Domoboard - General Discussions
Moderators: leecollings, wez3
Forum rules
Before posting here, make sure you are using the latest Beta or Stable version.
In order to fix issues or add features these have to be reported on the Domoboard Github pages.
This makes it possible to keep track of issues/features on a centralized place.
Refer to the issue of the github tracker when possible.
This subforum is meant to discuss issues and/or feature requests, or anything else related to Domoboard.
domoj
Re: Domoboard a New Dashboard using Domoticz as backend
Hi again,
well, I did miss the one post on pm2 and the one on systemd. Anyways, I wouldn't say that this question had been asked and answered multiple times.
I just tried both pm2 and systemd. No luck with the pm2 solution but the 'systemd' solution as kindly advised by Snowtiger worked without issue (thanks pepinj).
As I said, I am new to domoticz, and fairly new to everything linux. Long time users to domoticz probably do not realize it, but searching for information on the forum is a daunting task. So, IMHO, Sateetje is right, it would be nice to have a subforum for everything related to basic install and configuration of domoboard (or a wiki ?).
Cheers
JY
Cheers
JY
Awst6000
No news here. Domoboard works fine for me.
The WAF factor raised skyhigh
Although there are some minor wishes:
- Sorting of the toptiles in the top_tiles sectors [[[1}]]] etc.
- Icons instead of the relatively large text (Open/closed/on/off) in the top_tiles
squandor
- Domoticz version: 3.5837
We are working on the sorting, we thought that it was fixed, but apparently something still is messing with it.Awst6000 wrote:No news here. Domoboard works fine for me.
What kind of icons gives the same impression as the Open/Closed and On/Off
On/Off could be the icons which are being used with the group section.
But open and closed are specific term so the icon must express this term.
Any ideas?
domoj
This has be raised before, but I don't think there is a definitive answer: is there a way to start domoboard without having to enter a username and password ? If not, could it be possible in the future ?
Awst6000
Maybe using the enlarged icon instead of the text? In red or green, depending on the status, like:squandor wrote:What kind of icons gives the same impression as the Open/Closed and On/Off
[[top_tiles]]
TV = 1, bolt or lightbulb
http://puu.sh/hPj3v/5e70de7d54.png
Awst6000
Intentionally in a new post.
Is it possible to add Philips Jointspace to Domoboard?
If yes, for more than one TV?
squandor
i should say anything is possible hahaAwst6000 wrote:Itentionally in a new post.
Awst6000
I wish I had the knowledge to write plugins...squandor wrote: i should say anything is possible hahabut therefore i think its best to create an plugin for it.
squandor
It's not about knowledge but try and errorAwst6000 wrote:I wish I had the knowledge to write plugins...squandor wrote: i should say anything is possible hahabut therefore i think its best to create an plugin for it.
Believe me i've had a lot of error's in my day's and still i would like to extend my programming but that takes time and there are only 24 hours in an day
- felix63
- Domoticz version: 2020.1
How nice it would be to integrate something like http://www.netdata.be/tv/ in domoboard!squandor wrote:i should say anything is possible hahaAwst6000 wrote:Itentionally in a new post.
If yes, for more than one TV?but therefore i think its best to create an plugin for it.
domoj
don't know if it's legit, but here is a workaround for the need to login at startup. Since I don't want to have a keyboard on the rpi+7 ' touchscreen, I'd rather do without the login page. The workaround is to pre-fill the login form.
Do not change the config file, keep as is:
then:
add change the lines
into
And voila. The login form is pre-filled, and one just has to confirm log in.
[[users]]
username = password # Add users for Domoboard here. In this case login with username "username" and password "password"
cd ~/domoboard/templates
cp login.html old_login.html
sudo nano login.html
<input type="username" name="username" class="form-control" required="yes" placeholder="Username">
and
<input type="password" name="password" class="form-control" id="inputPassword3" placeholder="Password" required="">
<input type="username" name="username" class="form-control" required="yes" placeholder="Username" value="username">
and
<input type="password" name="password" class="form-control" id="inputPassword3" placeholder="Password" required="" value="password">
Awst6000
I wrote a template for the Knmi-weatherpages.
