Pinout for 433 Receiver
433Mhz opensource Receiver & Transmitter.
Bighouse
Post by Bighouse »
I'm trying to setup my RFLink functionality.
I'm using a cheap FS1000A as a transmitter and I bought a superheterodyne module named RXB12 as a receiver.
Because it wasn't listed I choose the pinout of Qiachip WL101 which looked quite the same as a print.
However I see:
"Pin 1 = Antenna
Pin 2 = Ground
Pin 3 = VCC (~3-5 volts)
Pin 4 = MEGA rx1/Pin 19 (RX Data)
Pin 5 = MEGA rx1/Pin 19 (RX Data)
Pin 6 = Ground"
Two times Pin 19 while other receiver boards go on 16 and 19. Is this a typing error or something? Or do they both need to go to the same pin?
Stuntteam
Re: Pinout for 433 Receiver
Post by Stuntteam »
These modules have a double data pin..
Note that RXB12 might not work with the current versions.. we have a solution coming up.
Bighouse
Post by Bighouse »
I already tried with one pin in 16 and one in 19. And change this around. This didn't work. However I decided to unplug randomly one of the two data pins and have only one cable to pin 19. Now it's working perfectly :-). Will adding the other one to 19 also (will need to split the cable then) give any further benefits?
Stuntteam
Post by Stuntteam »
no, there is no need to connect both..
Bighouse
Post by Bighouse »
Okay, I will test later with the other pin connected instead of the current one. But now it works perfectly.
Thanks for making this firmware.
Stuntteam
Post by Stuntteam »
Thanks,
No need to test the other pin, if it works keep it working.. :)
