levynger
Post by levynger »
@corbin, found some issues with my code, the gateway responses used to forcibly update the first switch always.. (unitcode=1).
modfied the code abit, now seems to work fine.
patches are waiting on your git.
@deennoo - your youtube demonstration just cost me 16$ - made me order the cube.. :lol:
deennoo
Post by deennoo »
levynger wrote:@corbin, found some issues with my code, the gateway responses used to forcibly update the first switch always.. (unitcode=1).
@deennoo - your youtube demonstration just cost me 16$ - made me order the cube.. Image
Hopping you get it via my link ! ;-)
This need that corbin put a request on mainworker.cpp and been validate by dev, to allow getting svalues for limitless led device, no way without this fonction.
Once done will provied the magic cube lua script.
http://domo-attitude.fr
pikapt
Post by pikapt »
deennoo wrote:You can set a returne to off by your self using : turn to off timer.
Never thought of using it like this! Awesome thanks!
doelle4
Post by doelle4 »
Newbie with Problems...
Hello i habe setup my Xiaomi Gatey at "Hardware"
Overview shows:
"2017-01-30 00:34:29 ☀▲07:32 ▼16:52
Keine Gerätefavoriten hinzugefügt ... (oder Verbindung verloren!)
Wenn dies Ihr erstes Mal hier ist, bitte Einrichtung vornehmen für Hardware, und binde ein Geräte."
=Chinese Time, Xiaomi Gateway is now right connect or?
But i cant see any Sensor , No Temp or others
What must i do to connect the Sensors ?
Greetings Hans
murtadin
Post by murtadin »
doelle4 wrote:Newbie with Problems...
Overview shows:
Greetings Hans
Have you checked setup/devices? Can you post your log output? setup/log
joebar
Post by joebar »
Maybe a silly question but i can't find it on the web, using Corbin's source now but seeing a lot of (official) beta releases the last days.
Judging by the build number, Corbin's is somewhat changes behind, is there a release note somewhere for the official beta or even a GitHub for the official beta to check?, can only find complied versions, and the what's new in the pop up doesn't display the specific build
joebar
Post by joebar »
Overview shows:
"2017-01-30 00:34:29 Image▲07:32 ▼16:52
Greetings Hans
Did you setup anything yet?, if not check devices and let the gateway detect and report the sensors. So with a button, click and see in the log of that sensor is now detected.
If so, it will be in the devices. For the rest follow first use domoticz (sorry if you already did that)
lamouette
Post by lamouette »
Hello there,
Does somebody is using the Yeelight Ceiling Light with domoticz ?
deennoo
Post by deennoo »
lamouette wrote:Hello there,
As there is no special instruction on Yeelight API this have to work as a normal yeelight product
Please use yeelight topic for this : viewtopic.php?t=13016
lamouette
Post by lamouette »
Merci :)
deennoo
Post by deennoo »
Just test this is half ok for me on debian 8.5 :
- Cube rotation is update on device (clock wise and anti clock wise and on text device,
- Dual wired switch appear as 2 singles switchs turning siwtch 1 on/off is ok but turning switch2 to "off" turn off switch1 too
Great job Guys !
Edit : ok didn't see the pull request who solve this issue, waiting for it
corbin
Post by corbin »
There is a problem with some systems that have multiple network adapters, to fix it I need to specify the local IP address to use. But I can't see anyway with the web interface to add a 'local address'. Anyone have an idea for how to get this into Domoticz (I'd rather not add it to the web interface myself)? Deennoo?
deennoo
Post by deennoo »
Trying to understand.
exemple :
a rpi 3 got both wifi and ethernet wired ok ?
Xiaomi is on the wifi network created by the RPI or where the PI is connected and ip is 192.168.4.x, ethernet is 192.168.0.x ?
As you set Xiaomi ip adresse on config page, all have to be good, this is to user to create a bridge between his 2 networks.
Domoticz don't manage network at all
lamouette
Post by lamouette »
Since few days, let's say, this weekend, 3 more devices appeared on my interface (running v3.6561 at the moment) :
3 light switches which I don't have :?: Any idea :idea: :?:
Other thing, my Wireless switch is only working with the "click" action. "double click" is not working any more.
corbin
Post by corbin »
deennoo wrote:Trying to understand.
exemple :
On some systems with multiple adapters it works ok, on others not. I guess it depends on the configuration. But we have confirmed that specifying the adapter to bind to makes it work on at least one of these systems.
corbin
Post by corbin »
lamouette wrote:Hi,
can you delete all the wireless switches, and see what gets added back in?
lamouette
Post by lamouette »
Done !
waiting to be back at home to make it coming back :mrgreen:
corbin
Post by corbin »
restarting the Xiaomi Gateway under hardware in Domoticz should make it scan for the switches straight away
lamouette
Post by lamouette »
They are back :ugeek:
joebar
Post by joebar »
lamouette wrote:They are back :ugeek:
I had the same, actually it are no new switches, in the example you mentioned it was the cuisine switch.
I removed the old and rename the new to the old.
To address the click only you mentioned, look if your switch has the click, double click and long click actions (go to the switch page, select that switch and edit).
If so, you need to manually add the long release and place after the long click, make the double click the last position.
It should have : click (10), long click (20), long release (30) and double click (40)
That was changed a week ago or so and those actions where not updated on mine, maybe at yours too
