fergalom
Re: Domoticz app 2.0
Post by fergalom »
working here also now, thanks!
EddyG
Post by EddyG »
galadril wrote:changed the wiki also:
https://github.com/domoticz/domoticz-an ... /NFC-Setup
Sorry for the nitpicking, but on the Wiki it states URL instead of URI.
It might confuse others.
NiklasO
Post by NiklasO »
Still can't add widgets. Any suggestions?
jjnj
Re: RE: Re: Domoticz app 2.0
Post by jjnj »
NiklasO wrote:Still can't add widgets. Any suggestions?
Is the app installed on the SD or internal memory?
galadril
Domoticz version: latest
Post by galadril »
You'll probably need to reconfigure widgets when installing the next beta..
Also transparant!!
piokuc
Post by piokuc »
For me one big problem is slider for dimmer. Is too small. Is not comfortable. I use Galaxy S6 with big sreen more han 5" and sometimes i can not setup correct value gor dimmer. I have big finger and it is prolem. Maybe good option will be setup slider under all text and to setup full size ?
tjabas
Post by tjabas »
galadril wrote:You'll probably need to reconfigure widgets when installing the next beta..
Also transparant!!
oh man!! i´ve always wanted the transparent widget, where can i get the beta version?
roiz
Post by roiz »
I don't know if I did something wrong... I installed the application to my phone and all working beside blinds...
It is not available at the Android app. Is that ok???
Sent from my ASUS_Z00AD using Tapatalk
NiklasO
Post by NiklasO »
No SD card slot. ;-)
Can't say when it started to tell me that I need the premium version for widgets. It has worked before because I had widgets already in place but they dissappeared when I tried to reinstall the app of course so now I have none...
martk
Post by martk »
new widgets are nice, but it comes with a few bugs..
If you add a scene widget, you can only turn it on, not off. Little irritating as I use this widget to turn off my home lights ;)
If you add a push button widget it used to have one button named On, now it has a button named Off (uit in my case, dutch), it still works though.
tjabas
Post by tjabas »
Where can i get this beta version of the app?
micha_pr
Post by micha_pr »
Refresh status / values
I have found several questions about this, but no answer - maybe haven't seen it - and somebody can help?
How to configure the App that values will be refreshed after some time - like door sensor, temperature etc.
I see all the time the "old" values.
Or is this "by design" and should not be refreshed (like in other apps) ?
Michael
Michael Pruefer
http://www.zwave-review.com (German only)
http://www.SmartHome.Work (German only)
NiklasO
Post by NiklasO »
Updated a couple of minutes ago, I can now add widgets again! :D
galadril
Post by galadril »
micha_pr wrote: How to configure the App that values will be refreshed after some time - like door sensor, temperature etc.
At this moment you can refresh a screen by pulling the list down.
galadril
Post by galadril »
NiklasO wrote:Updated a couple of minutes ago, I can now add widgets again! :D
Good to know!
galadril
Post by galadril »
tjabas wrote:Where can i get this beta version of the app?
You can find a link to the play store to become beta tester here:
http://hnogames.nl/domoticz.html
(at the bottom)
galadril
Post by galadril »
martk wrote:If you add a scene widget, you can only turn it on, not off. Little irritating as I use this widget to turn off my home lights ;)
ill test them!
galadril
Post by galadril »
roiz wrote: I don't know if I did something wrong... I installed the application to my phone and all working beside blinds...
blinds should work....
ultratoto14
Post by ultratoto14 »
Hi Galadril,
Do not know if it was asked before but i have some problem with the axes on the graphs.
I added a screenshot of my wind graph (i'm french so Wind = Vent) and the axes labels are not readable.
Is it something you are aware of ?
Best regards,
U.
galadril
Post by galadril »
ultratoto14 wrote: Do not know if it was asked before but i have some problem with the axes on the graphs.
Ill at it to the list
