i can not find a helping post in this forum and nothing with Google.
I use 2 Fibaro Roller Shutter 2 to controll my Venetian blinds. Up and down works without issues, only the stop do not work. I also tried to click a second time on open while it opens or the other way, but nothing works. In the past i have used both Roller Shutter with Fibaro HC Lite and it works great with stop function.
Please can somebody tell me if i have a wrong parameter configuration or what i am doing wrong?
http://imgur.com/a/QX0QW
Thanks,
mabo
Stop Venetian blinds
mabo21
Re: Stop Venetian blinds
No help?
Ernstl
- Domoticz version: 2020.2 b
Just try another switch type in the switch configuration.
I use "Blinds percentage inverted" and it works fine.
Ernstl
Ernstl
I have the same problem. Switch type with %level allows to set a level. But I haven't found something to stop the shutter in motion, especially in Lua.
Waltraud
Waltraud
mabo21
Thanks Ernstl, but this does´nt work. I need a normal stop function. Twice clicking on open or close does nothing, also the stop button haves no function. Does nobody have an idea?Ernstl wrote:Hi
Ernstl
trewq427
did anyone manage to solve this?
I have the same problem with aeotec nano shutter.
Labtec
Same problem here, can't stop when open or close sunscreen.mabo21 wrote: Wednesday 01 February 2017 0:36Thanks Ernstl, but this does´nt work. I need a normal stop function. Twice clicking on open or close does nothing, also the stop button haves no function. Does nobody have an idea?Ernstl wrote:Hi
Ernstl
Greetz
EHoog
I have the same issue. A "solution" is the one posted before: use the blinds with percentage. Open/close work fine and to stop the blinds you select any percentage and it stops. Anyway, for me at least with a qubino module. This is of course not really ideal, especially if eventually you want to use the percentage function for real
- emme
- Domoticz version: latest
do you have MQTT available?
could you try to send a telegram like:
while moving and see it it stops?
"command": "udevice",
"idx" : <venetian ID>,
"nvalue" : 2
}The most dangerous phrase in any language is:
"We always done this way"
