I've been setting up my Toon in Domoticz (using https://www.domoticz.com/wiki/Toon) and the strangest thing is that from my created switch the mode selector switches are not functioning. I find this strange because the JSON commands used work like they should. So when I paste this commands in a webbrowser my Toon switches to the respective mode.
I wouldn't bother you guys if I hadn't tried the obvious already like removind and adding again but this has got me puzzeled. Must be something simple though but when you know the solution afterwards it mostly is
Hope you guys can help and thanks!
Tim
