Kinping projector screen - lightning4 - domoticz - help Topic is solved
karde
Domoticz version: 3.7412
Post by karde »
I'm trying to add my kingpin (KP100) projector screen in domoticz using my RFXtrx433, according to the RFX manual kingpin screen should work with the following settings:
16.2. Kingpin (KP100) projection screen
Use Lighting4 with a pulse timing of 1040
UP 1110 0001 0100 0010 0010 0010 E1 42 22
STOP 1110 0001 0100 0010 0010 0100 E1 42 24
DOWN 1110 0001 0100 0010 0010 1000 E1 42 28
PROGRAM 1110 0001 0100 0010 0010 0001 E1 42 21
So, I have successfully paired the kingpin receiver in RFXmngr and transmitted these commands from RFXmngr.
Skärmavbild 2016-04-14 kl. 20.39.46.png (252.17 KiB) Viewed 3330 times
The screen from RFXmngr goes up and down, depending on the code I transmit.
But.. can someone please help me to add the device in domoticz :/, tried to choose switches/manual light switch, and tried to select the right code and test it, no luck, guess I should have some blinds type switch type - right..?, how do I choose pulse timing 1040 :/, and which one is lightning4, thanks for any help!!!!
Skärmavbild 2016-04-14 kl. 20.45.03.png (64.26 KiB) Viewed 3330 times
Did I miss some step in RFXmngr, all I did was pair my remote and try to transmit the commands..
Again - thanks!!
lotjepk
Re: Kinping projector screen - lightning4 - domoticz - help
Post by lotjepk »
any luck with this?
and how do i paire the kingpin kp100
gr,
paul
cogliostrio
Post by cogliostrio »
Have you tried learning the remote commands? I have a Mutibracket projector screen that also registerd as "lighting4" through rfxmanager.
Under the switch tab in Domoticz, hit the "learn light/switch" button, then press the remote button you want Domoticz to learn.
domoticz, learn switch.png (59.39 KiB) Viewed 3163 times
panomi
Post by panomi »
Maybe not the answer your looking for, but I have an Invisions screen and it's listed as: Blinds, T6 DC106
karde
Post by karde »
Thanks guys, sorry for a really late reply, feel bad that you have taken the time and I have missed it, looked at my post from time to time but haven't found anyone how knew the answer, and therefore wasn't expecting that anyone had replied..
None of the above worked for me :/, manual learn light switch just times out..
with and with the blinds manual T6 I can't get it to work :(.
Again thanks for taking the time to reply, a really!! sorry for not seeing this before know.. :/ However if anyone knew how to get this to work I'd be really happy!
cogliostrio
You cannot add a Lighting4 protocol manually. Someone made a patch, but it doesnt appear to have been submitted.
viewtopic.php?t=5367
Have you checked to see if you are using incompatible protocols in your RFXCom?
Like this for instance http://www.domoticz.com/forum/viewtopic ... 44&t=15070
Alternatively, if you got a z-wave network as well. You could use a shutter from either fibaro or qubino. This was to be
my backup plan, if my screen wasnt supported (still might do this at some point).
http://qubino.com/products/flush-shutter-dc/
http://manuals.fibaro.com/roller-shutter-2/
b_weijenberg
Post by b_weijenberg »
cogliostrio wrote:You cannot add a Lighting4 protocol manually. Someone made a patch, but it doesnt appear to have been submitted.
For transmit all protocols will operate. Enabling protocols is only used for receive.
RFX-433, RFX-433EMC, RFX-868
karde
Post by karde »
A, ok, so the above solution won't work? :/
Thanks both for your time/post though!!
karde
Post by karde »
Bought a new screen, not because of this, because it was time-thanks for all help though!
Sorry for marking it solved, was error from my side, didn't find out how to unsolve it, I didn't get this to work with domoticz.
