Yes, but still no date without a click on the time.dutchdevil83 wrote: 1) Do you have true spelled with a capital T in your config? If you look into my config above you see a config which should work
Domoboard - General Discussions
Moderators: leecollings, wez3
Forum rules
Before posting here, make sure you are using the latest Beta or Stable version.
In order to fix issues or add features these have to be reported on the Domoboard Github pages.
This makes it possible to keep track of issues/features on a centralized place.
Refer to the issue of the github tracker when possible.
This subforum is meant to discuss issues and/or feature requests, or anything else related to Domoboard.
Awst6000
Re: Domoboard a New Dashboard using Domoticz as backend
dutchdevil83
- Domoticz version: latest
Have got it to work. You have to generate a API key and fill this in your configuration file :Routernl wrote:Looking good !
Did you manage to get the traffic working with Google maps ?I'm still struggling with that.
[[domoboard]]
google_maps_api_key = yourkeyhere # Google Maps Embed API keyHardware
1x Raspberry Pi
1x Razberry Z-Wave
1x RFXtrx433E
1x Toon
1x GoodWe Solarpanels
2x FGSD-002 Smoke Detector
1x FGBS-001 Binaire Sensor (RFID lezer)
7x FGMS-001 Motion Sensor
3x ZW089 Verzonken Deursensor
7x NC Wallplug
&lots of KaKu stuff
1x Raspberry Pi
1x Razberry Z-Wave
1x RFXtrx433E
1x Toon
7x NC Wallplug
&lots of KaKu stuff
Awst6000
Yesterday I created an API key and filled it in, but nothing seems to happen in Domoboard.dutchdevil83 wrote:Have got it to work. You have to generate a API key and fill this in your configuration file :
google_maps_api_key = yourkeyhere # Google Maps Embed API key[/code]
Is there perhaps a screenshot of what I should get?
Txs
SwordFish
- Domoticz version: V4.11375
I've been following this topic from the start and its looks great. When I have time i give it a try.
Is it also possible to add Google calendar to Domoboard?
jossie67
I like the Domo dashboard a lot.
I try to make a new tab with deuren
I can see the tab Deuren, but there is no information in the tab.
What do i do wrong
[deur]
[[display_components]]
components = Deuren
[[Deuren]]
Voordeur = 1149, info
Achterdeur = 1156, infoI can see the tab Deuren, but there is no information in the tab.
What do i do wrong
Raspberry Pi (3x)
Master Domoticz installed on a Synology
RFXCOM RFXtrx433E USB
RFLink
USB Z-Wave Mini Adapter
Mi-light
QuinLED
Landis+Gyr ZME120ACd
Kamstrup_M401
USB-IR-Schreib-Lesekopf Alecto WS1700
Watermeter with TCRT5000
Kodi
DS18B20
RFLink
Mi-light
QuinLED
Kamstrup_M401
Kodi
DS18B20
jhenrikb
Could you also zip your "templates" folder? I fixed some of my issues after seeing how your config file is, but my page looks really messed up. Huge spaces between Switches and Weather etc.
John
John
dutchdevil83
You have to charge the line components = Deuren to components = top_tiles[Deuren]jossie67 wrote:Hi,
[deur] [[display_components]] components = Deuren [[Deuren]] Voordeur = 1149, info Achterdeur = 1156, info
What do i do wrong
Hardware
1x Raspberry Pi
1x Razberry Z-Wave
1x RFXtrx433E
1x Toon
7x NC Wallplug
&lots of KaKu stuff
1x Raspberry Pi
1x Razberry Z-Wave
1x RFXtrx433E
1x Toon
7x NC Wallplug
&lots of KaKu stuff
dutchdevil83
Can you post a screenshot? Don't charge anything in the templates folder. This isn't needed.jhenrikb wrote:Thanks
John
Hardware
1x Raspberry Pi
1x Razberry Z-Wave
1x RFXtrx433E
1x Toon
7x NC Wallplug
&lots of KaKu stuff
1x Raspberry Pi
1x Razberry Z-Wave
1x RFXtrx433E
1x Toon
7x NC Wallplug
&lots of KaKu stuff
- blackdog65
Hi guys,
I'm trying to get Wunderground working but I get when I try to start it... any ideas?
Error occured during loading imports for the plugin wunderground: No module named geocoderCubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
jhenrikb
Ah ok. I have only changed header texts to norwegian and Weather-country etc. Small things.
Thought you might had organized something in HTML design wise. I can post later after work.
I also get answp(don't remember exact name, but it's the file that comes with traffic plugin) error in putty when running Traffic. So I had to delete it in order to start it. That's why I thought maybe u changed something in the traffic.html
Last point is that is shows update available under time and date, but it doesn't update even I run in debug.
