first switch is S1 which controls the dimming
S2 is the second one which you can program to do anything.
something like this
Duggel
Resetting it did the trick. After resetting and including it, 21 new devices showed uptontze wrote:Did you try to reset it before adding again ?
- Schermafbeelding 2017-01-30 om 13.31.50.png (163.42 KiB) Viewed 1798 times
Gravityz
now you have to check what they do.
also your screenshot shows 2 devices(D and E)
if you have one device then D is probably the old device which does not work anymore so E are the active ones
Users browsing this forum: jvdz and 1 guest
