Advanced network monitoring
franzelare
Post by franzelare »
I have combined a few scripts in Domoticz to monitor my network performance that I like to share.
This is the floorplan with all my network vitals displayed in one quick overview
Checking if network devices are online
I have multiple scripts runing, first the ARP scan to detect if devices are on or off, this way you don't have to know the IP of the devices in your network and can use a DHCP server.
This script is based on this topic on domoticz forum: viewtopic.php?f=23&t=5256
I have 3 user variable strings with the mac addresses and device ID's with it.
The Lua time script runing in domoticz
-- source https://www.domoticz.com/forum/viewtopic.php?f=23&t=5256
PRINT_MODE = false					-- when true wil print output to log and send notifications
    function splitString(str, delim, maxNb)
        -- Eliminate bad cases...
        if string.find(str, delim) == nil then
            return { str }
        if maxNb == nil or maxNb < 1 then
            maxNb = 0    -- No limit
        local result = {}
        local pat = "(.-)" .. delim .. "()"
        local nb = 0
        local lastPos
        for part, pos in string.gmatch(str, pat) do
            nb = nb + 1
            result[nb] = part
            lastPos = pos
            if nb == maxNb then break end
        -- Handle the last field
        if nb ~= maxNb then
            result[nb + 1] = string.sub(str, lastPos)
        return result
    function CheckMac(maclist)
        Lines=splitString(maclist,"|")
        for i,line in pairs(Lines) do
            macs=splitString(line,";")
            if PRINT_MODE == true then
                print ("MAC Address to Poll: "..macs[1].." On IDX:"..macs[2])
            execcommand="sudo /home/pi/domoticz/scripts/bash/Check_MAC.sh "..macs[1].." "..macs[2].." &"
            os.execute(execcommand)
        print ("Checking presence list 1")
    list1= uservariables['PRESENCE_LIST1']
    CheckMac(list1)
        print ("Checking presence list 2")
    list2= uservariables['PRESENCE_LIST2']
    CheckMac(list2)
        print ("Checking presence list 3")
    list3= uservariables['PRESENCE_LIST3']
    CheckMac(list3)
The bash scripts it is calling out to:
    #!/bin/bash
    MAC=$1
    IDX=$2
    sudo arp-scan --localnet | grep -e $MAC
    if [ $? -eq 1 ]
    then
    echo "Device $MAC Not in LOCAL LAN"
    curl "http://127.0.0.1:8080/json.htm?type=command&param=switchlight&idx=$IDX&switchcmd=Off"
    echo "Device $MAC in LOCAL LAN"
    curl "http://127.0.0.1:8080/json.htm?type=command&param=switchlight&idx=$IDX&switchcmd=On"
    fi
Mysensor node online detection
For my mysensor units I have a watchdog script runing, that sends an on switch command to every mysensor unit (ESP units over WiFi and NRF24 units over the mysensor network mesh) every unit responds by toggeling the switch off again so I know the unit is still alive. For the ESP units I have a timeout of 1 minute in the hardware configuration in domoticz, so it will try to re-connect if there is no response to the heartbeat ChildID and on the mysensor nodes I have one output pin to pull the reset to ground in case no heartbeat ID is received for 5 minutes. with this watchdog script I assume a node to be dead when I miss 2 heartbeats, so I miss one and cannot connect again within 1 minute, meaning the node has crashed and need to wait until the watchdog timer on the unit runs out and a hard reset is done... (soft resets fail often on the ESP units) I also track failing nodes in a log file on the server.
