how to retrieve the historic of a temperature sensor
jmleglise
Domoticz version: 2022.1
Post by jmleglise »
Did someone knows how to retrieve the values of the log of temperature in a "device lua script" ?
I'm looking to check on the 20 last statements if the temperature has gone under 0°C. (It's a condition to use a rolling shutter for veranda roof)
I planned to decode Json of http://127.0.0.1:8081/json.htm?type=gra ... &range=day
But I didn't succeed with this script. (as I have explaned here : viewtopic.php?f=23&t=9662)
commandArray={}
if (devicechanged['ManualLaunchScript'] == 'On' and otherdevices['ManualLaunchScript'] == 'On') then
	commandArray['ManualLaunchScript']='Off'
	local handle=assert(io.popen("curl.exe http://127.0.0.1:8081/json.htm?type=graph&sensor=temp&idx=69&range=day"))
	local JMLresponse = handle:read('*all')
	handle:close()
	print(JMLresponse) --debug
Did Someone has a solution ?
My script : https://github.com/jmleglise
RFXTRX433E: Blind Somfy RTS, Portal Somfy Evolvia, chacon IO, Oregon, PIR sensor PT2262
My Last project : Location de vacances a Ouistreham vue mer
KMTronic USB relay
Chinese Z-WAVE: Neo CoolCam
Toulon7559
Domoticz version: <2025
Re: how to retrieve the historic of a temperature sensor
Post by Toulon7559 »
The way you formulate your question seems to imply that
- you would like to store the 20 latest-measured temperature values
- check whether at any time the temperature was below 0
- if True, take measures
Is that correct interpretation of your question?
Implies that you have to store 20 values, to refresh them at arrival of a new value, and then have to check all of them whether any value is going below 0.
Perhaps simpler is application of a 'filter'.
In Domoticz then a simple structure required:
- 1 input value called LatestTemp, for which you could take the value from an svalue available in Domoticz under 'Setup/Events'
- 1 uservariable called OldAvgTemp (to be defined under 'Setup/UserVariables')
- 1 variable called NewAvgTemp
Example algoritmic setup
# Initiation:
OldAvgTemp = 5 # to be sure that you start the algorithm 'at distance' from your threshold-Temperature
# Running algorithm, tunable by combination of parameter Filter (with e.g. value between 0.5 and 0.1) and boolean Condition:
While Condition
Call OldAvgTemp
Read LatestTemp
NewAvgTemp = (1-Filter) * OldAvgTemp + Filter * LatestTemp
OldAvgTemp = NewAvgTemp
If (OldAvgTemp < 0) then 'take measures' else 'reverse measures'
Write OldAvgTemp
Advantage is that this algorithm not instantly applies the temperature, but follows the temperature-tendency and has a built-in hysteresis:
with parameter 'Filter' you can control the speed of the filter + the size of the hysteresis.
Be aware that above example text is not a real script, but just a 'symbolic' algorithm which you have to adapt to the type of script you would like to apply!
That makes a lot of difference whether you want a Python-script or a lua-script or ..........
jmleglise
Post by jmleglise »
Thank you !!! Your method may solve my problem in a way that I had never anticipated BUT ... :-)
Your method is based on a Time script. But I'd rather avoid to execute a script every minute (or the like) to update a calcul when I need this calcul only to open a roller blind (perhaps twice a day). So my first idea was to execute the calcul only when I need it, to save CPU time and because Domoticz already store the historic of the temperature. To be clear here is what I talk about :
The data are available at this URL in JSON,
http://user:[email protected]:yourport/json.htm?type=graph&sensor=temp&idx=69&range=day
that I didn't succeed to access, because It seems that Lua can't self-request itself.
So I would like to know if there is a solution to retrieve this JSON in Lua.
KMTronic USB relay
Egregius
Domoticz version: v2024.7
Post by Egregius »
Read the data directly from the database in bash or php and use a cron every x minutes.
Edit: didn't read your last line that it's available thru json. Give me a minute to write a php script.
