arkoko
Post by arkoko »
corbin wrote:This is already fixed after the last firmware update.
:o Which number of FW you talking about? I have 1.4.1_143.0141 and still magnet always closing in 1 minute (beta 6371).
murtadin
Re: RE: Re: RE: Re: Xiaomi Smart Home Suite (very cheap) compatibilty?
Post by murtadin »
corbin wrote:
murtadin wrote:
First check /usr/bin/emerge if file exists. Check permitions. You are trying it under root user? If not -
looks like you have to install stage 3. Just download it and unzip to the system root.
I have installed missing liveusb library, required by precompiled binaries - now i can start ./domoticz, but still no luck. No device appear in device menu. Still need help to debug this case.
How about you create a VM of your setup that I can test with?
Do you mean i should create VM image of gentoo linux for Vmware for you? I am not sure that i understood you correct.
levynger
Post by levynger »
what is your domoticz version?
this issue was resolved already by corbin.
deennoo
Post by deennoo »
Is waiting your github correction to provid it to domoticz main beta
Edit : didn't see your work on github 1 hour ago sorry.
Now we have to wait about corbin to wakeup (it's only 6:05 on Brisban, wake up Corbin ! Europe waiting for you !)
http://domo-attitude.fr
levynger
Post by levynger »
deennoo wrote:
levynger wrote:
arkoko wrote: :o Which number of FW you talking about? I have 1.4.1_143.0141 and still magnet always closing in 1 minute (beta 6371).
the pull request is ready in github, includes the aqara wireless, and aqara wired (only report)
i just disconvered that there is another event "Dual Switch" with the wireless - will add it soon to a new pull.
deennoo
Re: RE: Re: RE: Re: RE: Re: Xiaomi Smart Home Suite (very cheap) compatibilty?
Post by deennoo »
Try something today :
For cube and round switch, corbin set the Off option, but as they are "active switch" they never goes to off but on standby (MiHome never show off for those device).
I remove off from selector this works just have to check about % value for selector.
Will made it after your pull about dual button wireless switch.
levynger
Post by levynger »
deennoo wrote:
levynger wrote:
deennoo wrote: Is waiting your github correction to provid it to domoticz main beta
done, removed old pull requests, patch-2 is ready with dual Click mode for the aqara wireless switch.
deennoo
Post by deennoo »
Great ! What is next device ? In wall plug ? The one shown before on this thread ? ... No api for this one, or maybe the outside wall plug is the same api.
corbin
Post by corbin »
murtadin wrote: Do you mean i should create VM image of gentoo linux for Vmware for you? I am not sure that i understood you correct.
If you can make it easy for me with a VM I can just download and run then I hope to be able to find what the problem is. Not one I have to play around with settings - as it is I've spent a bit of time just trying to get the thing running.
corbin
Post by corbin »
levynger wrote: done, removed old pull requests, patch-2 is ready with dual Click mode for the aqara wireless switch.
Thanks, can you check I re-opened the right pull request - they were all closed.
corbin
Post by corbin »
Can everyone that knows the sid of their gateway, report it here?
{"cmd":"iam","port":"9898","sid":"f0b4299ae4b8","model":"gateway","ip":"192.168.5.15"}
I want to see if I can shorten f0b4299ae4b8 so it can be converted to an int value.
vetalok
Domoticz version: 3.6273
Post by vetalok »
corbin wrote:Can everyone that knows the sid of their gateway, report it here?
('received message:', '{"cmd":"heartbeat","model":"gateway","sid":"f0b4299a6a3e","short_id":"0","token":"oaPNSolhcqpmG5gu","data":"{\\"ip\\":\\"192.168.2.193\\"}"}')
('received message:', '{"cmd":"heartbeat","model":"gateway","sid":"f0b4299a6a3e","short_id":"0","token":"tAivdgpTAgNZIoHV","data":"{\\"ip\\":\\"192.168.2.193\\"}"}')
('received message:', '{"cmd":"heartbeat","model":"gateway","sid":"f0b4299a6a3e","short_id":"0","token":"MSsVaS5tRVOmEEV8","data":"{\\"ip\\":\\"192.168.2.193\\"}"}')
('received message:', '{"cmd":"heartbeat","model":"gateway","sid":"f0b4299a6a3e","short_id":"0","token":"SXx5S6qwTYR1Wlto","data":"{\\"ip\\":\\"192.168.2.193\\"}"}')
('received message:', '{"cmd":"heartbeat","model":"gateway","sid":"f0b4299a6a3e","short_id":"0","token":"ofS1Uyk0A5YjR8FT","data":"{\\"ip\\":\\"192.168.2.193\\"}"}')
('received message:', '{"cmd":"report","model":"gateway","sid":"f0b4299a6a3e","short_id":0,"data":"{\\"rgb\\":1694498776}"}')
('received message:', '{"cmd":"report","model":"gateway","sid":"f0b4299a6a3e","short_id":0,"data":"{\\"rgb\\":0}"}')
('received message:', '{"cmd":"heartbeat","model":"gateway","sid":"f0b4299a6a3e","short_id":"0","token":"qOEkOTi9YEtWCsfX","data":"{\\"ip\\":\\"192.168.2.193\\"}"}')
('received message:', '{"cmd":"heartbeat","model":"gateway","sid":"f0b4299a6a3e","short_id":"0","token":"EKlvQaYzg5Dylvyd","data":"{\\"ip\\":\\"192.168.2.193\\"}"}')
And on page:
https://notes.jmsinfor.com/blog/post/admin/Xiaomi-Hub
see:
{'cmd': 'heartbeat', 'token': 'ydfnrsd4cjgIVcTj', 'model': 'gateway', 'sid': 'f0b429b3d7cc', 'data': '{"ip":"192.168.0.107"}', 'short_id': '0'}
f0b4299ae4b8
f0b429b3d7cc
f0b4299a6a3e
corbin
Post by corbin »
thanks, all starts with f0b4, so what I've coded should work.