Thanks for your great help so far, kind of you.
- felix63
- Domoticz version: 2020.1
blackdog65 wrote:Hi guys,
I'm trying to get Wunderground working but I getwhen I try to start it... any ideas?Code: Select all
sudo easy_install geocoded- felix63
sudo easy_install geocoder-
dutchdevil83
Had that problem too. Just open putty and dojhenrikb wrote:Ah ok. I have only changed header texts to norwegian and Weather-country etc. Small things.
git pullHardware
1x Raspberry Pi
1x Razberry Z-Wave
1x RFXtrx433E
1x Toon
7x NC Wallplug
&lots of KaKu stuff
1x Raspberry Pi
1x Razberry Z-Wave
1x RFXtrx433E
1x Toon
7x NC Wallplug
&lots of KaKu stuff
- blackdog65
many thanks... obvious when you see it
I doesn't show up on my dashboard though
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
dutchdevil83
Check your config file and compare with the config i posted. Probaly you figure it out why it isn't showing...blackdog65 wrote:@felix63
many thanks... obvious when you see it![]()
Hardware
1x Raspberry Pi
1x Razberry Z-Wave
1x RFXtrx433E
1x Toon
7x NC Wallplug
&lots of KaKu stuff
1x Raspberry Pi
1x Razberry Z-Wave
1x RFXtrx433E
1x Toon
7x NC Wallplug
&lots of KaKu stuff
- blackdog65
anddutchdevil83 wrote:Check your config file and compare with the config i posted. Probaly you figure it out why it isn't showing...blackdog65 wrote:@felix63
I have
[general_settings]
[[wunderground]]
api = xxxxxxxxxxxxxxxx
language = ENCode: Select all
[dashboard]
components = top_tiles, switches[Switches], news, wunderground[forecast]
[[top_tiles]]
Sitting Room = 361, television
Kitchen = 372, cutlery
Z-Bedroom = 374, bed
V-Bedroom = 363, bed
S-Bedroom = 369, bed
Outside = 77, thermometer-full
[[switches]]
[[[Switches]]]
D-Gong = 56, pushon
SR_Main = 389, dimmer
[[wunderground]]
[[[forecast]]]
location = "Wisbech, GB"
[[news]]
rssfeed = http://newsrss.bbc.co.uk/rss/newsonline_uk_edition/uk/rss.xmlCode: Select all
wunderground[condition]CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
wez3
This one should be fixed:dutchdevil83 wrote:i`m on develop. Trying to debug in chrome inspector but can`t get it to fix.felix63 wrote:I think my icons have disappeared from the top tiles. are you running development or master? It might be a bug?dutchdevil83 wrote:Looking at my pages i see that i don`t have the icons displayed in the top_tiles. Anyone knows why this isn`t loading? The icons on the right navbar is loading properly so i think the font file is correct.
https://github.com/wez3/domoboard/issues/71
Sateetje
No, no adblocker installed and on different browsers almost the same result (on IOS i've an icon at Plastic verpakkingen).dutchdevil83 wrote:Do you have a adblocker installed or something? Can you look into your page with multiple devices/browsers ?Sateetje wrote:My "afvalwijzer" on the left looks different. How do I get the nice icons?
dutchdevil83
@blackdog65
Can you try following link in your browser if jou get Json result back? (Fill in your API key)
http://api.wunderground.com/api/api_key ... sbech.json
Hardware
1x Raspberry Pi
1x Razberry Z-Wave
1x RFXtrx433E
1x Toon
7x NC Wallplug
&lots of KaKu stuff
1x Raspberry Pi
1x Razberry Z-Wave
1x RFXtrx433E
1x Toon
7x NC Wallplug
&lots of KaKu stuff
dutchdevil83
Mmm strange... you can check with Chrome Inspector tool for errors when loading the page. In Chrome press (CTRL+SHIFT+J) and check preserve log to follow loading trail. Also could be that you are missing some files in the afvalwijzer plug-in folder. You can try to copy the folder from github...Sateetje wrote:No, no adblocker installed and on different browsers almost the same result (on IOS i've an icon at Plastic verpakkingen).dutchdevil83 wrote:Do you have a adblocker installed or something? Can you look into your page with multiple devices/browsers ?Sateetje wrote:My "afvalwijzer" on the left looks different. How do I get the nice icons?
Hardware
1x Raspberry Pi
1x Razberry Z-Wave
1x RFXtrx433E
1x Toon
7x NC Wallplug
&lots of KaKu stuff
1x Raspberry Pi
1x Razberry Z-Wave
1x RFXtrx433E
1x Toon
7x NC Wallplug
&lots of KaKu stuff