Egregius
Post by Egregius »
here we go, the power of PHP :)
// = comment
#!/usr/bin/php
<?php
$domoticzurl='http://127.0.0.1:8080/'; //adjust ip and port
$idxthermometer=22; //idx of thermometer
$idxroof=52; //idx of root
// get the temps
$temps=json_decode(file_get_contents($domoticzurl.'json.htm?type=graph&sensor=temp&idx='.$idxthermometer.'&range=day'),true);
// clean the array to only keep the results
$temps=$temps['result'];
//reverse sort the array so we can break after 20
rsort($temps);
//set a variable to false
$cold = false;
// and a counter
$count = 0;
// Loop thru the received temps
foreach($temps as $temp) {
	if($temp['te']<0) $cold = true; // if temp is less than 0 set variable cold to true
	$count = $count + 1; // add a count
	if($count==20) break; // stop after 20 temps
if($cold==true) {
	//get current status of roof
	$roof=json_decode(file_get_contents($domoticzurl.'json.htm?type=devices&rid='.$idxroof),true);
	//if status of roof isn't 'On' switch it 'On' (adjust to closed if nescessary)
	if($roof['result'][0]['Status']!='On') Schakel($idxroof, 'On');
//just one of the functions of my script to set a switch. Sorry for the Dutch term 'Schakel', PHP doesn't like the 'Switch' name as that is a built-in function.
function Schakel($idx,$cmd) {
	global $domoticzurl;
	$reply=json_decode(file_get_contents($domoticzurl.'json.htm?type=command&param=switchlight&idx='.$idx.'&switchcmd='.$cmd),true);
	if($reply['status']=='OK') $reply='OK';else {$reply='ERROR';$errors=$errors+1;}
	return $reply;
Execute by cron: */15 means every 15 minutes.
*/15 * * * * /var/scripts/roof.php
Minglarn
Domoticz version: v3.8153
Post by Minglarn »
Are you willing to share your code?
I'm looking for basically the same.i just want to extract the lowest and highest temp in one sensor.
Best regards.
Sent from space using an app.
“When you eliminate the impossible, whatever remains, however improbable, must be the truth.” -Spock in Star Trek VI
Toulon7559
@ jmleglise
If you write
"I'm looking to check on the 20 last statements if the temperature has gone under 0°C"
at my side the question arises, how often do you check?
"20 last statements" implies that periodically a value is added to the list of values, and checking changes in such array 'smells' like a timed run of a script, where you could discuss the method of timing, e.g. (triggered by the entry of a new value) vs (periodic check)?
Therefore the question (just for curiosity): why not a time-script?
jmleglise
Post by jmleglise »
@Egregius Thank you for your answer and your time. I had already well noted in your other posts to the forum that you promote php :-)
For me, as I have invested some times in learning of LUA, I will persevere a bit more until a formal answer that it is impossible by the design of domoticz.
KMTronic USB relay
jmleglise
Post by jmleglise »
Hi Toulon7559
I must check only when the roller shutter is about to move. (around only twice per day). That is the reason why I thought of a device_script.
Here is my needs :
1 - My temperature sensor sends temperature every 30sec to domoticz. Domoticz store the historic of the temperature with 1 measure every 5 minutes. This is native with Domoticz.
2 - My roller shutter may be broken if operated when there is ice. So before automating my roller shutter, I have to find a way to prevent it from moving if it freezes or if it froze these last hours.
So , either I use your solution that runs a script every 5 minutes, either I must found a way on device_change to analyse the xx last measures simply stored by domoticz (in LUA !).
KMTronic USB relay
alfred_j_kwak
Domoticz version: 2.3530
Post by alfred_j_kwak »
This might be stupid idea, but how about script_time that check if temperature is below zero. If so then set user variable to 'SOMETHING'. Then in script_device you can check when this user variable is last updated. If it is updated less than hour ago then temperature has been under zero.
Toulon7559
@jmleglise
Domoticz even runs time-scripts every 1 minute, but ;-) computers do not get tired.
And by insertion in such time-script of an interval-function you can set the interval for checking to any higher value you like!
You can also design the subject interval-function in such way that it checks the clock against a specific set of day-times, e.g. at sunrise and at sunset.
