deennoo
Post by deennoo »
corbin wrote:The no_close message has changed from
"data":"{\"status\":\"no_close\"}"
to
"data":"{\"no_close\":\"60\"}"
the 60 looks to be the time in seconds the door has been open, which is more useful. I'll get the Domoticz code updated to handle it soon.
Check about PIR maybe it's the same.
http://domo-attitude.fr
Mat2Vence
Domoticz version: 3.7449
Post by Mat2Vence »
Does anyone succeed to find a way to send command to the mi home? Would be nice to be able to play the alarm, ring and play with the RGB?
corbin
Post by corbin »
Mat2Vence wrote:Does anyone succeed to find a way to send command to the mi home? Would be nice to be able to play the alarm, ring and play with the RGB?
The light can be controlled via the API, don't know about the alarm/audio yet. None of this is in Domoticz yet.
Mat2Vence
Post by Mat2Vence »
corbin wrote: The light can be controlled via the API, don't know about the alarm/audio yet. None of this is in Domoticz yet.
Is there any example of that? I have the switch, PIR and door sensor in the device list but nothing else.
Is there some documentation somewhere of the xiaomi API?
corbin
Post by corbin »
Mat2Vence wrote: Is there any example of that? I have the switch, PIR and door sensor in the device list but nothing else.
https://translate.google.com/translate? ... edit-text=
murtadin
Post by murtadin »
Still can't run domoticz on my linux server normally. RGBW yeelight works, but gateway and all attached devices don't. Updated today my system, upgraded kernel and still no luck. Configuring, making without any errors. If i restore DB from backup - got this error in log:
2017-01-13 01:53:54.637  User: Admin initiated a switch command (16/Xiaomi Smart Plug/On)
2017-01-13 01:53:54.637  0117A188
2017-01-13 01:53:54.787  XiaomiGateway: response {"cmd":"write_ack","sid":"158d000117a188","data":"{\"error\":\"Invalid key\"}"}
Pls help me debug this andput this to work. Can provide any information you need. :( :( :(
deennoo
Post by deennoo »
Message is explicit : invalid key
Are you sure of your key ? Did you respect min and maj ?
corbin
Post by corbin »
deennoo wrote: Check about PIR maybe it's the same.
yes it is, I'll have some updates to do over the weekend!
murtadin
Post by murtadin »
deennoo wrote:Message is explicit : invalid key
Of course key is correct. I have checked it 100 times. What do you mean did i respect min and maj? English is not my native language. Do you mean case?
deennoo
Post by deennoo »
Mine to :
A : maj
a : min
But can't be the issue, you 'ill not be able to retrive your plug.
corbin
Post by corbin »
murtadin wrote: Pls help me debug this andput this to work. Can provide any information you need. :( :( :(
could it be Gentoo Linux not having all the software/components installed to do the key encryption?
murtadin
Post by murtadin »
It is possible - how can i check this? Is all traffic between domoticz and mi gateway encrypted?
corbin
Post by corbin »
murtadin wrote: It is possible - how can i check this?
Not familiar with Gentoo, but did have a look last night and it looks like you have to configure most parts yourself? If you try a pre-configured distro, does it still not work?
murtadin
Post by murtadin »
i have tried binaries, but there was error about usb libs. but i do not use any usb devices. will try install all necessary libs later and try one more time precompiled binaries.
Sent from my MI MAX using Tapatalk
corbin
Post by corbin »
deennoo wrote: Maybe disable auto off for cube and round switch, a switch never turn off it just state change (clik, long clik etc) same for cube each mouvement is a new one
Try https://github.com/corbinmunce/domoticz for the rotate command handling - I haven't changed the on/off status part, you can easily adjust the source though.
corbin
Post by corbin »
murtadin wrote: i have tried binaries, but there was error about usb libs. but i do not use any usb devices. will try install all necessary libs later and try one more time precompiled binaries.
I don't think that usb libs error is related, but wouldn't rule it out.
Can you give me a URL for a Gentoo image/ISO I can use for a Vmware VM?
murtadin
Re: RE: Re: RE: Re: Xiaomi Smart Home Suite (very cheap) compatibilty?
Post by murtadin »
https://mirrors.kernel.org/gentoo//rele ... /20160704/
But i do not use generic kernel. I have built my system almost from the scratch. But i will try generic kernel from livedvd too.
corbin
Post by corbin »
Do you know what base settings to use for Vmware - ie Ubuntu x64...?
murtadin
Post by murtadin »
corbin wrote:Do you know what base settings to use for Vmware - ie Ubuntu x64...?
you can try vmware images https://www.osboxes.org/gentoo/
deennoo
Post by deennoo »
Just test "rotate", fonction are created on cube selector switch but they aren't linked to the gateway message. other fonction are ok
