Domoboard - General Discussions
Domoboard is a dashboard for Domoticz based on Python Flask.
Moderators: leecollings, wez3
Forum rules
Before posting here, make sure you are using the latest Beta or Stable version.
In order to fix issues or add features these have to be reported on the Domoboard Github pages.
This makes it possible to keep track of issues/features on a centralized place.
Refer to the issue of the github tracker when possible.
This subforum is meant to discuss issues and/or feature requests, or anything else related to Domoboard.
squandor
Domoticz version: 3.5837
Re: Domoboard - General Discussions
Post by squandor »
Awst6000 wrote:A question about the selector:
Is this the three-way switch for the ventilation system?
Three way or four way doesn't matter it will dynamically add the number of buttons that you have in domoticz.
jhenrikb
Post by jhenrikb »
Is there any way to increase buttons size?
I tried to double all the pixels in bootstrap-switch and "buttons" file without success.
the other files I looked in I didnt find much related to size.
On the 2000x1500 pixel tablet a scene button becomes very small.
Sincerely
John
squandor
Post by squandor »
jhenrikb wrote:Is there any way to increase buttons size?
Sincerely
John
Hi john the scene buttons style is located in the buttons.css so maybe if you change the values in that file that the buttons will change to.
Zahariac
Post by Zahariac »
I can't seem to get it working. When I want to startup domoboard with the Python server.py config file this is what I get:
File "server.py", line 149, in <module>
unsanitizedConfig = configobj.ConfigObj(configfile)
File "/usr/local/lib/python2.7/dist-packages/configobj-5.0.6-py2.7.egg/configobj.py", line 1229, in __init__
self._load(infile, configspec)
File "/usr/local/lib/python2.7/dist-packages/configobj-5.0.6-py2.7.egg/configobj.py", line 1318, in _load
raise error
configobj.ConfigObjError: Parsing failed with several errors.
First error at line 67.
When I go to that map the file configonj does'nt exist. Can somebody help me? I am clearly not an expert in linux
PS: On the easy install configobj is installed with the correct version
jhenrikb
Post by jhenrikb »
Zahariac wrote:I can't seem to get it working. When I want to startup domoboard with the Python server.py config file this is what I get:
raise error
I get those errors when there is something wrong with my .config file. eg example.config
Got it last night when I tried to show a dimmer as a switch.
Zahariac
Post by Zahariac »
raise error
THANK YOU! Now I got another fault. But can I change the port with no problems? Yes I can! Thanks it is working I think.
Error when starting the Flask server: [Errno 98] Address already in use
Still have a lot of 404 errors on several pages but I am getting somewhere
anconakip
Domoticz version: 7722
Post by anconakip »
I have installed all by this post on my pi2. I changed the flask_url port to 5000. But when i go to myip:5000 the browser wil not connect. What do i wrong?
Zahariac
Post by Zahariac »
anconakip wrote:I have installed all by this post on my pi2. I changed the flask_url port to 5000. But when i go to myip:5000 the browser wil not connect. What do i wrong?
Does your router support up to range 5000 for the port? Or your PI2 for that matter?
anconakip
Post by anconakip »
I changed the port to 85 and this works also not. What should i change on my pi then? all is on my locale network so i don't need portforwarding on my router i guess.
Zahariac
Post by Zahariac »
Are you sure that the installation is complete?
anconakip
Post by anconakip »
how can i check that? i folowwed this tut.
Zahariac
Post by Zahariac »
anconakip wrote:
Zahariac wrote:
anconakip wrote: I changed the port to 85 and this works also not. What should i change on my pi then? all is on my locale network so i don't need portforwarding on my router i guess.
Not sure on a Pi. But in my terminal I can see lines and lines of code running
anconakip
Post by anconakip »
with what command?
dutchdevil83
Domoticz version: latest
Post by dutchdevil83 »
anconakip wrote:
Zahariac wrote:
anconakip wrote: how can i check that? i folowwed this tut.
with what command?
start with -d in terminal and you can run in debug mode :
python server.py -c <config_file> -d
Hardware
1x Raspberry Pi
1x Razberry Z-Wave
1x RFXtrx433E
1x Toon
1x GoodWe Solarpanels
2x FGSD-002 Smoke Detector
1x FGBS-001 Binaire Sensor (RFID lezer)
7x FGMS-001 Motion Sensor
3x ZW089 Verzonken Deursensor
7x NC Wallplug
&lots of KaKu stuff
anconakip
Post by anconakip »
dutchdevil83 wrote:
anconakip wrote:
with what command?
The only thing i see is:
Device and/or scene with IDX 22 is not available in Domoticz
and then my command line again.
desertdog
Domoticz version: 2020.1
Post by desertdog »
Just a question to be sure I wont 'break' anything...
My Domoticz web interface is currently running on 192.168.0.2:8080
If I set the Domoboard config to:
[general_settings]
  [[server]]
    url = 192.168.0.2:8080			# IP-address of Domoticz backend
    flask_url = 192.168.0.2:80		# Please note: this is the internal IP-address including port of the Domoboard server
Does this means that the domoticz interface is still available on port 8080 and the Domoboard interface in port 80?
Snowtiger
Domoticz version: 4.10915
Post by Snowtiger »
anconakip wrote:
dutchdevil83 wrote:
anconakip wrote: with what command?
in your configuration file (something like myconf.conf) you can only use IDX which are actually present and active in your Domoticz - you specified IDX 22 which is not present in your Domoticz so Domoboard will not run
Snowtiger
Post by Snowtiger »
desertdog wrote:Just a question to be sure I wont 'break' anything...
[general_settings]
  [[server]]
Correct, maybe you should use another port number that 80 because this is the default port for webservers - or it must be that this is your intention ;) use for example 1500 :)
desertdog
Post by desertdog »
Unfortunately I already get stuck at the first line:
sudo easy_install flask flask-auth configobj gitpython simplejson bleach requests
This gives the error: sudo: easy_install: command not found
I am trying to install on a Rasberry Pi 3B
what am I doing wrong?
Felix82
Post by Felix82 »
desertdog wrote:Unfortunately I already get stuck at the first line:
Already posted, read forum, use google...
sudo install python-setuptools
