ZWave association + slow response
rmmed
Post by rmmed »
I've just started out with zwave, and I a running into 2 problems. I hope someone can help.
My setup is a RPi 3 with RazBerry board. And currently only Fibaro Dimmer 2 modules.
First problem:
I want to use a S2 button of one dimmer to turn on another dimmer. To achieve this I've put the second dimmer (node 15) in group 4 and 5 of the first one (node 13). But pressing the s2 button does not turn on the other light.
I've attached a screenshot of the groups. Is this not correct?
Second problem:
Sometimes switching of lights through the web interface takes more than 10 seconds. The OZW_LOG contains a lot of these messages:
2017-01-21 15:50:59.623 Error, Node009, ERROR: Dropping command, expected response not received after 1 attempt(s)
2017-01-21 15:50:59.623 Always,
2017-01-21 15:50:59.623 Always, Dumping queued log messages
2017-01-21 15:50:59.624 Always, End of queued log message dump
2017-01-21 15:51:02.197 Error, Node012, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
2017-01-21 15:51:02.197 Always,
2017-01-21 15:51:02.198 Always, Dumping queued log messages
2017-01-21 15:51:02.198 Always, End of queued log message dump
2017-01-21 15:51:02.199 Always,
2017-01-21 15:51:02.343 Error, Node012, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
2017-01-21 15:51:02.343 Always,
2017-01-21 15:51:02.344 Always, Dumping queued log messages
2017-01-21 15:51:02.345 Always,
2017-01-21 15:51:02.345 Always, End of queued log message dump
''2017-01-21 15:51:04.559 Error, Node008, ERROR: ZW_SEND_DATA could not be delivered to Z-Wave stack
2017-01-21 15:51:04.559 Always,
2017-01-21 15:51:04.560 Always, Dumping queued log messages
2017-01-21 15:51:04.560 Always, End of queued log message dump
2017-01-21 15:51:04.561 Always,
Cubes
Re: ZWave association + slow response
Post by Cubes »
I'm sure you sorted this by now but for future reference, it's supposed to be the other way around. Your remote dimmer needs to have the id of the dimmer to which the light is connected in its groups 4 + 5.
