Device's getting forgotton about / dropping off
stuiow
Domoticz version: 3.6857
Post by stuiow »
Last few weeks, i've had issues with 2 devices jsut getting bored and stop communicating.
I've tried all sorts to node heal, refreshing node info, excluding and including it and none of this worked.
I managed to eventually include the node, but now i have 2 of the same device that used to be the device, but will not remove from my openzwave list.
How do i get rid of them? I tried the delete button in domoticz on the z-wave device list.
It disappears off from that list, but not the openzwave list.
Also, i've also had issues with devices just getting forgotton about altogether.
For instance, a window sensor dropped off all lists.
What is causing all these issues?
I'm running pi2 with a Razberry 1
Domoticz 3.6312
Cheers
Now setup on a RPI3.
Also using Evohome HGI80, RFXTRX433E and a Aeotec Gen5 stick. Mainly a Gen5 Z-Wave system.
My weather (Davis vantage Pro2) data is obtained by weatherunderground
Now collecting rtl_433 data from Apollo Ultrasonic meter
geezerrr
Re: Device's getting forgotton about / dropping off
Post by geezerrr »
Hi you can remove the devices as in this topic viewtopic.php?t=3224
stuiow
Post by stuiow »
ah excellent, going through the editing the .xml file has finally forced those devices are dead.
Just stuck there, but i'll get there now they're marked dead.
Cheers!
