Cant get devices to my.domoticz.com (proxy error)
TommyE
Domoticz version: 3.5877
Post by TommyE »
Hi.
First post here.
I have been trying to get my.domoticz.com to work, but I do something wrong and can't find out where to go next.
I have logged in to my.domoticz.com
I have created a account.
I have set up my domoticz server to use MyDomoticz (Setup/Settings/MyDomoticz settings:)
I have entered my API key and my password.
I checked Enabled and Shared Domoticz Allowed.
In domoticz I get this in my logg.
2016-12-06 14:45:26.209 Proxymanager started.
2016-12-06 14:45:26.211 Accepting shared server connections via MyDomotiz (see settings menu).
2016-12-06 14:45:26.218 Active notification subsystems: email (1/12)
After a few seconds I get
2016-12-06 14:45:41.327 Error: PROXY: StartThread(): Exception: resolve: Host not found (authoritative)
After that nothing happens.
I have been googling for this alot now, the only thing that I have found is a entry in proxyclient.cpp where it @ line 100 says
std::string address = "domoproxy.domoticz.com";
https://github.com/domoticz/domoticz/bl ... client.cpp
I can ping that adress from my Raspberry Pi, and I can connect to it from my work computer.
I tried to add domoproxy.domoticz.com with ip nr to my hosts file, but to no avail.
Any ideas what to try now?
By the way I have not got a MyDomoticz Instase ID.
Tommy
Running
Raspberry PI3
Latest jessi.
Domoticz 3.5877
Nginx webserver (that I tried to disable).
TommyE
Re: Cant get devices to my.domoticz.com (proxy error)
Post by TommyE »
Nobody have an idea?
I have now tried to install Domoticz on my Windows 10 computer, got the same error message.
I also tried to make a new my.domoticz account, still no go.
Does anyone have it working? Is there any point for me to keep trying on my side, or is it a problem @ my.domoticz.
Any help would be appriciated.
Keith66
Post by Keith66 »
I have the same problem, i'm new to this is it some mistake?
2016-12-10 19:22:30.192 Proxymanager started.
2016-12-10 19:22:30.203 Accepting shared server connections via MyDomotiz (see settings menu).
2016-12-10 19:22:30.230 Active notification subsystems: (0/12)
2016-12-10 19:22:45.237 Error: PROXY: StartThread(): Exception: resolve: Host not found (authoritative)
I have changed the password but still no luck?
I am running domoticz on a RaspberryPi Zero and accessing from my macbook pro using firefox.
About Domoticz
Version: 3.5877
Build Hash: 15b013c
Compile Date: 2016-11-10 15:44:33
Uptime: 7 Days, 6 Minutes, 25 Seconds
Screen Shot 2016-12-10 at 19.26.jpg (116.91 KiB) Viewed 4995 times
rpusztai
Post by rpusztai »
I am also getting the same error when trying to enable the my.domoticz service and it doesn't seem to be working.
2016-12-12 22:21:36.987 Proxymanager started.
2016-12-12 22:21:36.995 Active notification subsystems: (0/12)
2016-12-12 22:21:48.756 Hardware Monitor: Fetching data (System sensors)
2016-12-12 22:21:52.012 Error: PROXY: StartThread(): Exception: resolve: Host not found (authoritative)
Any ideas on why this is happening?
Kender
Post by Kender »
Same problem here, tried also to change DNS servers ... simply doesn't work :(
Any idea ??
zacson
Post by zacson »
Same issue for me while enabling mydomoticz feature. Tried Domoticz build 3.5877 on both Window 10(64Bit) & Raspberry Pi 3 (Jessie Lite).
Log - Error: PROXY: StartThread(): Exception: resolve: Host not found (authoritative)
zacson
Post by zacson »
This seems to be a known issue in the latest stable release. To use mydomoticz we need to switch to the latest beta or wait for the next release.
Please refer the following thread for further information - viewtopic.php?f=47&t=7764&start=360
Diederik
Post by Diederik »
Domoticz works fine, I stil get a long list of proxy errors ?
2017-01-17 21:26:13.769 Error: PROXY: Connect failed, reconnecting: resolve: Host not found (authoritative)
What is wrong ?
