Three way or four way doesn't matter it will dynamically add the number of buttons that you have in domoticz.Awst6000 wrote:A question about the selector:
Is this the three-way switch for the ventilation system?
Domoboard - General Discussions
Moderators: leecollings, wez3
Forum rules
Before posting here, make sure you are using the latest Beta or Stable version.
In order to fix issues or add features these have to be reported on the Domoboard Github pages.
This makes it possible to keep track of issues/features on a centralized place.
Refer to the issue of the github tracker when possible.
This subforum is meant to discuss issues and/or feature requests, or anything else related to Domoboard.
squandor
- Domoticz version: 3.5837
Re: Domoboard - General Discussions
jhenrikb
Is there any way to increase buttons size?
I tried to double all the pixels in bootstrap-switch and "buttons" file without success.
the other files I looked in I didnt find much related to size.
On the 2000x1500 pixel tablet a scene button becomes very small.
Sincerely
John
Sincerely
John
squandor
Hi john the scene buttons style is located in the buttons.css so maybe if you change the values in that file that the buttons will change to.jhenrikb wrote:Is there any way to increase buttons size?
Sincerely
John
I can't seem to get it working. When I want to startup domoboard with the Python server.py config file this is what I get:
File "server.py", line 149, in <module>
unsanitizedConfig = configobj.ConfigObj(configfile)
File "/usr/local/lib/python2.7/dist-packages/configobj-5.0.6-py2.7.egg/configobj.py", line 1229, in __init__
self._load(infile, configspec)
File "/usr/local/lib/python2.7/dist-packages/configobj-5.0.6-py2.7.egg/configobj.py", line 1318, in _load
raise error
configobj.ConfigObjError: Parsing failed with several errors.
First error at line 67.
When I go to that map the file configonj does'nt exist. Can somebody help me? I am clearly not an expert in linux
PS: On the easy install configobj is installed with the correct version
raise error
jhenrikb
I get those errors when there is something wrong with my .config file. eg example.configZahariac wrote:I can't seem to get it working. When I want to startup domoboard with the Python server.py config file this is what I get:
raise error
Got it last night when I tried to show a dimmer as a switch.
THANK YOU! Now I got another fault. But can I change the port with no problems? Yes I can! Thanks it is working I think.jhenrikb wrote:I get those errors when there is something wrong with my .config file. eg example.configZahariac wrote:I can't seem to get it working. When I want to startup domoboard with the Python server.py config file this is what I get:
raise error
Error when starting the Flask server: [Errno 98] Address already in use
Still have a lot of 404 errors on several pages but I am getting somewhere
anconakip
- Domoticz version: 7722
I have installed all by this post on my pi2. I changed the flask_url port to 5000. But when i go to myip:5000 the browser wil not connect. What do i wrong?
Does your router support up to range 5000 for the port? Or your PI2 for that matter?anconakip wrote:I have installed all by this post on my pi2. I changed the flask_url port to 5000. But when i go to myip:5000 the browser wil not connect. What do i wrong?
anconakip
I changed the port to 85 and this works also not. What should i change on my pi then? all is on my locale network so i don't need portforwarding on my router i guess.Zahariac wrote:Does your router support up to range 5000 for the port? Or your PI2 for that matter?anconakip wrote:I have installed all by this post on my pi2. I changed the flask_url port to 5000. But when i go to myip:5000 the browser wil not connect. What do i wrong?
Are you sure that the installation is complete?anconakip wrote:I changed the port to 85 and this works also not. What should i change on my pi then? all is on my locale network so i don't need portforwarding on my router i guess.Zahariac wrote:Does your router support up to range 5000 for the port? Or your PI2 for that matter?anconakip wrote:I have installed all by this post on my pi2. I changed the flask_url port to 5000. But when i go to myip:5000 the browser wil not connect. What do i wrong?
anconakip
how can i check that? i folowwed this tut.Zahariac wrote:Are you sure that the installation is complete?anconakip wrote:I changed the port to 85 and this works also not. What should i change on my pi then? all is on my locale network so i don't need portforwarding on my router i guess.Zahariac wrote:
Not sure on a Pi. But in my terminal I can see lines and lines of code runninganconakip wrote:how can i check that? i folowwed this tut.Zahariac wrote:Are you sure that the installation is complete?anconakip wrote: I changed the port to 85 and this works also not. What should i change on my pi then? all is on my locale network so i don't need portforwarding on my router i guess.
anconakip
with what command?Zahariac wrote:Not sure on a Pi. But in my terminal I can see lines and lines of code runninganconakip wrote:how can i check that? i folowwed this tut.Zahariac wrote:
dutchdevil83
- Domoticz version: latest
start with -d in terminal and you can run in debug mode :anconakip wrote:with what command?Zahariac wrote:Not sure on a Pi. But in my terminal I can see lines and lines of code runninganconakip wrote: how can i check that? i folowwed this tut.
python server.py -c <config_file> -dHardware
1x Raspberry Pi
1x Razberry Z-Wave
1x RFXtrx433E
1x Toon
1x GoodWe Solarpanels
2x FGSD-002 Smoke Detector
1x FGBS-001 Binaire Sensor (RFID lezer)
7x FGMS-001 Motion Sensor
3x ZW089 Verzonken Deursensor
7x NC Wallplug
&lots of KaKu stuff
1x Raspberry Pi
1x Razberry Z-Wave
1x RFXtrx433E
1x Toon
7x NC Wallplug
&lots of KaKu stuff
anconakip
The only thing i see is:dutchdevil83 wrote:start with -d in terminal and you can run in debug mode :anconakip wrote:with what command?Zahariac wrote:
Not sure on a Pi. But in my terminal I can see lines and lines of code runningCode: Select all
Device and/or scene with IDX 22 is not available in Domoticz
and then my command line again.
desertdog
- Domoticz version: 2020.1
Just a question to be sure I wont 'break' anything...
My Domoticz web interface is currently running on 192.168.0.2:8080
If I set the Domoboard config to:
Does this means that the domoticz interface is still available on port 8080 and the Domoboard interface in port 80?
[general_settings]
[[server]]
url = 192.168.0.2:8080 # IP-address of Domoticz backend
flask_url = 192.168.0.2:80 # Please note: this is the internal IP-address including port of the Domoboard server
Snowtiger
- Domoticz version: 4.10915
in your configuration file (something like myconf.conf) you can only use IDX which are actually present and active in your Domoticz - you specified IDX 22 which is not present in your Domoticz so Domoboard will not runanconakip wrote:The only thing i see is:dutchdevil83 wrote:start with -d in terminal and you can run in debug mode :anconakip wrote: with what command?Code: Select all
Snowtiger
Correct, maybe you should use another port number that 80 because this is the default port for webservers - or it must be that this is your intentiondesertdog wrote:Just a question to be sure I wont 'break' anything...
If I set the Domoboard config to:Does this means that the domoticz interface is still available on port 8080 and the Domoboard interface in port 80?Code: Select all
[general_settings] [[server]] url = 192.168.0.2:8080 # IP-address of Domoticz backend flask_url = 192.168.0.2:80 # Please note: this is the internal IP-address including port of the Domoboard server
desertdog
Unfortunately I already get stuck at the first line:
This gives the error: sudo: easy_install: command not found
I am trying to install on a Rasberry Pi 3B
what am I doing wrong?
sudo easy_install flask flask-auth configobj gitpython simplejson bleach requestsI am trying to install on a Rasberry Pi 3B
Felix82
Already posted, read forum, use google...desertdog wrote:Unfortunately I already get stuck at the first line:This gives the error: sudo: easy_install: command not foundCode: Select all
sudo install python-setuptools