for details see my post in this topic on the hardware and code: viewtopic.php?f=42&t=9775
function timedifference (s)
  year = string.sub(s, 1, 4)
  month = string.sub(s, 6, 7)
  day = string.sub(s, 9, 10)
  hour = string.sub(s, 12, 13)
  t1 = os.time()
  difference = os.difftime (t1, t2)
  return difference
LastupdateESPstalletje = otherdevices_lastupdate['HeartbeatESPStalletje']
ESPStaldifference=timedifference (LastupdateESPstalletje)
	    print('Lastupdate ESP stalletje ' .. LastupdateESPstalletje)
        print('Time difference ' .. ESPStaldifference)
if (ESPStaldifference>=130 and otherdevices['ESPStalletjeAlive'] == 'On')then
    commandArray['ESPStalletjeAlive'] = 'Off'
        print('Lost connection with ESP Stalletje')
    CurrentTime=os.date("%Y-%m-%d %H:%M:%S")
    file = io.open("/home/pi/domoticz/www/log/MysensorWatchdog.log", "a")
        io.output(file)
        io.write(CurrentTime.. " Mysensor ESP stalletje connection lost" .. "\n")
        io.close(file)
            print('Writing to error log')
if (ESPStaldifference<=130 and otherdevices['ESPStalletjeAlive'] == 'Off')then
        print('ESP stalletje is a live again')
    commandArray['ESPStalletjeAlive'] = 'On'
        io.output(file)
        io.write(CurrentTime.. " Mysensor ESP stalletje connection operational again" .. "\n")
        io.close(file)
LastupdateESPIR = otherdevices_lastupdate['HeartbeatESPIRRemote']
ESPIRdifference=timedifference (LastupdateESPIR)
	    print('Lastupdate ESP IR Remote ' .. LastupdateESPIR)
        print('Time difference ' .. ESPIRdifference)
if (ESPIRdifference>=130 and otherdevices['ESPIRAlive'] == 'On') then
    commandArray['ESPIRAlive'] = 'Off'
        print('Lost connection with ESP IR Remote')
        io.output(file)
        io.write(CurrentTime.. " Mysensor ESP IR Remote connection lost" .. "\n")
        io.close(file)
if (ESPIRdifference<=130 and otherdevices['ESPIRAlive'] == 'Off')then
        print('ESP IR Remote is a live again')
    commandArray['ESPIRAlive'] = 'On'
        io.output(file)
        io.write(CurrentTime.. " Mysensor ESP IR Remote connection operational again" .. "\n")
        io.close(file)
LastupdateESPGSR = otherdevices_lastupdate['GSRHEARTBEAT']
ESPGSRdifference=timedifference (LastupdateESPGSR)
	    print('Lastupdate ESP GSR ' .. LastupdateESPGSR)
        print('Time difference ' .. ESPGSRdifference)
if (ESPGSRdifference>=130 and otherdevices['ESPGSRAlive'] == 'On') then
    commandArray['ESPGSRAlive'] = 'Off'
        print('Lost connection with ESP GSR')
        io.output(file)
        io.write(CurrentTime.. " Mysensor ESP GSR connection lost" .. "\n")
        io.close(file)
if (ESPGSRdifference<=130 and otherdevices['ESPGSRAlive'] == 'Off')then
        print('ESP GSR is a live again')
    commandArray['ESPGSRAlive'] = 'On'
        io.output(file)
        io.write(CurrentTime.. " Mysensor ESP GSR connection operational again" .. "\n")
        io.close(file)
-- send watchdog signals to mysensor gateway's
            commandArray['HeartBeatBedLight'] = 'On'
            commandArray['HeartbeatESPStalletje'] = 'On'
            commandArray['HeartbeatArduinoVoordeur'] = 'On'
            commandArray['GSRHEARTBEAT'] = 'On'
            commandArray['GSLHEARTBEAT'] = 'On'
            commandArray['GWRHEARTBEAT'] = 'On'
            commandArray['GWLHEARTBEAT'] = 'On'
            commandArray['HeartbeatESPIRRemote'] = 'On'
--            commandArray['HeartbeatESPVerwarming'] = 'On'
--            commandArray['HeartbeatESPRGB'] = 'On'
Ping times inside my network
Secondly I run a Ping script for the main devices in my network that have a fixed IP, like ESP units that run as Mysensor nodes and my switches and network drives.
