fergalom
Re: Domoticz app 2.0
working here also now, thanks!
Sorry for the nitpicking, but on the Wiki it states URL instead of URI.galadril wrote:changed the wiki also:
https://github.com/domoticz/domoticz-an ... /NFC-Setup
It might confuse others.
NiklasO
- Target OS: -
Still can't add widgets. Any suggestions?
jjnj
Re: RE: Re: Domoticz app 2.0
Is the app installed on the SD or internal memory?NiklasO wrote:Still can't add widgets. Any suggestions?
- galadril
- Domoticz version: latest
You'll probably need to reconfigure widgets when installing the next beta..
Also transparant!!
Also transparant!!
piokuc
For me one big problem is slider for dimmer. Is too small. Is not comfortable. I use Galaxy S6 with big sreen more han 5" and sometimes i can not setup correct value gor dimmer. I have big finger and it is prolem. Maybe good option will be setup slider under all text and to setup full size ?
tjabas
galadril wrote:You'll probably need to reconfigure widgets when installing the next beta..
Also transparant!!
oh man!! i´ve always wanted the transparent widget, where can i get the beta version?
I don't know if I did something wrong... I installed the application to my phone and all working beside blinds...
It is not available at the Android app. Is that ok???
Sent from my ASUS_Z00AD using Tapatalk
NiklasO
- Target OS: -
No SD card slot.jjnj wrote:Is the app installed on the SD or internal memory?NiklasO wrote:Still can't add widgets. Any suggestions?
Can't say when it started to tell me that I need the premium version for widgets. It has worked before because I had widgets already in place but they dissappeared when I tried to reinstall the app of course so now I have none...
martk
new widgets are nice, but it comes with a few bugs..
If you add a scene widget, you can only turn it on, not off. Little irritating as I use this widget to turn off my home lights
If you add a push button widget it used to have one button named On, now it has a button named Off (uit in my case, dutch), it still works though.
tjabas
Where can i get this beta version of the app?
micha_pr
Refresh status / values
I have found several questions about this, but no answer - maybe haven't seen it - and somebody can help?
How to configure the App that values will be refreshed after some time - like door sensor, temperature etc.
I see all the time the "old" values.
Or is this "by design" and should not be refreshed (like in other apps) ?
Michael
Michael
Michael Pruefer
http://www.zwave-review.com (German only)
http://www.SmartHome.Work (German only)
NiklasO
- Target OS: -
Updated a couple of minutes ago, I can now add widgets again!
- galadril
At this moment you can refresh a screen by pulling the list down.micha_pr wrote: How to configure the App that values will be refreshed after some time - like door sensor, temperature etc.
- galadril
Good to know!NiklasO wrote:Updated a couple of minutes ago, I can now add widgets again!
- galadril
You can find a link to the play store to become beta tester here:tjabas wrote:Where can i get this beta version of the app?
http://hnogames.nl/domoticz.html
(at the bottom)
- galadril
ill test them!martk wrote:If you add a scene widget, you can only turn it on, not off. Little irritating as I use this widget to turn off my home lights
- galadril
blinds should work....roiz wrote: I don't know if I did something wrong... I installed the application to my phone and all working beside blinds...
ultratoto14
Hi Galadril,
Do not know if it was asked before but i have some problem with the axes on the graphs.
I added a screenshot of my wind graph (i'm french so Wind = Vent) and the axes labels are not readable.
Is it something you are aware of ?
Best regards,
U.
Best regards,
U.
- Screenshot_2017-01-13-13-46-05.png (125.21 KiB) Viewed 2227 times
- galadril
Ill at it to the listultratoto14 wrote: Do not know if it was asked before but i have some problem with the axes on the graphs.