In my opinion, the only other aspect you have to pay attention is whether you allow (between the checks) that a temperature value below 0 is allowed to be missed or not, like hinted in the message of alfred_j_kwak
alfred_j_kwak
It is also possible to set notification into temperature device itself?
If set notification as http and from Setup->Settings->Notifications->Custom HTTP Action. There you could define URL action for notification - maybe use this to update User Variable and get even better resolution than with script_time.
jmleglise
Post by jmleglise »
Thank you very much everyone for all your answers.
If someone is interesting, here is the implementation I made of the advices given to me.
-- require : Virtual / Type General / Subtype Alert / name : Freeze Alert
 function timedifference (s)
   year = string.sub(s, 1, 4)
   month = string.sub(s, 6, 7)
   day = string.sub(s, 9, 10)
   hour = string.sub(s, 12, 13)
   t1 = os.time()
   difference = os.difftime (t1, t2)
   return difference
if (devicechanged['Temp Sensor'])  then
	local idx = '80' -- Device ID (Type Alert on virtual hardware)
	--local sValue = 'Risk : Freeze '
	--local nValue = 4  --  0 grey / 1 green / 2 yellow / 3 orange / 4 red
	if tonumber(otherdevices_svalues['Temp Sensor']) <1 then
		commandArray['UpdateDevice'] = idx .. '|4|Risk Freeze'
	elseif timedifference(otherdevices_lastupdate['Freeze Alert']) > 3*60*60 then -- No freeze since 3 hours
		commandArray['UpdateDevice'] = idx .. '|1|No Freeze'
PS : This resolve my situation, but don't answer my question. I am already interested to know how to access the historic of data that Domoticz store.
KMTronic USB relay
jake
Post by jake »
jmleglise wrote:Thank you very much everyone for all your answers.
Have you succeeded to retrieve historical data? I found this topic in need of the same information. In my case I want to split up the P1 Gas meter in both hot water heating and room heating. I got it working now, by storing the actual gas meter value in a variable. With the next 'devicechanged' I compare the svalue with the variable, do my calculation and afterwards update my new virtual gas meter and the variable again.
Instead of the variable I'd prefer to compare the updated value with the 'second-last' value of the gas meter sensor, but how...
McFranky
Post by McFranky »
This code work for me. It calculates the average temperature for the last 7 days.
local function DeviceUpdate(idx, value1)
    local cmd = string.format("%d|0|%.2f", idx, value1)
	--print(cmd)
    table.insert (commandArray, { ['UpdateDevice'] = cmd } )
-- Script parameters
Debug = "NO"                    -- Turn debugging on ("YES") or off ("NO")
-- CommandArray
-- Variablen deklarieren
local temperatur_name	= 'Aussentemperatur_Mittelwert'
local temperatur_idx	= otherdevices_idx[temperatur_name]
local messwert_name	= 'Aussentemperatur'
local messwert_idx	= otherdevices_idx[messwert_name]
--Abfrage der Tages-Tabellen-Werte
local sAbfrage			= 'curl "http://192.168.178.29:8080/json.htm?type=graph&sensor=temp&idx='..tostring(messwert_idx)..'&range=day"'
local handle=assert(io.popen(sAbfrage))
local raw = handle:read('*all')
handle:close()
--JSON Auswertung der erhaltenen Daten
json = assert(loadfile '/home/pi/domoticz/scripts/lua/JSON.lua')()
local jsonData = json:decode(raw)
if Debug=='YES' then
	print (jsonData.title)
	print (jsonData.status)
	print (jsonData.result[1].d)
	print (jsonData.result[1].te)
--Durchschnittswert der letzten 7 Tage ermitteln
local sum = 0
local ave = 0
local elements = #jsonData.result
for i = 1, elements do
    sum = sum + jsonData.result[i].te
ave = sum / elements
	print('Mittelwert: '..tostring(ave))
--Wert speichern in Zielvariable
DeviceUpdate(temperatur_idx,ave)
Greetings from Berlin
Greetings from Berlin...