Does this template has to be reviewed first?
(This template is probably only useful for Dutch people. Sorry)
Last edited by Awst6000 on Tuesday 17 January 2017 12:23, edited 6 times in total.
woody4165
English, please!Awst6000 wrote:Ik heb een template gemaakt voor de Knmi-actueel pagina's.
Dient deze eerst te worden gereviewed door iemand? Of kan ik deze hier gewoon plaatsen?
woody4165
Is Wundergound working?
I've tried both on master and dev, but with no success.
I've installed the plugin via web page, in general_setting i have
and in dashboard
with
in display_components
I don't see any new section in the web page and nothing in the log... very strange
thanks
[[wunderground]]
api = xxxxxx
language = EN (or IT)
[[wunderground]]
[[[forecast]]]
location = "Rome, IT"
[[[condition]]]
wunderground[forecast], wunderground[condition]I don't see any new section in the web page and nothing in the log... very strange
thanks
patricknooijen
had the same problem. Wunderground only worked with the developer repo, not the master.woody4165 wrote:Is Wundergound working?
I've installed the plugin via web page, in general_setting i haveand in dashboardCode: Select all
[[wunderground]] api = xxxxxx language = EN (or IT)withCode: Select all
[[wunderground]] [[[forecast]]] location = "Rome, IT" [[[condition]]] location = "Rome, IT"in display_componentsCode: Select all
thanks
woody4165
Thanks @patricknooijenpatricknooijen wrote: had the same problem. Wunderground only worked with the developer repo, not the master.
I've tried also with dev branch, on another ip port, in another folder, but no success...
PS: Actually in the log I can see
192.168.xx.xx - - [17/Jan/2017 12:42:11] "POST /api?custom=wunderground&loc=forecast&country=&action=Rome,IT HTTP/1.1" 200 -
192.168.xx.xx - - [17/Jan/2017 12:42:11] "POST /api?custom=wunderground&loc=condition&country=&action=Rome,IT HTTP/1.1" 200 -Cubietruck - Linux cubietruck 4.13.16 (Debian GNU/Linux 8 (jessie)) + Domoticz + RFLink, Xiaomi Gateway, Owl USB, Yeelight Color and B/W, ESP8266, Broadlink RM2, Netatmo Thermostat
patricknooijen
Try this :
[[wunderground]]
[[[forecast]]]
location = Rome, IT
[[[condition]]]
location = Rome, IT
woody4165
Using it without double quotes, now some values have changed positions
but seems still wrong, to me.
192.168.xx.xx - - [17/Jan/2017 13:39:09] "POST /api?custom=wunderground&loc=IT&country=condition&action=Rome HTTP/1.1" 200 -
192.168.xx.xx - - [17/Jan/2017 13:39:09] "POST /api?custom=wunderground&loc=IT&country=forecast&action=Rome HTTP/1.1" 200 -
patricknooijen
looks ok to me. When i use this it works. I use develop branch. Did you fill in your wunderground api key?woody4165 wrote:Using it without double quotes, now some values have changed positions
but seems still wrong, to me.Code: Select all
192.168.xx.xx - - [17/Jan/2017 13:39:09] "POST /api?custom=wunderground&loc=IT&country=condition&action=Rome HTTP/1.1" 200 - 192.168.xx.xx - - [17/Jan/2017 13:39:09] "POST /api?custom=wunderground&loc=IT&country=forecast&action=Rome HTTP/1.1" 200 -
i see you get the wrong order. try the develop branch please.
woody4165
got it.
I made a git clone, starting with the link in the dev page, but the link is the same as the master (or prob I missed something).
So I downloaded the dev zip and now wundergound is working.
But temp that I have in dashboard are not showed anymore, I will look into it.
Thanks again.
Thanks again.
