Cheap chinese z-wave products
DarkAllMan
Re: Cheap chinese z-wave products
Post by DarkAllMan »
Received and added Neo Coolcam powerplug. But can someone explain all the devices and how to use them?
I can use the switch, but have no idea what to do with the rest :)
sincze
Domoticz version: 2024.4
Re: RE: Re: Cheap chinese z-wave products
Post by sincze »
A nice overview of what you receive for around 30 euro Image
Sent from my SM-G925F using Tapatalk
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
zalsson
Post by zalsson »
Really crapy build, the ground connector is just forced together with that little screw that is screwed to the plastic... This can't meet any standard. You unscrew and their is no ground, and you don't even know if it's connected when you screw it together again. Just hope the metal touch each other.
Safe haha
Skickat från min A0001 via Tapatalk
LouiS22
Post by LouiS22 »
DarkAllMan wrote:neopp.PNG
As the users manual clearly explains, the power plug is able to monitor your energy consumption. So 10 or 11 (you'll see that after a day or so) will be your total consumption (in kwh), 11 is the current consumption (or the total, you'll see that), 12 is the current voltage while 13 is the current ampere.
LouiS22
Post by LouiS22 »
zalsson wrote:Really crapy build, the ground connector is just forced together with that little screw that is screwed to the plastic... This can't meet any standard. You unscrew and their is no ground, and you don't even know if it's connected when you screw it together again. Just hope the metal touch each other. Image
Safe haha
Have you thought that maybe, just maybe yours is a defective one?
zalsson
Post by zalsson »
Safe haha
Haha one of four broken, it's not that.
Its the way it's build, that ground is connected thru a single little screw that easily will brake. And that's for all four.
You have to be a seller for coolcam? Right? Because you argue like it's your own personal stuff, and can't see the fact that it's "cheap" Chinese quality. That not meet the the other manufacturers standard and quality/ control... But it's a little cheaper, will buy fibaro next time and can't recommend this after a couple of weeks use.
zalsson
Post by zalsson »
zalsson
Post by zalsson »
LouiS22
Post by LouiS22 »
zalsson wrote:
Safe haha
No, I'm not a seller, just a happy user. And btw you're rude.
zalsson
Re: RE: Re: RE: Re: Cheap chinese z-wave products
Post by zalsson »
Yeah right
mschut
Domoticz version: V3.5613
Post by mschut »
Nice pictures. Shows its build clearly. Did you find any fuse? Two of mine "died". Am wondering whether it's repearable or not.
Verstuurd vanaf mijn SM-G920F met Tapatalk
zalsson
Post by zalsson »
mschut wrote:Nice pictures. Shows its build clearly. Did you find any fuse? Two of mine "died". Am wondering whether it's repearable or not.
No fuse, I think, dead is dead :(
mschut
Post by mschut »
No Penny Dreadful magic indeed. Luckily good after sales service.
deennoo
Post by deennoo »
Got 2 power plug on my side one from august, one from november and no worry with them.
Yeap i don't plug/unplug them every day, i don't open them. Just use them on a normal way...and just respect zwave inclusion recommandation :
Put them on their definitve place, and inclued them...
http://domo-attitude.fr
Justintime
Post by Justintime »
Got two of them still going strong.
Really don't understand all the fuzz of the ground pin... Looks well to me.
trixwood
Post by trixwood »
Well that the insurance won't pay when you burn you're house down...
But no fuse? Really?
Justintime
There is a fuse in it... I can see it.
It's a polyfuse. So don't panic all if you don't know electronics.
trixwood
Post by trixwood »
fuzz i meant to type no fuzz... :-) but no fuse works too...
neo powerplug, no fuzz, no grounds for no fuse...
Justintime
Neo Powerplug, with a Fuse and ground. (lots of appliance powerplugs even don't have ground)
So indeed no Fuzz. Use it with confidence. Least I will if need more.
Guess some people are a bit frustrated because of a defective product. Please claim your guarantee with the seller.
Last edited by Justintime on Monday 02 January 2017 10:37, edited 1 time in total.
mschut
Post by mschut »
is the fuse replaceable? Prefer that in stead of returning.
