I'm trying to setup my RFLink functionality.
I'm using a cheap FS1000A as a transmitter and I bought a superheterodyne module named RXB12 as a receiver.
Because it wasn't listed I choose the pinout of Qiachip WL101 which looked quite the same as a print.
However I see:
"Pin 1 = Antenna
Pin 2 = Ground
Pin 3 = VCC (~3-5 volts)
Pin 4 = MEGA rx1/Pin 19 (RX Data)
Pin 5 = MEGA rx1/Pin 19 (RX Data)
Pin 6 = Ground"
Two times Pin 19 while other receiver boards go on 16 and 19. Is this a typing error or something? Or do they both need to go to the same pin?