Having a problem to convert the Domoticz Hue value into RGB for the gateway now...
vetalok
Post by vetalok »
corbin wrote: Having a problem to convert the Domoticz Hue value into RGB for the gateway now...
http://stackoverflow.com/questions/3018 ... 5-for-both
corbin
Post by corbin »
There is a hue2rgb function already but I might be using it wrong, will try some other functions too.
Edit - I was making a mistake. Gateway light is working now, setting to the correct colour.
murtadin
Post by murtadin »
May be you can give me ssh access to your VM which you hve installed? And i can install all neceseray libs in order to run domoticz. If not - i will do something on my side. Probably install gentoo on standalone host.
But who can explain - which are minimal requirements to run successful domoticz with xiaomi gateway? I mena linux kernel options, libs etc?
Tonight i installed ubuntu 14.04 server on new pc and tested domoticz. Almost all was working except minor bugs and look at this:
hats@u-srv2:/usr/local/git/domoticz$ sudo ldd domoticz
        linux-vdso.so.1 =>  (0x00007ffe79bf9000)
        libusb-0.1.so.4 => /lib/x86_64-linux-gnu/libusb-0.1.so.4 (0x00007f0aa24a2000)
        libssl.so.1.0.0 => /lib/x86_64-linux-gnu/libssl.so.1.0.0 (0x00007f0aa2243000)
        libcrypto.so.1.0.0 => /lib/x86_64-linux-gnu/libcrypto.so.1.0.0 (0x00007f0aa1e66000)
        librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f0aa1c5e000)
        libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007f0aa1a45000)
        libcurl.so.4 => /usr/lib/x86_64-linux-gnu/libcurl.so.4 (0x00007f0aa17dd000)
        libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f0aa15bf000)
        libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f0aa13bb000)
        libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f0aa10b4000)
        libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f0aa0cef000)
        /lib64/ld-linux-x86-64.so.2 (0x00005612bc6d3000)
        libidn.so.11 => /usr/lib/x86_64-linux-gnu/libidn.so.11 (0x00007f0aa0abc000)
        librtmp.so.0 => /usr/lib/x86_64-linux-gnu/librtmp.so.0 (0x00007f0aa08a1000)
        libgssapi_krb5.so.2 => /usr/lib/x86_64-linux-gnu/libgssapi_krb5.so.2 (0x00007f0aa065a000)
        liblber-2.4.so.2 => /usr/lib/x86_64-linux-gnu/liblber-2.4.so.2 (0x00007f0aa044b000)
        libldap_r-2.4.so.2 => /usr/lib/x86_64-linux-gnu/libldap_r-2.4.so.2 (0x00007f0aa01f9000)
        libgnutls.so.26 => /usr/lib/x86_64-linux-gnu/libgnutls.so.26 (0x00007f0a9ff3b000)
        libgcrypt.so.11 => /lib/x86_64-linux-gnu/libgcrypt.so.11 (0x00007f0a9fcba000)
        libkrb5.so.3 => /usr/lib/x86_64-linux-gnu/libkrb5.so.3 (0x00007f0a9f9ef000)
        libk5crypto.so.3 => /usr/lib/x86_64-linux-gnu/libk5crypto.so.3 (0x00007f0a9f7c0000)
        libcom_err.so.2 => /lib/x86_64-linux-gnu/libcom_err.so.2 (0x00007f0a9f5bb000)
        libkrb5support.so.0 => /usr/lib/x86_64-linux-gnu/libkrb5support.so.0 (0x00007f0a9f3b0000)
        libresolv.so.2 => /lib/x86_64-linux-gnu/libresolv.so.2 (0x00007f0a9f195000)
        libsasl2.so.2 => /usr/lib/x86_64-linux-gnu/libsasl2.so.2 (0x00007f0a9ef79000)
        libgssapi.so.3 => /usr/lib/x86_64-linux-gnu/libgssapi.so.3 (0x00007f0a9ed3b000)
        libtasn1.so.6 => /usr/lib/x86_64-linux-gnu/libtasn1.so.6 (0x00007f0a9eb27000)
        libp11-kit.so.0 => /usr/lib/x86_64-linux-gnu/libp11-kit.so.0 (0x00007f0a9e8e4000)
        libgpg-error.so.0 => /lib/x86_64-linux-gnu/libgpg-error.so.0 (0x00007f0a9e6df000)
        libkeyutils.so.1 => /lib/x86_64-linux-gnu/libkeyutils.so.1 (0x00007f0a9e4db000)
        libheimntlm.so.0 => /usr/lib/x86_64-linux-gnu/libheimntlm.so.0 (0x00007f0a9e2d1000)