This is derrived from the arp scan script and this topic on the domoticz forum: viewtopic.php?f=38&t=13421
This is the time based lua script runing in domoticz
            return { str }
        local result = {}
        local nb = 0
        local lastPos
            nb = nb + 1
            result[nb] = part
            lastPos = pos
        if nb ~= maxNb then
        return result
    function CheckIP(IPlist)
        Lines=splitString(IPlist,"|")
            IP=splitString(line,";")
                print ("Check if device is on to ping : "..IP[2])
            pingdevice = tostring(IP[2])
            if otherdevices [pingdevice] == 'On' then
                    print ("Device " ..IP[2].. " is on")
                    print ("IP Address to Poll: "..IP[1].." With 3 counts for IDX "..IP[3])
                execcommand="sudo /home/pi/domoticz/scripts/bash/ping.sh " ..IP[1].." 3 "..IP[3].." &"
                    print ("Device " ..IP[2].. " is off")
        print ("Checking ping list 1")
    list1= uservariables['PING_LIST1']
    CheckIP(list1)
        print ("Checking ping list 2")
    list2= uservariables['PING_LIST2']
    CheckIP(list2)
        print ("Checking ping list 3")
    list3= uservariables['PING_LIST3']
    CheckIP(list3)
The bash script it is calling out to
host=$1
count=$2
idx=$3
name=$4
domoticz=127.0.0.1
multiply=1000
value=`ping -c $count $host | awk -F '/' 'END {print $5}'`
value2=$(echo "$value*$multiply" | bc)
value3=${value2%.*}
echo "$4 $value3"
curl "$domoticz:8080/json.htm?type=command&param=udevice&idx=$idx&nvalue=0&svalue=$value3"
Uptime tracking of network devices
For some devices I also want to know the uptime, since I'm suffering from devices in my network loosing communication, so I track the time decives are on with a custom counter and a lua script runing from domoticz.
This script is based on this forum topic: viewtopic.php?f=38&t=11985
-- this script is to detect Uptime of devices in domoticz
-- based on the script of mvzut that can be found here on the forum
-- https://www.domoticz.com/forum/viewtopic.php?f=38&t=11985
-- this has to be a time based lua script in domoticz (as device script this will not work)
-- for every device to monitor a counter has to be created as virtual devicecount
-- Create an custom counter using the Dummy hardware component (first add this component if you haven't already done so before, using Setup>Hardware).
-- Then go to the Utility section, change the type of your new counter from Energy to Counter, and fill in the Value Quantity (e.g. "On time") and Value Units ("Minutes").
-- Check the Device ID (idx) that is given to the new counter device.
-- this script can be run in combination with an ping, bluetooth scan or an arp scan what is in some cases more reliable
    -- ping: https://www.domoticz.com/wiki/Presence_detection
    -- bluetooth: https://www.domoticz.com/wiki/Presence_detection_(Bluetooth_4.0_Low_energy_Beacon)
    -- arp scan: https://www.domoticz.com/forum/viewtopic.php?f=23&t=5256
-- define general script values
devicecount = 8                     -- number of deviced to be cheked by the script for on time
-- create a table to store device information
devicetable = {}
-- Device 1
device = 1
devicetable["name" .. device] = 'KPN Modem'           -- exact name of the device to be checked for on time
devicetable["timer" .. device] = 'Uptime KPN Modem'     -- exact name of the counter created for this device
devicetable["ID" .. device] = 368                       -- idx of the counter created for this device
-- Device 2
device=2
devicetable["name" .. device] = 'Pi2Heating'           -- exact name of the device to be checked for on time
devicetable["timer" .. device] = 'Uptime Pi2Heating'     -- exact name of the counter created for this device
devicetable["ID" .. device] = 369                      -- idx of the counter created for this device
-- Device 3
device=3
devicetable["name" .. device] = 'ESPIRAlive'           -- exact name of the device to be checked for on time
devicetable["timer" .. device] = 'Uptime IR remote'     -- exact name of the counter created for this device
devicetable["ID" .. device] = 370                       -- idx of the counter created for this device
-- Device 4
device=4
devicetable["name" .. device] = 'ESPStalletjeAlive'           -- exact name of the device to be checked for on time
devicetable["timer" .. device] = 'Uptime Schuur'     -- exact name of the counter created for this device
devicetable["ID" .. device] = 371                       -- idx of the counter created for this device
-- Device 5
