I can use the switch, but have no idea what to do with the rest
Cheap chinese z-wave products
DarkAllMan
Re: Cheap chinese z-wave products
Received and added Neo Coolcam powerplug. But can someone explain all the devices and how to use them?
- sincze
- Domoticz version: 2024.4
Re: RE: Re: Cheap chinese z-wave products
A nice overview of what you receive for around 30 euroDarkAllMan wrote: Received and added Neo Coolcam powerplug. But can someone explain all the devices and how to use them?
Sent from my SM-G925F using Tapatalk
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Really crapy build, the ground connector is just forced together with that little screw that is screwed to the plastic... This can't meet any standard. You unscrew and their is no ground, and you don't even know if it's connected when you screw it together again. Just hope the metal touch each other.
Safe haha
Skickat från min A0001 via Tapatalk
Safe haha
- LouiS22
As the users manual clearly explains, the power plug is able to monitor your energy consumption. So 10 or 11 (you'll see that after a day or so) will be your total consumption (in kwh), 11 is the current consumption (or the total, you'll see that), 12 is the current voltage while 13 is the current ampere.DarkAllMan wrote:neopp.PNG
- LouiS22
Have you thought that maybe, just maybe yours is a defective one?zalsson wrote:Really crapy build, the ground connector is just forced together with that little screw that is screwed to the plastic... This can't meet any standard. You unscrew and their is no ground, and you don't even know if it's connected when you screw it together again. Just hope the metal touch each other.
Safe haha
Haha one of four broken, it's not that.LouiS22 wrote:Have you thought that maybe, just maybe yours is a defective one?zalsson wrote:Really crapy build, the ground connector is just forced together with that little screw that is screwed to the plastic... This can't meet any standard. You unscrew and their is no ground, and you don't even know if it's connected when you screw it together again. Just hope the metal touch each other.
Safe haha
Its the way it's build, that ground is connected thru a single little screw that easily will brake. And that's for all four.
You have to be a seller for coolcam? Right? Because you argue like it's your own personal stuff, and can't see the fact that it's "cheap" Chinese quality. That not meet the the other manufacturers standard and quality/ control... But it's a little cheaper, will buy fibaro next time and can't recommend this after a couple of weeks use.
- LouiS22
No, I'm not a seller, just a happy user. And btw you're rude.zalsson wrote:Haha one of four broken, it's not that.LouiS22 wrote:Have you thought that maybe, just maybe yours is a defective one?zalsson wrote:Really crapy build, the ground connector is just forced together with that little screw that is screwed to the plastic... This can't meet any standard. You unscrew and their is no ground, and you don't even know if it's connected when you screw it together again. Just hope the metal touch each other.
Safe haha
Re: RE: Re: RE: Re: Cheap chinese z-wave products
Yeah rightLouiS22 wrote:No, I'm not a seller, just a happy user. And btw you're rude.zalsson wrote:Haha one of four broken, it's not that.LouiS22 wrote:
mschut
- Domoticz version: V3.5613
Nice pictures. Shows its build clearly. Did you find any fuse? Two of mine "died". Am wondering whether it's repearable or not.
Verstuurd vanaf mijn SM-G920F met Tapatalk
No fuse, I think, dead is deadmschut wrote:Nice pictures. Shows its build clearly. Did you find any fuse? Two of mine "died". Am wondering whether it's repearable or not.
mschut
No Penny Dreadful magic indeed. Luckily good after sales service.zalsson wrote:No fuse, I think, dead is deadmschut wrote:Nice pictures. Shows its build clearly. Did you find any fuse? Two of mine "died". Am wondering whether it's repearable or not.
deennoo
Got 2 power plug on my side one from august, one from november and no worry with them.
Yeap i don't plug/unplug them every day, i don't open them. Just use them on a normal way...and just respect zwave inclusion recommandation :
Put them on their definitve place, and inclued them...
http://domo-attitude.fr
Justintime
Got two of them still going strong.
Really don't understand all the fuzz of the ground pin... Looks well to me.
trixwood
Well that the insurance won't pay when you burn you're house down...Really don't understand all the fuzz of the ground pin... Looks well to me.
But no fuse? Really?
Justintime
There is a fuse in it... I can see it.trixwood wrote:Well that the insurance won't pay when you burn you're house down...Really don't understand all the fuzz of the ground pin... Looks well to me.
It's a polyfuse. So don't panic all if you don't know electronics.
trixwood
fuzz i meant to type no fuzz...
but no fuse works too...
neo powerplug, no fuzz, no grounds for no fuse...
Justintime
Neo Powerplug, with a Fuse and ground.
(lots of appliance powerplugs even don't have ground)
So indeed no Fuzz. Use it with confidence. Least I will if need more.
Guess some people are a bit frustrated because of a defective product. Please claim your guarantee with the seller.
(lots of appliance powerplugs even don't have ground) So indeed no Fuzz. Use it with confidence. Least I will if need more.
Last edited by Justintime on Monday 02 January 2017 10:37, edited 1 time in total.
mschut
is the fuse replaceable? Prefer that in stead of returning.
Users browsing this forum: madpatrick and 1 guest
