Youless Power Watt Graph (value is divided by 10)
ludwigkempenaar
Post by ludwigkempenaar »
Had some trouble setting up my Youless... (no daily usage value, but Siewert308SW helped me out :-))
I changed the RFXMeter/Meter dividers... (for energy from 1000 to 100000). That changed the KwH value to the right numbers... But it also changes the Power usage in Watts (which is a factor 100 lower now).The KwH value on the left axes are right, but the actual Power usage in Watt not.
Schermafdruk 2016-12-30 11.07.10.png (350.84 KiB) Viewed 643 times
Schermafdruk 2016-12-30 11.01.14.png (339.37 KiB) Viewed 643 times
Any tips?
Siewert308SW
Domoticz version: Stable
Re: Youless Power Watt Graph (value is divided by 10)
Post by Siewert308SW »
Tried to change back the 100000 to 1000 as it should be.
100000 is a way to high number as your meter has a 1000 output
Setup:
- DS923+ Docker
Domoticz Latest Stable
Mosquitto / ZwaveJSUI @ Aeotec Z-Stick Gen5+ / PiHole Unbound
P1 USB Gas/Power, HW watermeter
- A lot of Zwave switches, contacts, plugs, smoke/Co2 ect
- DiY 7.5kWh Solar Storage @ GitHuB
ludwigkempenaar
When I change it back, the Kwh reading is messed up again.
ludwigkempenaar
Schermafdruk 2016-12-30 16.19.11kopie.jpg (247.88 KiB) Viewed 628 times