device=5
devicetable["name" .. device] = 'ESPGSRAlive'           -- exact name of the device to be checked for on time
devicetable["timer" .. device] = 'Uptime ESP GSR'     -- exact name of the counter created for this device
devicetable["ID" .. device] = 372                       -- idx of the counter created for this device
-- Device 6
device=6
devicetable["name" .. device] = 'ESPGSLAlive'           -- exact name of the device to be checked for on time
devicetable["timer" .. device] = 'Uptime ESP GSL'     -- exact name of the counter created for this device
devicetable["ID" .. device] = 373                       -- idx of the counter created for this device
-- Device 7
device=7
devicetable["name" .. device] = 'ESPGWRAlive'           -- exact name of the device to be checked for on time
devicetable["timer" .. device] = 'Uptime ESP GWR'     -- exact name of the counter created for this device
devicetable["ID" .. device] = 374                       -- idx of the counter created for this device
-- Device 8
device=8
devicetable["name" .. device] = 'ESPGWLAlive'           -- exact name of the device to be checked for on time
devicetable["ID" .. device] = 375                       -- idx of the counter created for this device
for i=1,devicecount do
    if otherdevices[devicetable["name" .. i]] == 'On' then
	    TotalMinutesUp = tonumber(otherdevices_svalues[devicetable["timer" .. i]])
    	TotalMinutesUpNew = TotalMinutesUp + 1
    	TimerID = tonumber(devicetable["ID" .. i])
            execcommandUp="sudo /home/pi/domoticz/scripts/bash/SetCounter.sh "..TimerID.." "..TotalMinutesUpNew.." &"
            os.execute(execcommandUp)
            print('Device sequence: ' .. i)
            print('Device name detected On :' .. devicetable["name" .. i])
            print('Device name On timer :' .. devicetable["timer" .. i])
            print('Device ID timer counter :' .. TimerID)
		    print('Previous Uptime: ' .. TotalMinutesOn)
		    print('New Uptime: ' .. TotalMinutesOnNew)
    elseif otherdevices[devicetable["name" .. i]] == 'Off' then
            print('Device detected Off: ' .. devicetable["name" .. i])
            print('Resetting uptimer to 0')
            Reset=0
            execcommandUp="sudo /home/pi/domoticz/scripts/bash/SetCounter.sh "..TimerID.." "..Reset.." &"
            print('Device ERROR: ' .. devicetable["name" .. i])
Since I want to update multiple customer counters, i need to do this through a bash script, since lua in domoticz will only update the last custom device called out to.
    #!/bin/bash
    IDX=$1
    COUNT=$2
	curl "http://127.0.0.1:8080/json.htm?type=command&param=udevice&idx=$IDX&nvalue=0&svalue=$COUNT"
Ontime tracking of devices in my network
Last I want to monitor ontime for some devices, just to see how often the phones, TV and so on is switched on... just because I can...
-- this script is to detect on time of devices in domoticz
-- Create an incremental counter using the Dummy hardware component (first add this component if you haven't already done so before, using Setup>Hardware).
devicecount = 11                     -- number of deviced to be cheked by the script for on time
devicetable = {}
-- Device 1
device = 1
devicetable["name" .. device] = 'FransMobiel'           -- exact name of the device to be checked for on time
devicetable["timer" .. device] = 'FransMobielTimer'     -- exact name of the counter created for this device
devicetable["ID" .. device] = 237                       -- idx of the counter created for this device
-- Device 2
device=2
devicetable["name" .. device] = 'SusanMobiel'           -- exact name of the device to be checked for on time
devicetable["timer" .. device] = 'SusanMobielTimer'     -- exact name of the counter created for this device
devicetable["ID" .. device] = 238                       -- idx of the counter created for this device
-- Device 3
device=3
devicetable["name" .. device] = 'FransTablet'           -- exact name of the device to be checked for on time
devicetable["timer" .. device] = 'FransTabletTimer'     -- exact name of the counter created for this device
devicetable["ID" .. device] = 239                       -- idx of the counter created for this device
-- Device 4
device=4
devicetable["name" .. device] = 'SusanTablet'           -- exact name of the device to be checked for on time
devicetable["timer" .. device] = 'SusanTabletTimer'     -- exact name of the counter created for this device
devicetable["ID" .. device] = 240                       -- idx of the counter created for this device
-- Device 5
device=5