        libkrb5.so.26 => /usr/lib/x86_64-linux-gnu/libkrb5.so.26 (0x00007f0a9e049000)
        libasn1.so.8 => /usr/lib/x86_64-linux-gnu/libasn1.so.8 (0x00007f0a9dda8000)
        libhcrypto.so.4 => /usr/lib/x86_64-linux-gnu/libhcrypto.so.4 (0x00007f0a9db74000)
        libroken.so.18 => /usr/lib/x86_64-linux-gnu/libroken.so.18 (0x00007f0a9d95f000)
        libffi.so.6 => /usr/lib/x86_64-linux-gnu/libffi.so.6 (0x00007f0a9d757000)
        libwind.so.0 => /usr/lib/x86_64-linux-gnu/libwind.so.0 (0x00007f0a9d52d000)
        libheimbase.so.1 => /usr/lib/x86_64-linux-gnu/libheimbase.so.1 (0x00007f0a9d31f000)
        libhx509.so.5 => /usr/lib/x86_64-linux-gnu/libhx509.so.5 (0x00007f0a9d0d6000)
        libsqlite3.so.0 => /usr/lib/x86_64-linux-gnu/libsqlite3.so.0 (0x00007f0a9ce1c000)
        libcrypt.so.1 => /lib/x86_64-linux-gnu/libcrypt.so.1 (0x00007f0a9cbe3000)
and same from gentoo:
desktop domoticz # ldd domoticz
        linux-vdso.so.1 (0x00007fffc2b5e000)
        libusb-0.1.so.4 => /lib64/libusb-0.1.so.4 (0x00007f814608c000)
        libssl.so.1.0.0 => /usr/lib64/libssl.so.1.0.0 (0x00007f8145e1c000)
        libcrypto.so.1.0.0 => /usr/lib64/libcrypto.so.1.0.0 (0x00007f81459d9000)
        librt.so.1 => /lib64/librt.so.1 (0x00007f81457d1000)
        libz.so.1 => /lib64/libz.so.1 (0x00007f81455ba000)
        libcurl.so.4 => /usr/lib64/libcurl.so.4 (0x00007f8145354000)
        libpthread.so.0 => /lib64/libpthread.so.0 (0x00007f8145138000)
        libdl.so.2 => /lib64/libdl.so.2 (0x00007f8144f34000)
        libm.so.6 => /lib64/libm.so.6 (0x00007f8144c2f000)
        libc.so.6 => /lib64/libc.so.6 (0x00007f8144896000)
        /lib64/ld-linux-x86-64.so.2 (0x00007f8146292000)
        libusb-1.0.so.0 => /lib64/libusb-1.0.so.0 (0x00007f814467e000)
But i have checked some libs - they are installed. Not all - cause i do not use kerberos, ldap and so on But may be some important libs are missed and for some reason, when i configure sources i see no errors at all about it.
P.S. - i really apreciate your help. Thank you.
vetalok
Post by vetalok »
Emm... When I enable LED from MiHome - Domoticz off light
Log:
2017-01-17 15:16:30.337 (XiaomiGateway) Lighting Limitless/Applamp (Xiaomi RGB Gateway)
2017-01-17 15:16:30.339 {"cmd":"report","model":"gateway","sid":"f0b4299a6a3e","short_id":0,"data":"{\"rgb\":1694440192}"}
2017-01-17 15:16:31.337 XiaomiGateway: Updating existing - nodeid: f0b4299a6a3e
2017-01-17 15:16:31.337 (XiaomiGateway) Lighting Limitless/Applamp (Xiaomi RGB Gateway)
2017-01-17 15:16:31.339 {"cmd":"report","model":"gateway","sid":"f0b4299a6a3e","short_id":0,"data":"{\"rgb\":0}"}
deennoo
Post by deennoo »
On/OFF looks to be solve since 1h30 gmt today
Have a different probleme :
brightness doesn't work but normal as show on log message :
2017-01-17 08:03:58.379 User: Admin initiated a switch command (8/Xiaomi RGB Gateway/Set Level)
2017-01-17 08:03:58.379 XiaomiGateway: Setting brightness not implemented, will try to fix this later
It's time to concidering a beer donation for corbin, do you have a paypal account ?
corbin
Post by corbin »
vetalok wrote: Emm... When I enable LED from MiHome - Domoticz off light
I've made a couple of changes, you will now need to turn the light on from the app to get it to detect in Domoticz, and I've added some extra log output. Can you try that and post the output if it still isn't working?
corbin
Post by corbin »
deennoo wrote: It's time to concidering a beer donation for corbin, do you have a paypal account ?
Appreciate that thanks, but If you want to make a donation, please use the donate link on https://www.domoticz.com/