devicetable["name" .. device] = 'FransPC'           -- exact name of the device to be checked for on time
devicetable["timer" .. device] = 'FransPCTimer'     -- exact name of the counter created for this device
devicetable["ID" .. device] = 241                       -- idx of the counter created for this device
-- Device 6
device=6
devicetable["name" .. device] = 'SusanPC'           -- exact name of the device to be checked for on time
devicetable["timer" .. device] = 'SusanPCTimer'     -- exact name of the counter created for this device
devicetable["ID" .. device] = 242                       -- idx of the counter created for this device
-- Device 7
device=7
devicetable["name" .. device] = 'SonyBlueRay'           -- exact name of the device to be checked for on time
devicetable["timer" .. device] = 'SonyBlueRayTimer'     -- exact name of the counter created for this device
devicetable["ID" .. device] = 243                       -- idx of the counter created for this device
-- Device 8
device=8
devicetable["name" .. device] = 'ITV receiver'           -- exact name of the device to be checked for on time
devicetable["timer" .. device] = 'ITV receiverTimer'     -- exact name of the counter created for this device
devicetable["ID" .. device] = 244                       -- idx of the counter created for this device
-- Device 9
device=9
devicetable["name" .. device] = 'ASM-Lan'           -- exact name of the device to be checked for on time
devicetable["timer" .. device] = 'ASM-LanTimer'     -- exact name of the counter created for this device
devicetable["ID" .. device] = 245                       -- idx of the counter created for this device
-- Device 10
device=10
devicetable["name" .. device] = 'ASM-Wifi'           -- exact name of the device to be checked for on time
devicetable["timer" .. device] = 'ASM-WifiTimer'     -- exact name of the counter created for this device
devicetable["ID" .. device] = 246                       -- idx of the counter created for this device
-- Device 11
device=11
devicetable["name" .. device] = 'Chromecast'           -- exact name of the device to be checked for on time
devicetable["timer" .. device] = 'ChromecastTimer'     -- exact name of the counter created for this device
devicetable["ID" .. device] = 247                       -- idx of the counter created for this device
	    TotalMinutesOn = tonumber(otherdevices_svalues[devicetable["timer" .. i]])
    	TotalMinutesOnNew = TotalMinutesOn + 1
--	    commandArray['UpdateDevice'] =  TimerID .. '|0|' .. tonumber(TotalMinutesOnNew)
            execcommandOn="sudo /home/pi/domoticz/scripts/bash/SetCounter.sh "..TimerID.." "..TotalMinutesOnNew.." &"
            os.execute(execcommandOn)
		    print('Previous on time: ' .. TotalMinutesOn)
		    print('New on time: ' .. TotalMinutesOnNew)
            print('No update of the timer needed')
Reboot scripts
For the domoticz servers I use them to do a crosscheck if domoticz is still runing and if not reboot the server, since just restarting domoticz is not always working. I do this with a time based lua script on both servers
        print ("Checking if heating Pi 2 is online")
        execcommand="sudo /home/pi/domoticz/scripts/bash/CheckOnline.sh"
calling out for the following bash script
#!/bin/sh
# check domoticz
status=`curl -s -i -H "Accept: application/json" "http://192.168.2.141:8080/json.htm?type=devices&rid=1" | grep "status"| awk -F: '{print $2}'|sed 's/,//'| sed 's/\"//g'`
if [ $status ]
then
echo "Domoticz draait nog"
echo "Domoticz draait niet meer, rebooting server"
curl "http://127.0.0.1:8080/json.htm?type=command&param=switchlight&idx=146&switchcmd=On"
sshpass -p 'xxxxxxxx' ssh [email protected] 'sudo reboot'
fi
sshpass you have to login manually first to accept the key presented, but after that it will run from the script
The script switches a virtual switch to let me know it rebooted the other server, in the startup script of the other server it sends an off command again so I can see in the logging that the reboot was successful
emme
Domoticz version: latest
Re: Advanced network monitoring
Post by emme »
I love it!!!!!! :o :o :o :o :o :o :o :o
"We always done this way"
sincze
Domoticz version: 2024.4
Post by sincze »
Whaaaah nice
Sent from my SM-G925F using Tapatalk
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
korniza
Domoticz version: V3.6028
Post by korniza »
Nice! I have a similar plan but I use Alert sensors as I do not need the real values of ping response and get a better visualisation as alert sensor has 3 states (green,orange,red)
>>>> Google Home <<<<<
